- Timing?
- Now it is really finished......
- Operating temp
- Best brand solenoid?
- Rocker Oil Fittings size
- Crossover dual mods
- Runaway Starter
- slight knocking sound in pushrod
- Update: Leaky rear chain case on FLT
- '82 FLT speedometer bounce
- Pastor Jim
- check ball cap plug
- Kicker installation
- 77 Puking oil and missing line?
- Pics
- audio read switch
- Busted oil vent fitting 1980 FXEF
- Idle is bad. Ideas?
- 74 Superglide Won't Start
- hey john
- 81 FXWG kicker clutch spring
- Soft Front Brake
- 82 FLT starter operating correctly
- Tranny dope
- Eating crank bearings
- Help
- Help
- Doesnt run right. (video)
- What carb do you run on your shovel??
- 82+ front master rebuild
- 74 superglide charging issues
- Rear muffler turned yellow...
- cone engine cam shaft question or 2
- No compression
- 1993 FLHTCU Low Accessory Voltage
- How to set up a 4 speed totary top trans for a foot clutch?
- '80 FXEF 80" wiring woes
- 80 FXW noise
- Primary Belt
- Speedometer jumps over 50mph: repair?
- Paint schemes for 1975
- Scored rear cylinder ... please advise
- 76 FLH Stripped Swingarm Pivot
- oil leaking out of my breather hose
- Vibration near top speed
- options for pipes
- wide glide front end
- Battery reccomendation
- '80 FLT done
- another oil question: automotive oil
- New true duels on
- puked some gas at last fill, is this normal?
- Question about Tappets and adjustment
- Front dual disc
- Wtf is wrong with my clutch?
- Clutch plates
- Questions for electric ignition install
- New shovel for me
- Drum Brakes Humming
- Replace rigid rear brake line with a braided one
- Clutch bearings
- Front Brakes
- Dual Caliper Single Rotor Rear
- Rear footpeg mount
- Synthetic Oil ?
- Any issues with taking a shovel from sealevel to mountains in one trip?
- Front tire Reccomendation
- saddlebag lid
- BUying my first shovel next week
- rocking nut/leak on rocker box shaft;
- Progressive Drop Ins on 75 FLH?
- Flh hinge fender
- How much transmission oil? 1974 flh
- mirror glue
- Paint codes for older bikes?
- Headlight
- Front brake issue pump up lever holds, let go lever drops
- What Happened to all The FLs?
- Starter turns but motor doesn't
- Bag Guards For ‘77 FLH
- Rocker arm screw oil leak
- 82 FLTC issues
- Fork seals 'n oil...time to fix
- removing a batwing faring
- tranny oil
- 7" Headlight on 1980 Wide Glide
- 74 exhaust true duels over priced
- Need guidance with air cleaner and carb rebuild
- lifter block MOD worth doing?
- Starting to look @ shovels
- anyone still run the stock primary chain oiler?
- Starter question
- Oil pump pinion
- 76 FX Superglide
- 77 shovelhead - Rebuilt silenoid, but now won't engage
- clutch issue
- from the ground up
- Left rear crash bar for 1979 FLH
- Fairing question??
- Shovel chop don't like water
- wheel cylinder 63 through 72
- Oil mist
- Noisey Valvetrain.
- Need Speedo Suggestions
- What internals?
- New Guy
- Need ideas for coil
- Dead battery help
- lifter Base bolt thread size?
- Backfiring through carb and exhaust??
- 82 fxr breather issue
- Ignition timing cover riveted on?
- 72 FLH Project
- rods
- 4 speed tranny fill level argument...
- Project '72
- Looking for a kick-start.
- Original Rims
- 1982 Lowrider FXS Build
- Old School
- 82' FXB Sturgis - starter issue
- looking for true duals
- 2000 two cable carb on a 76 Shovel???
