- Racepres you may have missed this one the coil has a part number
- Sportster tank on a big twin.
- Overheating?
- Seat Skirt
- Ultima external electronic ignition module
- Using cow pie gearset in ratchet top?
- evo speedometer?
- Rear brake inspection
- 83 fxrs with enclosed chain
- Ultima electronic iggy woes
- Pushrod Tube Leak, middle seal only
- Coil choice Need opinions
- New to shovelhead. New to this thread
- Shop to replace/ream cam cover bushings
- Is an external ignition module better than in the cone
- Pogo Seat Passenger Options
- Edelbrock Carb
- Edelbrock Carb
- Lower Tank Mount.....
- Another Gas Tank Opinions Wanted
- Can you use sealant on tappet blocks.
- Reproduction tanks for 1980 FXWG
- Am I stuck with O-ring intake?
- How To Remove The Headlamp Mount Cover - 75 FXE
- Coil Wire Got Very Hot - 75 FXE
- The prettiest Harley engines in this order
- Saddlebag restoration project
- cca battery for a fxef 1981 superglide
- FXE gas tank question
- 83 fxr
- spark plug
- Good Shovelhead FAQs?
- 1982 FXR Shovelhead valve seats
- Fishtail MUFFLERS for late shovel FLH not FLT
- 1977 fxe
- Had a friend blast a head
- Original Tins.....
- Slap me...don’t work on the bike when tired!!!
- Ultima R2 Performance Carburetor vs S&S Super E
- Keihin question
- Removing clutch hub off tapered shaft
- SuperGlide License Plate Mounting??
- 81 FXS - Compensator Nut
- Trying to identify a part...
- Are these timing marks correct?
- 2005 and 1981 harley davidson
- battery for 79 flh
- A good service manual
- starter drive gear is malfunctioning
- Tech Tips & Tricks and other books
- Signal lights not working
- Front Wheel Question
- Ignition switch problem
- Installed cam bearing “backwards”
- Molested 1983 FXRT, a few questions.
- 1983 FXSB primary belt or not
- 72 shovel cam and breather end-play
- Favorite cams
- Shovelhead leak down test results
- think I maybe the only one with this problem
- 1981 FXS Lowrider - Wiring and Starting Help
- Rockerbox gaskets - Removing heads vs. pulling engine
- 1978 fxe
- What else besides stroker flywheels?
- trike
- Need opinions on fork brace
- Removing stubborn tappet blocks
- 1966 FLH Electra Glide
- Late ‘84 electric start not shifting right.
- 81 Tour Glide Saddlebag Swap
- Dads 80flh Cases to split or not???
- wow spark plugs always a headache
- '81 FLT Tour Glide Saddlebag Lid
- Removing hinge from FLH rear fender
- why do a shovelhead sound different from other bikes
- 79 fxe.....
- 1981 FXS Lowrider - Dyna Ignition Swap
- Primary cover won’t come off
- 1982 Triple Shovel: One-off Three-Cylinder H-D
- Part number needed
- S&S Super B Questions
- 1965 pan/shovel (panhead w/shovel head top end)
- Transmission ?.?.?
- single fire and dual fire which one better
- Headlight Nacelle Finish
- trike
- A Permanent Fixture......LOL.....
- Ultima heads???
- Neutral light and gen light stay on
- 80 flh clutch assembly
- Next project - a few unknowns 1982 FLHC
- My speedo Died
- Value of Shovels
- 1980 low rider
- stainless steel exhaust pipes
- feel guilty
- 2 inch shotgun pipes for my 83 fxr????
- Geeting to know my bike
- valve stem seal
- Rebuilding dads shovel
- 1983 93” shovelhead 5 spd
- Rebuilding/restoring my dads shovelhead
- Clutch springs
- 1981 FXS Lowrider
- 1978 H-D FXS Low Rider Original
- relay
- 1983 FXDG Disc Glide Rebuild/Restore
- Fitting cam cover to new cases
- Ham can grille
- Lever Action Solenoid
- Riser installation question
- piston identification
- next question, intake manifold
- Fender?
- What Am I?
- 71 engine shaft
- Front end options?
- Mystery Bolt
- Progessive shock bushings
- fx rear shock choices?
