View Full Version : Shovelhead
- Paugcho slip ons
- Electronic Speedo Conversion
- Glass Bags on '81 Sturgis
- idiot lights on the shovelhead
- Installing new dry primary belt on 72 Shovel
- ? for all you Sturgis owners . . .
- Shovelhead 80" Andrews A/B cam More Timing ?
- oil
- Cam whine
- Happy Easter
- slab side exhaust pipe set - fitment
- 1980 fxwg
- She’s DONE! It’s a Wrap!
- Repair or reupholster FLH solo seat
- carb advice
- Custom cables headaches
- Solid Lifter Adapter Springs?
- Wiring My 73
- Dual Plug Head Wiring
- Hydrolic tappet collapse
- FLHS re-assembly
- FLT Inner Primary Bearing
- '76 FXE: Primary chain mystery
- seat replacement
- jiffy stand Vs primary case
- Transmission Gasket/Seal kit.
- Pan-Shovel oil delivery issue - help please
- Wheel Advice for FXR Restoration
- '75 FXE Starter stays running
- Speedo and Tach Delete
- Oil line question
- Need help converting my 82 low rider front end to flh
- Exhaust stud installation
- Primary Cover Replacement 1970 to 1968 FLH
- air filter
- air filter
- 12 volt regulator ground strap
- best resource, print or on-line, for specs on shovelheads?
- 75 FXE Speedo Cable Fender Grommet
- LED headlight for FXE superglide
- Any forward controls available that will work for tall guys on a early 80’s FX?
- 1978 Shovelhead
- First rides of the year
- 2:1 or 1:1
- CV carb fuel line routing question.
- 1972 FLH Shovelhead ???
- Pushrod seals
- Thunderheart / Dash Questions
- Same ole dumb cable questions. Sorry
- Solo Spring seat for 1981 FXWG
- New owner of a 1981 FLHC
- oil
- 75 FXE Tach
- New exhaust on 81 FXWG-rejet
- 1977 FXE wiring Harness
- Shovelhead Project ?
- 28" turn out muffler, OEM Part Number# 65240-67..
- 1977 FXE Transmission and Primary Questions
- Remote starter solenoid
- Clutch Pushrod assemblies
- Lithium Ion Battery
- Slight “clunk” in driveline - ‘75 FXE
- 5 speed Kicker conversion housing extension FXR FLT
- 1977 FXE Oil Line Routing
- cheap Chinese carbs
- More Master Cylinder problems
- Great Day!
- OEM rear Sprocket offset
- Oil leak out of breather since nose cone replacement
- Help me mount my new wheel
- Mechanical Tachometers
- Cow bells on wide glide front end.
- Bleeding Dual Disc Front Brakes
- Correct Gas Tank Badge
- Picture request
- Issue by the pull starter / instead Magnet
- Oil Tank Plug
- Speedometer drive
- Trying to put My Bike back on the road.
- horse shoe vs the stock oil tank
- fusion cyles
- 1981 FXWG what is stock and what is not?
- 1981 fxwg
- 1977 FXE Front Brake Light Switch
- 1982 shovel motor
- Progress on my FXE
- How many miles till oil change on shovelhead?
- Engine case numbers 1983 FXSB
- Adjusting pushrods
- wrong flywheel marks on my 1983??
- 1973 FX internal throttle with S&S carb
- FXE brakes
- What's this called and source?
- V-Twin Mfg. 5 Gallon Hand Shift Fat Bob Tanks
- starter solenoid fork
- Removing "varnish" from tanks and carb
- Oil tank removal
- Gas Tank Emblem mounting Brackets
- New Oil hose
- Wire gauge for handlebar switches
- Considering a trade.
- Intake manifold gasket replacement
- 1978 FLH 1200 Anniversary
- 1980 AMF HD Wide Glide Flame Paint Info
- Battery Replacemnt FLH Models
- Production numbers & dates 1983 FXR
- 1973 FX throttle assembly question
- running wide open - need advice
- BDL 8mm Shovel install problems. '83 FXE
- 1971 super glide battery
- Shovelhead valve spring installed hieght
- need help
- Seat identifications
- 1972 nose cone shovel refresh
- Bike Identification
- 82 Wide Glide signal flasher
- Shovelhead Help
- Someone must have been good this year!
