- Oil consumption question
- 81 FXS - Frozen Banana Caliper
- Dumb Bendix Carb Question
- Brake Drum Cooling Ring
- 81 FXS - Stupid Wiring Question
- clutch arm
- 1981 fxs low rider shovelhead chrome inner primary conversion
- Troy's 1983 FXWG/FXDG Replica Build
- new shovel due tomorrow - 83 flht
- Head questions...
- Sealing pin hole leak in tank.
- Torque
- 81 FXS - Brake Help Needed
- 84 into 76 fxe
- Shovelhead transmission
- Chain Master Link ID
- 1979 FL electrical wiring diagram colorized
- Unexpected South Korean S&S Shovelhead Chopper
- Need Brakes solution for my 1981 FXWG
- '76 FXE Shovelhead: Where to find quality critical parts?
- 1981 fltc center stand instruction or parts list
- 83 Shovelhead FXDG just up and died on me!!
- 78 FLH Front Brake
- Calling out Johnjzjz
- bloody kids
- My 1984 FLH - Last of the Breed
- '76 FXE Shovelhead: Rattling sound from primary?
- My 69 FLH Out and About
- connect light tour pak AMF on my Shovelhead
- new to shovelheads
- Any value to 1976 OEM Tour Pack and Fairing?
- Southern California Repair Shop Recommendation
- Oil Leaking From Engine Bolt?
- New Here~! '73 FX Question
- Where did Harley Davidson go wrong?
- 72 FLH oil pump replacement
- Aftermarket speedometers repairable?
- Broken Crane Solid Lifter Pushrod ...
- 77 FLH - Help Please - Where to find brake parts?
- New frame
- Thinking about a NEW rat rod build...
- 81 FX Oil Pressure Switch
- 83 flhtc
- Bike doesnt like being kicked over?
- clutch issues
- Skin-Deep Attraction for a Shovelhead Hardtail Bobber
- 1979 FXS-80 rear wheel interchange
- 1974 FLH Colours
- clutch
- Primary fluid question
- 72 FLH rear chain adjust mystery
- Spark plugs left out...help!
- Can anyone identify these bikes?
- shovelhead Fly wheels, cast #s ??
- Who makes the best primary cover gasket?
- Rear wheel & hub interchange
- Lubricants for 67 Shovel
- Just wanted to say thank you
- Shovelhead BDL Competitor Clutch Buzz
- Plug chops
- New to me
- LED headlamp for 1975 Superglide
- Plugs
- Spring service and little cleanup
- Sturgis Primary Compensator
- Lost my FLT saddlebag lock
- On start, loud pop, smoke from air filter and no power
- What should I check next
- Early 79 Shovelhead Primary drive removal
- Buddy seat question
- Electrical help
- The age old geariing question
- Compensator Shaft Extension Removal
- Mid controls for 78 Super Glide?
- 1973 FLH Front End
- Tillotson running rich
- 81 FXS Inner Primary Bearing and Seal Install
- Done!!!
- New to the forum/First Harley 1975 Super Glide FX
- Nostalgic Look at Shovelhead FL Production
- 1982 Electra Glide no right side turn signals
- Idle and throttle cables FXR
- 1983 FLH. engine and transnmission oil recommendationn
- Oil Pump ID
- 1973 Shovel Troubleshooting
- Recommendations for mufflers (or complete systems) for a 69 Electra Glide
- 76 FXE Turn Signal Issue
- 79 FXS Shifting problems
- Carb jetting with fishtail slip ons
- Tire time
- A Little Noisy when Cold
- Cylinder work
- 1983 FLH starting issue.
- wiring harness removal from headlamp housing
- 1976 flh1200
- 82 FXB wont crank
- Front Fender for 1973 FLH
- Speedo/dash differnce
- Brake line won't seat
- 1983 FXDG Bent Pushrod
- 81 FXB exhaust mount
- Plug Chop Tuning Tips
- UK 77 back together
- wiring loom
- Gear Whine
- 1970 FLH Gas Caps
- clutch
- 72 FLH dash wiring
- Best service manual for 78?
- Turret top 4 speed counterhaft issue
- My 1974 flh blue lady
- 1983 FLHP w/ FX front end
- Looking at buying 1983 FLHTC,have some questionss
- Throwout bearing fork
- clutch
- Lesson learned: cheap gas tank
- 1976 FLH Crankcase pressurizing and leaking oil
- Need Help...Turn Signals...
- 1968 Shovelhead Ad
- Transmission Sprocket Question
- 103 inherited
- transmission oil
- 73 FLH + Sidecar
- What to do, What to do???
