View Full Version : Shovelhead
- Speedo
- Beginner & just got my first motorcycle
- Cam Choice in Mostly Stock 74
- side oling or end oiling cam cover
- Year and model please
- belt belt baby - 81 flh on the road
- 72 flh primary chain alignment/spacer
- liberty edition?
- no start - blowing oil
- 1980 FXWG Color Brown, with brown seat
- 73 shovel cylinder head bolt question after rebuild
- Police Model VIN
- Mechanical pre-trip checklist?
- Points v's Electronic Ignition
- Vin number question
- 1976 FLH Neutral Light Question
- alternative seats for 1982 FLH
- 1983 flht
- Feels Great to be on a Shovel
- Starting
- Oil line question
- Isolating the primary drive question
- 1980 FXWG Front end....so...umm....is this right?
- Some purists will hate this...
- sumping, check ball.. or maybe not
- fork oil
- Hard time cold kick starting
- Chain tension
- Should I buy this shovel?
- New England Shovelhead
- FLH SHovel Head Electric Starter
- Bringing the old girl back to life, but she is a little resistant...
- Vintage Harleys
- 1980 FXWG 41mm Fork Rebuild Question....
- Carb Support Bracket
- 1980 FXWG fork mounted turn signals
- Starter & Solenoid Install 75 FXE
- Shovelhead GARAGE FIND
- Valve guides:difficulty of replacement?
- Fuel Line Routing
- Oil starved front head?
- no oil pressure
- 75 FXE Speedometer Trip Meter
- starter
- s&s super e gas leak
- 76 shovel fx single front disc brake line picture
- FX Wiring Options
- 75 FXE Carburation Issue?
- New FX Fenders......
- Need help identifying tank
- Opinion? I can't decide...
- 79 FLH-80 Need Help with Fenders
- '76 FLH ... your opinion
- 79 FLH-80 Rear Brake Pad Change
- Mounting FXE Tank?
- Coil ohm question...
- engine keeps flooding
- 79 FLH Oil Cooler
- 1985 flhp shovelhead oilcooler
- 4-speed sprocket super tight
- Timing
- Jetting
- New Gremlin
- Occasional Backfire Through Carb At Idle
- Oil Temperature
- Just Dawned On Me.....
- Exhaust Deposit Color
- Shovelhead Idle Speed
- clutch hub is stuck !!!
- Exhaust sound
- rocker box oil lines leaky
- VIN on 1980 FXS 80 Lowrider
- 78 FXE 4 speed clutch help
- Ok... what's the trick... pushrod tube keeper
- Oil Puking
- 79 FLH-80 Update and Clutch Question
- 1983 FXSB Speedometer Cable
- Need to rebalance and true flywheels if cases split?
- 1980 fxe upgrades
- Rusty flywheels...what to do?
- 74ci or 80ci ?
- Fuel Issue maybe Carb
- That has been sitting
- I just put my 117 s&s back together but it won't start ,
- Starter & Solenoid Recommendations - 75 FXE
- Transmission Rebuild Kit?
- Popping out the exhaust on my Shovel... Help
- 83 FLT no power over 4500 rpm
- Clutch Drag On My '77 FX
- Loctite all electrical?
- Never seen such idiocy in my life
- Harley switches
- LMAO about this seal!
- Oil pipe/Exhaust pipe
- Inner Primary Off-what seals should I replace?
- Dual Carb Intakes
- Mount FatBoy rims to 1979 FLH Frame
- What spacers are requirred to mount FatBoy Rims to a 1979 FLH Frame.
- 79 FLH80 Dash Filler
- Lifter Blocks.....
- 70 FLH-80 Spot Lamp and Headlight Questions
- oil temperature gauge
- 74 FXE circuit breakers
- How do you remove engine primary shaft extension?
- 1975 shovelhead primary drive?
- What's it worth? 82 FXR
- Replacing Tappet Guidels
- 100/90-19 Does Not Fit A Narrow Glide
- flh80 front fender bumper
- 4 speed ratchet top trans (aftermarket)
- installing compensating sprocket nut
- Belly numbers question
- pete (iceman)
- ID my cam
- FXE Newbie frame mount Questions
- Stator assembly question
- Wiring question
- Gas odour 81 FXB
- poorly running and I don't know why
- 79 FLH80 - Gas Tank Lines
- Andrews AB Cam?
