View Full Version : Shovelhead
- FXWG 1986 facts
- 2 into 1 Exhaust for 1982 fxr
- 1975 FLH 2 piece handlebar upgrade
- Inherited '80 Low Rider, shoots sparks
- Rotary top jockey shift/rocker clutch
- Solid vs compensator sprocket ?
- tire pressure
- Fork Oil.
- Late model bags on my '77
- Fabob Fuel Tank collects water under console
- Old horseshoe oiltank..
- '71 FX Superglide - couple of questions
- FXR 1982 Shovel Steering Head Bolt Size
- New to me 72 FLH need some advice
- CV carb no go at WOT
- Clutch Push Rod help
- Stewart Warner speedo ID question
- Fender question
- Shovelhead electrical problerm
- 77/78/79 Low Rider MSRP ?
- Kick only not charging
- 1982 fxrs
- 84 FXSB Tachometer Help
- Lifter wheel bearing failure
- Center dash light 1974 flh
- Shovelhead speedo question from Finland.
- 84 lowrider bobber
- FLH extended rear brake pedal??
- Updated the front of my '77
- Am I crazy??
- Oil
- My shovel is in my grasp! Biker soul but beginner wrenchman here!
- 79' FLH Clutch and Sprockets Upgrade - Experienced Advice Wanted
- Wiring vs Switch on 75 FLH
- Fuel gauge needle goes to E full or not
- Upper motor mount on 1982 FXR....
- Spring is finally here, im ready to go
- a question about compression in PSI.
- 1976 Shovel Broke Stuffed in an Evo Motor
- FLH-80 wheel fitment question
- 1200 FL with S&S "B" problem.
- New look for an old girl.....1980 Sturgis
- Compression release or not?
- How to snug up the popsicle?
- Tapping noise 1974 FLH
- 1966 FLH Pogo prob!
- front drum brake
- Oil cooler
- Optimal Jets Super E
- Banana calipur tight
- First Ride 82 FXR
- Shovelhead rear shock dissasembly
- Primary belt drive
- Primary Belt Drive Wear
- Can someone identify this bike?
- 83 fxrs help
- 79 shovel
- Oil Filters
- New to Me 1982 FXR
- Rear 12" shocks
- New to me 1982 FXR, questions
- 1970 FLH DMV says its a 1981 Custom
- Evo ignition on a Shovelhead
- New to Shovelheads
- Removing an Ignition switch
- Trim pieces in place of blinkers
- West Coast gas eats petcock rubber?
- center Stand
- Troubles With Shovels
- dang S&S
- New to me '77 FL
- Rear Master Cylinder Dilemma
- Need reliable FLH mechanic/shop in Los Angeles
- Using banjo fitting on 1978 style MC
- am I missing a front seat bracket?
- Breather Gear Causing Whine?
- Rear Cylinder backfire
- hello i'm new and need some advise
- "Juice" Rear Drum brake adjusment
- WTF...Just happened...?
- Banana Caliper 1974 flh single disk
- Do I need dual plug heads?
- Waterline?
- '85 FXWG Upgrade ??
- Engine Vin Question
- New Shovelhead Owner...Problem.
- 78 FL Shovelhead project
- front brake noise
- 5 speed clutch adjustment
- 82 FXR - Engine Fins - Paint it Black
- Shovelhead FXWG transmission - is this normal?
- 80ci parts in a 74ci?
- 4 way hazard flasher
- Tire Pressure - 82 FXRS Shovelhead
- to old of bike a problem?
- What can I expect from my S&S 80" Top End Kit?
- Starter solenoid 1967
- first bike could use some help......
- ROCKER SHAFT PLUGS/NUT question
- Remove Transmisson question
- scrapes on right hand turns
- fuze?
- rebuild
- Rubber Mounting a '79
- Need advice on 84 FLH
- Kicked Off Shovelhead Forum?
- voltage meter inputs
- negative corrosion
- Screamin Eagle 7 pin ignition module on a 72 Shovel
- Shovelhead Forum?
- The hunt is finally over! Found a full 66 shovel chop!!!
- little black buttons in old style shovelhead controls
- What's a good price for this 1982 FXRS
- Electrical Puzzle
- Looking to Buy a Shovel - FXR?
- Shovelhead killing battery
- rev tech 4 speed made in usa?
- 1997 FLHT front end on 1978 FXS
- need help finding 1971 fx super glide decals
- Solid Lifter Noise
- Help in identifying this rear fender
- rear swingarm bearing upgrade on FXR?
