- Shovelhead Shop In Calgary
- Hard starting 75 FX
- Oil pump for 1975 shovelhead
- oil
- Need help
- Need help
- Super E jetting
- 1982 FLH nippon seiki speedo repair
- 84 FXWG Rear shock rubber bushings
- Remote oil filter location
- 77 FX tach and speedo cluster bulbs
- 1982 FXR Restoration Thread
- transmission swap
- Suddenly not wanting to start
- oil pressure but no flow???
- starting fixed
- 1982 FXR 5-Speed Rebuild Parts?
- Turn Signal Relocation on 1981 FLTC
- Oil pump rear chain oiler feeding primary-WTF??
- Front brake reservoir hitting handle bars
- Clutch hub nut
- starting
- Exhaust Setup Question
- Clogged Fuel Filler Compartment Drain
- replacing shovelhead head gasket
- Battery carrier and oil tank rubber mounts
- Shovelhead backfiring and dying.
- 80 FLT muffler choice
- Rear fender interchangeability
- 77 FLH bar change
- Ratchet Top Shifter Shaft parts
- 1982 FXE Superglide power to coil but no spark
- Primary Part # Check
- Shovel love
- S&S carb support bracket.
- Exhaust Connection Question
- Left Side Engine Shaft Seal & Spacer, Brake Fluid Questions
- Bobber fender
- GMA rear brake caliper
- 67 Shovelhead sprocket nut & primary chain alignment
- 1984 fxef
- FXDG Fender Medallion for sale in Russia !
- Tank decals
- Chasing the Dream!! My 1983 FXDG Disc Glide !!
- i have a question for all you FXRT experts !!
- FXE / FLH hybrid
- monitoring oil pressure
- I'm looking...
- shovelhead cylinder scoring fresh rebuild
- O-ring between motor and primary, FXB ?
- Electric start vs Kick
- More 1984 Harley Confusion
- timing 76 fxe
- New to me tanks and fender
- 5 gallon Fat Bob tank mounting
- 1984 FXEF Odometer cable routing
- Where does this spring go?
- Reed breather valve fix to try
- Anyone recognize this spring?
- 81 FLT Inner Primary.
- Loose Fork Bearing Cup
- FLH Brake Upgrade
- Ignition upgrade 1983 FXR
- Front brake lines.
- Solo seat OEM 52004-25 Vs 52006-47B
- Fuel Line
- should I buy 1969 Shovel motor ?
- Keihin carb
- 1981 fxs factory gold pin stripe paint
- 1980 FLT swingarm question
- Ham can a/c cover insert.
- Automatic oiler delete
- FXEF SuperGlide Dash Mounting
- shovelhead swing arm question
- S+S shovel
- 3-1/2 tanks
- Quality gaskets?
- Shovelhead project
- FSX Engine Silver
- Hellone
- Standard rear shock length confusion
- Anyone recoginize this ignition?
- 77 fx
- Sealed beam for a 1984 FXEF
- Can I put a late model Shifter fork shaft in an early model transmission case?
- 1977 FXE shake down runs.
- Comfort flex seat mounting
- 1982 FXWG Shovel Restoration
- Bought my old bike back!
- 1983 fxsb
- Speed O Meters
- Lurching in gear.
- Banana caliper question
- Working on my 81 FXB
- Does the primary pressurize
- How to ID O.E.M cetrifigal Advance components
- Ignition coil v fire II
- 1983 FXDG Twin Belt Wide Glide
- Wheel bearing question '79 FLH
- Duo-Glide center stand on an FXE
- Ignition upgrade
- Shovel questions
- Great brake upgrade (imo)
- Kehin 90 degree inlet cracked
- Stumbled on a garage with a few old bikes
- Points Timing
- Shovel ignition condenser
- Transmission ID help
- Ultima 53-50 Single Fire Ignition
- Starter motor
- Hydraulic Lifter Specs
- Main shaft Clutch Nut Different Thread Pitch
- Chain guard bracket info
- Kickstart has gone to pedal, see pic
- 83 Disc Glide rear wheel.
- Bad Weekend!
- Ultima Ignition died Switching to Points
- Lost wrench
- Which side is positive?
- Late model mufflers on Shovelhead?