- Brake Light Activation From Front Master - FXE
- New Ride
- FLH triple tree repair
- Wiring of 5 point ignition shovelhead
- Need some schooling
- Duplicate Keys
- Looking for FXWG pics
- Looking for FXB pics
- 82 FXR Engine clunk
- 1980 FLT clutch
- Wheel bearing end play
- HELP Shovelhead no spark
- Intake manifold question
- 79 FLH-80 Turn Signal Wiring Questions
- Engine reinstallation 72 FX
- Smaller tank on a big twin shovel frame ideas
- Shovelhead FLH brake calipers
- 79 FLH80 Front Brake Master Cylinder
- Questions on 93" S&S big bore engine
- 72 flh rear axle spacer direction??
- Shovelhead wet primary questions
- New '75 project, Rust in Rear Cylinder
- S&S Super B rebuild...
- 78 FLh 1200 clutch issue
- 1981 FLT Engine burning too lean
- Stumbles in all gears
- 1970 With orig tillotson carb settings help please.
- 72 FX Wheel options
- '75 Shovel Kick Start Process
- Battery Losing Charge - 2 Weeks
- 49-77 fork tubes...
- 1979 shovelhead valve seal useage
- starter relay
- FLH fork cover question
- Starter issue
- Anybody running Paughco mufflers?
- Motor mounts...
- 75 FLH ratchet top shifer issues
- Compensating sprocket and clutch hub nut
- Wiring harness
- 1980 lowrider wilwood brake question
- 1980 Lowrider wiring gremlin
- 1972 Shovelhead mystery numbers.
- Free stuff to anyone who is willing to leave their shovel with Bassani in Anahiem for a couple weeks.
- 1973 front master cylinder diameter?
- gasket sealer
- advise for getting me a shovel
- starter stays engaged
- an emotional restoration
- ignition question
- 71super glide
- Paint Help.......
- Another rear shock absorber question
- 1972 FX rear shock length
- 1977 shovelhead lowrider
- Hydraulic Lifter setup preference.
- 71 electra glide fuses
- Torque values for rear shock mounts?
- Nacelle fitment
- Lifters and push-rods - I need advice.
- 79 FLH80 - Original Color and a Letter to HD
- Cam Cover
- Shovelhead Front Caliper Reversal
- Wanting a shovelhead build question
- Looking to fix up a shovehead for a project
- Timing marks
- mercury switch
- Inside the Fender??
- Narrow glide to wide glide question
- over pressure oil
- Primary belt pulley
- 1988 Softail Evo, Shovelhead-like primary case
- Help identify
- Caliper, Master Cylinder, or just Air?
- Rear Cylinder Oil Leak
- Proper oil for shovelheads
- Let's talk exhausts....
- what transmission
- NOS decals
- Voes
- New guy first post looking for input on a motor build.
- Gearing Question
- Shovelhead wiring harness sources
- Shovelhead oil pump question
- 83 fxr fork upgrades
- 71 "ish" FXE Getting redone... Come along for the ride.
- Speedometer question
- adding a kickstarter
- Python Exhaust
- S & S shovelhead rocker boxes and arms
- Piston rings
- Parts Diagram
- can anyone id this please
- Bigger Rear Tire '80 FLT
- FLH engine top end
- 77shovel front mounting bolts
- vent thread size
- 1981 oil feed to crankshaft
- Considering a Shovelhead... Link inside.
- 1977 FLH Turn Signals
- Is this a diamond chain
- Flywheel marks, timing question
- Aftermarket rocker shafts....
- carb
- First HD
- Riding along when motor seized!!!
- new cam
- Installing points ignition
- Compu-fire charging system?
- Starter drive gear an clutch ring gear together
- Clutch dome suggestions?
- Stroker compression help!
- Starter issues
- Is this Spacer in correctly?
- Hog wheel lacing look correct??
- 1978 FXS Early vs LATE ?
- Restoring a '80 Sturgis
- Bike sitting a while, spat oil on start
- Shovel mechanic in East Tn
- 1981 HD FLH shovelhead Heritage Edition
- Clutch release arm - will not adjust
- shovel head oil pump shaft bushing
- Shorter springs in a FXWG front end?
- Later floorboard controls on a Shovel?
- Slab Shovel Idenification Help
- Helpful advice on older bike... thx
- 2 into 1 with fishtail...
- Need help identifying case