- S and S oil pump lines on 1980 Shovelhead
- Bill's 1980 FXWG Project
- Merry Christmas
- Trying to put bags on my 82
- is it an fxef or fxe or just low rider
- Poor Poor Shovelheads
- Restorations
- Front master cylinder identification
- Shovelhead heads
- Solid Lifters
- Polarizing 1966 Shovelhead Gets Low
- 79 80"
- 1976, 74cid Close to Stock Engine Build
- 1976 flh 74 cid engine build
- bonehead oil question
- headlight
- S&s sh 93
- Shovelhead Gets Treated to Classic Restoration
- Alternator Rotor
- Good Running 1967 FLH
- simple rocker box question
- which shovelhead the most attractive
- Primary Build Compensator Questions
- 1979 FLH w/sidecar... thoughts, opinions, advice wanted
- Need Replacement Flywheel Advice - ASAP
- Front brake caliper rebuild kit
- Stator test
- trike
- Rear lights stay on
- 1970
- Rocker shaft 0-ring question
- FXR front suspension
- 78 FLH Tail Light Help
- What horn for FXE
- Excessive noise on bench test after transmission rebuild
- Shovelhead Til I'm Dead
- 1980 fxwg
- Just cleaned oil tank and replaced oil lines
- Pour a Glass with Hard Rock Shovelhead
- Sealed primary oil level
- Leaky 4 speed - Need y'all's help.
- Mag wheels
- Oil leak into primary, sliding noises, 81 FXB
- Basket Case Shovelhead Transformed into Slick Machine
- Bringing a 1982 FLH back
- 78 Super Glide Redo
- Blue Beaded Windshield
- multiple shovelhead questions
- Cow pie 4 spd trans 1979
- Im liking this FXR
- '82 FLH winter project
- Dead Battery Kick Start
- nuts, bolts,screws,&washers, what's OEM ?
- 3 1/2 g Fat Bob tanks / OEM NOS ?
- Recognize this Bike ?
- Original Gauge Refurbished
- new pistons
- Blocked oil ports
- flh1200 shift cover wire/ground?
- side covrer gasket inner primary chain drive
- What do you bros think of this motor cycle?
- 66 flh
- tail lights go off when brakes are activated
- Valve Guide Seals 82 Shovelhead
- Neutral light socket replacement 1979 FLH
- 1977 FLH 1200 Electra Glide - crank vent oil leak
- Transmission removal woes
- Can I kick it?
- 1982 FLH Shrine transmission breather
- 1982flh pushrod keep coming loose
- Largest tire width, square swing arm
- Speedo reset shaft
- big twin swingarm frame tubes?
- 76’ fxe mags wheels
- Is it worth buying this 1975 fxe ?
- Purchase advice on a 1979 Super glide
- Cast Wheels for 1979 FLH-80
- triple trees
- 41470-73A rear sprocket 1979 FLH-80
- Shovelhead newbie questions
- Handlebar Clamp for 75
- How much trouble am I in for?
- 1983 Dealer Award FXSB
- Drag Bars- FXS & FXB's 77-80 Dragbar pics??
- Long Island Shovelhead is Done Right
- USA made start solenoid for 1979 FLH-80
- How to ID a 72 FX boat tail with no boat tail?
- Alternator/regulator problem?
- Outer Primary cover
- Horn 1979 FLH-80
- Late 79 Transmission FLH-80
- Float Needle Jet- Anyone used the CV version successfully?
- Time to decide on tires 1979 FLH
- Working on 1979 FLH-80 I picked up last week
- 1979 FXE Chopper Ran When Parked
- Most Basic Wiring to Fire Up '71 on table
- Which seal kit and pads?? Street 1979 FXS FXEF
- For Parts Opinions and Info: Feedback for new "help post"????
- Starter Relay question
- New Brake Issue
- 1984 FXWG Starting issue.
- rear mounts - FXR and FLT - 47553-79
- Best sounding exhaust - GO!
- lowering buddy seat on 79 FLH or seat swap
- Bought a 1979 FLH today
- Pic of Right engine case number
- Nacelle for my shovel
- Inner primary bearing upgrade
- In tank fuel filter for stock petcock? 1979 FXS-80
- ‘82 FLH No spark to plugs
- 1982 fxwg speedo size
- 1976 FLH kickstand spring question
- Riser bushings
- Speedo Trans housing size
- 1980 sportster front end on 76’ shovelhead
- Final drive ratio
- How’s this ratchet top look?
- Some Benefits of OEM Parts and Aftermarket Upgrades
- 58-64 horseshoe tank in a 65-84 frame…
- Shovelhead with no power.
- PVC valve on crankcase vent hose?
- Smoking
- Absolutely cannot get compensator nut off
- rebuilt shovel motor with CV carb
- taillight bodies and lenses
- 81 FXS Front Wheel question
- Piqued my interest, what are your thoughts? (1976 FXE)
- 1980 Limited Edition FXE
- 1985 4 speed transmission/kicker
- Best oil line kit?
- New shovel… think I’ve got some problems
- 1983 fxsb talk to me!