- lever Action Solenoid
- original risers if any 77FX
- Painting to stock color, 77 FX
- 1984 5-speed Shovelheads
- Speedo
- Still having primary problems
- Softail 4-piston Caliper and Rotor on my FXS
- D.I.D. 530VGC-SO Pro "O" ring chain
- Stock handlebar for a 77FX
- Using a FX rear fender on a 1982 FLH
- Fall cruise
- 3/1983 Iron Horse mag FXDG feature
- S&S B Question
- Crankcase blow by - how much is to much
- Release disc and clutch plates
- Will my front axle/wheel fit?
- FLT nacelle to FLHR style
- 76 fxe trike conversion
- 1981 harley davadison low rider 4 speed transmission out shaft run out spec
- Rear shock bushings
- 77 FX Ignition siwtch/choke and horn placement
- 41mm axle diameters same, except center?
- Relays
- 1982 Wide Glide Project Thread
- 82 FXB issues
- Oil filter needed
- Ignition module ?
- 77 FX wheel set
- 5 speeds
- 79 fxs
- FX super glide tank
- FLH wiring problems
- Buying an '82 FXR
- brake fitting designation
- 1977 FXE 35mm fork seal ?
- 81 fxs oil line mystery
- Shovelhead retro fit
- startershaft/jackshaft lengths and years
- Rear Wheel Question
- Getting a 1979 FXEF 1200 running after 30 years
- '82-'84 FLH's: more/less desirable than 70's FLH's?
- Best fit exhaust pipe
- 79 FL build
- 1981 comfort flex seat frame install
- '72 vs. '73 and on Front End Question
- 77 fx
- Ultima Ignition Programming Kit
- Pogo seat install 1980
- 82-83’ low rider PRICE??
- Torgue on compensating sprocket nut
- Anyone running Conti Twin K112 MT90H-16 F&R?
- Dual fire ignition coil
- What are extra swing arm brackets for?
- Inner primary washers
- Tank identification OEM vs Aftermarket?
- shift conversion
- Transmission - Is this for a Shovelhead?
- H-D Spun Aluminum Wheel 41057-83
- Voes
- OEM Stock guides - HD Part not shouldered
- Rear Brake Switch Question
- seat
- The Last Shovelheads: 1984 FLHX Special EditionThe Last Shovelheads: 1984 FLHX Special Edition
- Clutch ^%#@
- Which Solo Seat fits my 1983 FLT
- Primary blues
- Off the lift
- Smiles per mile - Miss Piggy always delivers
- Electronic ignition
- "O" ring for starter solenoid
- Brass nuts for copper terminal circuit breaker
- New member in search of part
- 1984 fxwg
- Foward Control for 79-fxe super glide
- What clutch plate should I buy?
- Front calipers
- 82 FXR Ticking Noise
- 1976 FLH inner primary part# questions
- Late "S" cam
- Front laced wheel 43341-78
- 81 Shovelhead - Piston Wrist Pins very tight
- 81 FXS - Brake Light Troubleshootibng
- Advice on ignition timing
- Advice on Value in today's market
- 68' FLH Clutch Issues
- Outer Primary Bent
- Push rod covers
- Oil Tank
- Torque for engine case studs
- Modern Lubes in a Shovelhead
- FX or and FXE or an FXR or an...
- 1979 Clutch hub fit
- Oil pump and gasket help
- Orphan Build
- Electrical issue:starts, runs and lights ok. Nothing else
- To all!! PDF Manuals are not allowed!
- Oil Leaks
- Raked? Cups? Trees?
- NOS mufflers for FXR
- Wicked S&S Powered 1955 Shovelhead Bobber Built For Skin Doctor
- Shovelution?
- 1980 FLT front fairing, did it have one?
- Rear Chain adjustment
- Brand New Tappet Guide Blocks
- Oil troubles
- Primary Belt Drive ID
- Bates Mfg. "Ride Off Stand"
- balance flywheels
- 72 Custom Shovel
- 81 FXS - Rewiring Questions
- 1980 fxe
- Rocker box studs
- Talk me out of this bike
- Frankenshovel Identification
- Piston Help
- 'Funny' Newbie Story
- cast pistons
- 1966 Shovelhead,
- Tank Ignition Switch Wiring
- Secondary Chain Gearing
- 74 fxe
- Dumping primary oil
- Early Rear Banana Caliper on 81 FXS?
- 1982 FXB Sturgis
- 1977 Super Glide updates
- Never lose your shift lever again
- Picked up a 77 just for fun
- 4 speed tranny clutch
- Pinion gear fitment