- Photo needed of 79 FLH ignition switch wiring
- I’ve had a Pan, Evo and TC
- It's Alive!
- Super basic question
- 79 FXE T.P. Engineering Oil Pump
- Shovelhead VR1 SAE 50 Engine Primary Transmission
- Bike holding charge without ignition, when ignition is wired to the coils battery drains charge.
- Very, very basic battery question
- reverse
- Flh side covers
- pre pair for the wet-sump
- motor seized..??
- motor seized....
- 3.5 or 5 gallon tanks
- Oil Burning from Front Cylinder
- oil
- Upgrade 68 FLH Battery
- Modern twin-cam era front end parts on a FL shovelhead
- Static Timing
- Mdg
- What should I know about a first start after top end rebuild
- Fitting a stroker
- 1980 FXS with Wide Glide-speed help
- 1982 FXWG Custom project
- Rear Crash Bars and Paint Codes
- the frames center post
- Clutch Issue? or something else
- Starter gear/ bendix
- Vintage cylinder head temp gauge connecting
- Removing clutch
- 1976 Electra glide
- Cam ????????
- 5 Speed oil mixer?
- 84' Shovelhead Compensator Sprocket
- Transmission Sprocket Binds
- About service and parts manuals
- trapdoor
- '83 shovel ratchet top issues
- keep hearing
- Front base cometic gasket issue
- FLH Shovelhead Windshield preference
- 1978 Superglide fxe detail photo needed
- Question
- 73 FLH Shovelhead Rear Wheel Bearing rebuild
- 70 Shovelhead nose cone alternator motor, battery eliminator
- Hardtail rear brake caliper
- Neutral Switch RevTech 4 Speed
- Transmission misses 4th and 5th gear sometimes
- Oil Cooler Thermostat Mounting
- carberetor
- Re-wire and ignition
- Primary' choices
- What would you do?
- Primary to Engine Install
- Passenger Footpeg extensio
- Dads Old Bike
- Stuck 1 mile from home today 83 FXR
- First dumb question - lever starter on the solenoid?
- Torque spec for 79 Fxef exhaust
- Primary chain inspection and adjustment
- Goodyear D402?
- Late 1984 Shovelhead wet clutch oil capacity.
- Ragged 1979 Shovelhead Bobber Made Mechanically Sound
- Install clutch hub
- 83-85 Rear Master Cylinder Setup
- Piston rings for 77 FLH
- 4 speed mainshaft seal problems
- Leaky Tappet guide gasket.
- Tear down
- Accel Petcock?
- Reserve Fuel
- Swap enricheners between S&S B and E carbs?
- Quality lifters?
- Intake Seals
- ‘77 Shovel - Engine teardown
- Potential coil problem maybe?
- How to release pins from cam timing sensor plug?
- Motor not starting help!
- Ignition switch part number
- flh
- Cylinder Base Stud Question
- Brake piston insulators
- cast wheels for 82 FLH
- Polarizing 1966 Shovelhead Digger Goes Real Low
- Finally decided to do a rewire on my Shovel.
- 72 shovel compatibility questions!!!!
- Inner Primary Re-assembly Question
- 3-Piece Oil Rings
- 82 FXS Inner Primary Oil Line Routing
- 82 FXR Teardown
- Wheels
- 81 Sturgis inner primary
- My 73 Shovel
- Muffler support tubes
- 82 FXR questions
- Help on 1979 FXE rebuild - inner primary
- Super E jetting?
- Rear brake light switch
- Base Gasket Leak
- Speedometer ID?
- LED headlight
- Help..... 67 FLH Electrics
- Shovelhead side or end Oiler??
- Duel Fire Ignition...
- Tour Glide Solo Seat Options
- LED running lights front directionals
- Classic 4 speed Wide Glide's (shovel & Evo's)
- rear chain oiler t
- Help! Engine ID suspicions
- 1973 Shovel Top Speed
- Decal's...
- ‘77 timer cover decal
- 74-75 shovel head spark plug "science"
- Manual Kick Starter
- Crashbar oil cooler project
- Oil lamp doesn't turn off
- Tank filler strip for comfort flex
- Total # of 1983 FXR sold
- Will Street Bob shocks be too stiff for my 79 FXS?
- Re-engineer the 1973 Electra Glide FLH Brake Pedal
- clutch
- which frame
- School me 1979 FXE
- Newbie Springer Questions
- 1967 Oil Pump / Inner Primary Questions
- Orphan