- Regulator
- 72' head
- Popping through carb
- Oil consumption
- brass(?) parts in transmission
- fluid capacities
- What other front ends will fit and ild FLH
- Primary chain oiler
- Just bought a new Project - Not sure where to start
- extended forks
- Corbin seat question
- Finally ... bought my 1st Shovelhead
- Is it just me or does everyone have problems with the handlebar buttons?
- Tail light/ Headlight upgrade
- Anyone have a simple wiring diagram using the 72-81 style handlebar controls ?
- Primary assistance
- Respoking
- Died while idling, now won't start.
- 78 shovelhead cylinder base nut leak
- Rebuilding a 1974 electraglide
- How did this happen?
- 74 74
- Need tranny help with my new custom build...
- lost pieces
- Seat
- Lost frame
- Octane
- Looking at possibly buying a 1980 FLH Shovelhead any advice?
- generator output
- 1975 FLH Rear Brake Switch
- need photo of stock 1984 genuine HD speedometer
- modify front end of "75" Shovelhead
- New Heads
- Bent Pushrod
- Bigger front wheel for a 78 FLH?
- FX with FL forks?
- Compensating sprocket
- Questionable?
- 79 fxe chopper finally done
- Identify a stroker or not.
- '63 PanShovel Oil Light
- Need help, primary allllmost off
- 1975 FLH Speedometer Not Working
- 1977 Harley Davidson Confederate Edition tribute bike almost done
- Primary chain
- Intake Manifold Leak/Alignment ('76 FXE)
- Preventive Maintenance Checklist
- 1981 FXWG questions
- Barn find
- Shovelhead with EVO heads?
- more FXE questions - rear fender spacing
- Adjusting Shock
- shovel starts with ignition in off position
- Confused on engine size
- Crane Cams- Hydraulic Lifters Kit # 3-1003 Anyone?
- New (old) 1979 FLH
- FX - FL Frame Difference
- 1969 transmission swap...what fits
- Kicker return, NOT
- stinkin superglide tank mount - fail
- timing plug
- Cleaning up a 78 FLH Electra Glide
- 79 Shovel Starter Relay Question
- This true when switching to struts?
- I ferget
- White Paint for old Fiberglass?
- Need help bike won't start
- '83 FLHS belts
- Big Crank battery question
- Need help tearing down
- Purchase - 1983 FXDG or 1983 FXRS ??
- bendix question
- 82 FLH rider backrest
- Carb problem?
- someone check me on this please
- CV float needle problems
- general vibration and rear wiggle
- DOT 5 and leaking front caliper
- 1978 1/2 80cui
- '69 FLH finished
- Belt drive primary compensating sprocket - got one?
- 4 spd clutch release shaft retainer pic
- jetting
- superglide tank mount help
- tranny plate and spacer
- fork seal question
- Heavy duty seat post springs
- adding a brake light switch to the front brake.
- First shovel....
- 1966 FLH color chart
- o.k. I got one for ya.......
- Starter problems.
- 1980 4 speed problems :( video inside
- Ironhead Saddlebags
- Oil problems
- KeepN a Shovel OG.
- fat boob tank mounts
- Weird clutch wear - would appreciate your advice
- Couple oddball questions i guess
- one shock or another
- Shovelhead oil puking problem
- FXWG Question!
- Handlebar
- Motor Tranny alignment ??
- Footpeg rubber adhesive
- security lockdown
- more 4 speed questions - locking key spacer
- pull trans plate to install 4 speed???
- Springtime Tune up!
- Crankcase Breather
- Springer on my 77
- Vetter Fairings
- oil pump woes
- 4 speed fork spacing
- Mystery of the vanishing clutch....
- 74 flh >4k miles . sitting 4ever
- Looking for spokes
- electrics
- Which oil cooler
- so why is my gen light on?
- Shovelhead Missing
- Poor braking
- What manual to get for my 1982 shovel
- Another vin # question
- Oil Pressure gauge
- Can anyone identify these tins
- Shovelhead Flywheel Numbers