- Nicest Shovelhead Custom out there
- old stf oil lines
- ultima King spoke wheel
- Finally it's Finished.
- 77 flh kickstart install
- carb time
- Swing arm bearing assembly
- Started leaving trail of oil
- 82 FXR won't turn over
- 82 FXR Won't turn over
- shovelhead compression issues
- Blown head gasket
- Obsolete Parts, who knows where to get stuff besides Ebay?
- Andrews A vs AB ?
- Just Purchased a 1966 FLH Shovelhead!
- Ignition recommendation for '83 FXR?
- Shovel build from a pan
- 81 FLH Rebuild
- How many FX Superglides were made in 1974/75/76 etc.?
- Update on my 1980 Shovel FXE/FXWG
- my COB method to counter boring rocker arm spacers
- Parasitic Draw
- 1978 FXS- Gonna keep it stock
- 1980 Sturgis Worth?
- 76 shovel fuel problems
- 1972 flh shovel condensers...........
- Split rocker boxes
- xr1200r shocks on flh?
- Raking a panhead rigid frame
- Battery eliminator?
- Cam recomendations
- Front master cylinder fitting
- Turn signals mandatory?
- Hydraglide fork harsh rebound
- Just picked up this 84 lowider
- Just showing it off
- 1967-1972 front wheel hub diagram
- Axle question
- Bonhams or Mecum's for my '66 FLH?
- rebuild recomondations
- Static time electronic Ignition
- Preferred Drive Ratios on 93"?
- 93" Cam Choice?
- 1967 Electra glide
- 1968 Stock exhaust removal
- Cold start
- Starter keeps turning FXEF-80
- Front brake fades
- High Cranking AGM Battery for Shovelhead Stroker
- Bike wants to stall not sure if its the carb or clutch
- Rocker oil gauge
- Wheel on old FLH
- antique "dell orto" (keihin?) carb
- 82 FXR needs help
- Here's where I am in my 93" Build
- Best ignition for kicker
- 1971 FL restoration
- 1968 FLH kickstart
- Oil Pump for '69
- stupid question - but can;t google it up
- 19x250 rim
- Winterizing
- Breaker cycling? And an intro…
- rebuild time
- front rotors I.D question
- Starting
- 74 vs 80 Cylinders
- pan/shovel hybrid????
- How to: Update your FLT to late model tins and bags
- Static Timing Dyna S
- cam seal
- Taller Pushrod Cover Seals???
- Shovelhead rocker box stud removal
- Speedometer Help Needed
- Exhaust flange is always welded on?
- Crankcase pressure? Venting issue?
- question about valve adjustments
- backfire, no exhast leak
- Is there an adapter ?
- WTF with the starter now?
- '83 FXRS: New to Shovels!
- early 1984 FLT tour glide bottom end question?
- Looking for a pic of a saddleman explorer on flh
- 72 fx 1200
- Shovelhead smokin'
- Started tear-down on 1975 FX-1200
- 1972 HD Shovelhead
- Inner Primary to Case O-Ring
- 1984 FLT EVO sprocket shaft question?
- 1979 Value ?
- oil light
- Whats wrong with my head??? Shovel Head that is
- Ignition Switch
- Cylinder heat
- How to Wire an Inner Primary Bolt?
- wont stay running
- 76 FLH Fork Seals
- Custom Shovelhead Primary fluid question
- connecting rods on a 1984 FLT
- Just picked up my first shovelhead
- Keeping my 1957 XL, but wanting shovel
- Starter working on a good day
- Crapping out after a few miles
- Here's mine
- My 74-74
- I was Offered this Shovelhead, should I get it????
- Starter Clutch, Starter Drive, Bendix..whatever it's called, how do you replace it?
- Just bought a Shovel
- Oil Leak
- Stator issue
- 76 FLH Squeals Bad Starting
- Recommendations on a carb conversion.
- Need help finding fender struts for 79 Low Rider.
- Best way to find good shovel head
- Trying to ID this Build
- Spark Plugs
- Need to replace speedo cable...what ratio?
- Evo in shovelhead frame
- My first Shovelhead
- Help please>>>>
- new starter
- CV carb conversion - How to?
- Push rods for solids
- Kicking a Shovel
- smoking at start up
- engine and transmission oil change....
- Front Chain Baffle
- gas tanks mounting