- Fuel fumes/leak checklist
- Shovelhead Compression issues!!!!!!!!!
- Whaddya' think about this '70?
- Looking for little guidance
- Gas cap venting
- motor identification
- Headlight assembly what is this?
- rocker arm shaft
- '77 FXE sprocket size question
- Electric start issues
- Fat bob mounting hardware
- Brake Curious
- New clutch pack
- shovelhead and jammer
- Charging system ground question
- Control lever question
- 79 flh 80 forward control help
- '77FXE shock springload adjustment q
- Fancy new fuel injection...
- Need some help
- first dumb question - oil lines
- Tombstone tail light
- Single or dual fire?
- I'm confused
- 75 FLH Project
- Finally!
- best place for research photos
- Need help identify this shovel.
- Needing inspiration.....and cash!!!
- mating 2 different engine cases
- transmission rebuild
- Crap!
- 4R vs 3-4 plugs??
- Should 74 gas cap be vented?
- 1977 frame question
- 76 flh forks
- Replacing steering head bearings...
- FXE gauge bracket question
- tillotson carb on 68 shovelhead
- 68 FLH Back 2 Basics
- Will this cam work in a 72 Shovelhead?
- Which brand rebuild kit?
- Help Id a part.
- Mid USA trans gear set...
- ‘77 FXE clutch question
- '75 FXE Charging Test - 4 pin stator?
- 1975 funky frame
- Girders
- What cam is this?
- 74 shovel
- To the shovelhead gods, iso of help
- Compatible foreword controls 74fx
- Brake Pad Help
- My baby
- FL vs FX fender struts?
- Does anyone recognize these mufflers?
- S&S super E carb diagram
- 68 Shovelhead sputters / misses
- Ignition Problems
- Fuel pouring out of Bendix Zenith
- Shovelhead Speakers Question
- Dumb question of the day!
- 68 FLH Bendix carb no fuel for start-up
- Shovelhead disc brake swing arm dims
- C-clip for shitlfter on rachet
- Oil leak fun.............yeah
- Great Day of Riding
- Battery Recommendation
- Need a shorter kickstand spring
- ISO Basic Wiring
- High compression pistons VS. stroker
- Wiring stator to regulator (no plug)
- 74 fx barrel q's
- '75 FXE Custom Wiring Review
- 76 FXE Inner Primary Replacement Options
- Outside oil return
- Starter Bendix
- Andrews "b"
- Strange identification number on Shovel
- does not start, nothig
- Breaking in new Shovel chop
- No compression in rear cylinder
- 76 FXE Shovelhead Disaster Rears It's UGLY Head-Clutch Shell
- Heads
- 1978 FXE superglide
- 76 FXE Starter Mounting ? & Battery Tray Mount ?
- Bike dies when lifted off Jiffy stand
- Shovelhead caddy radio
- PanShovelution build
- Bastard FLT
- Evo cam in Shovelhead
- Tin primary covers
- Bannana Caliper Pad Shim
- What happened?
- 97"
- Trans swap
- Starter Bolts.... Secrets?
- shovelhead exhaust pipe to head joint
- Wiring/ Dash questions
- First Harley learning . . .
- Good/bad gaskets and seals?
- 1977 FXE sprocket question
- 39mm Mikuni VM on a shovel
- 82 FLH Bars
- 1977 paint code
- Fork terminal block
- oil vent drained a few ounces of oil
- Misfire and Stalls-Fuel, Ignition or Electrical???
- ISO 1982 FLTC wiring diagram from service manual
- 1971 FLH Spark
- Back on a Shovel
- brake banjo fitting thread size?
- ‘77 backfiring
- Shovel Primary Oil Question
- 1985 electra glide classic
- Master mechanic question
- What year is this tin set?
- Starter Studs...
- Handlebar clamps
- Trans question
- 76 FXE Starter Wiring Questions
- 76 FLH clutch
- Early or late 1977 model?
- Mechanical advance unit questions
- Luggage rack question
- rear caliper rebuild disc versus drum notes
- 2/4 plug compression release
- front banana caliper 82 FLH
- POS V-Twin Dual piston rear banana (pics)- what a DRAG
