- Speedo for 1983 FXR/sportster
- 80 Rotary Top 4 speed - Super Nut
- FL Saddlebags
- Thoughts on shovel exhaust...
- What model is this bike please?.
- Looking For a shop
- Compensator sprocket question.
- Shovelhead lifters
- What is in your bike tool kit
- 1972 shovelhead rear brake line
- Speedometer Drive Rebuild
- OE Black Mirrors
- rare sportys surfaceing
- ‘67 FLH Starter
- What exhaust for 75 superglide
- 1980 FLH ignition system wiring
- 1984 4 Speed Rotary Top Mainshaft Leak
- 81 shovel
- 1970 FLH Mirrors
- Rear brake MC not working
- Ratchet top issues
- 1970 FLH Passing Lamps/Turn Signals
- '79 FXEF 80" back on the road
- Specs for stock cam on 83 FXR
- Looking for part number
- 1981 FXB Sturgis
- daytona fla last ttime was 1971
- clutch cover
- Primary gearing
- Rocker box rebuild
- Cam Cover Won't fit
- ‘72 FLH grounding issue
- transmission
- Shovelhead flywheel identification
- Jan 18-20 west Springfield ma
- 82 FLH rear chain clearance
- Hello, New guy here with need of build advice
- Fuel tank mounting question
- Best Brake Pads, Stock 81 FX
- Small Hose Nipple On Back of Ham Can
- About chains: final drive
- Head scratcher
- flh 4 speeds
- Need help choosing final drive spockets
- 1972 Shovelhead vin help
- FX BDL Primary Removal Questions
- 1981 Staggered Duals w/ Crossover
- Starting up my 84 FXWG for first time in 15 years
- Drive Chain Recommendations
- LED H4 bulb now no low beam
- 74" Stroker Pistons
- Dual disc/ front end questions
- 1967 Shovel Intake Manifold
- I want a new horn, 1983 FLT
- 67' Foot Shift Linkage
- Merry Christmas
- And the fun begins....uk 77 glide
- 1983 FXE color
- 1967 FLH Kicker
- Cab carb on 1975 shovel
- Final drive belt tension 1984FXWG
- 3rd Gear Noise
- Officially it sucks
- Dry Clutch Problem.
- FXE Fender Bracket (Brace) Rivets & Rivet Tool
- Hydraulic Lifter Collapse
- Advance Assembly - 76 FLH
- 67' Shovel
- high torque starter
- My 1974 FXE rebuild
- clutch
- 1981 FXWG front brake calipers
- 85 flh 80
- Cam cover seal installment
- oil pump
- seat springs
- '78 Electra Shovel
- Chipped intake valve guide.
- Broke my clutch splines....
- Tire and Wheel question
- Help with a 77
- Uneven heat range / front head 90f difference
- Front brake lines 1983 FXR
- 76 FXE Liberty Edition Paint Name?
- Turn Signal Flasher Stays On?
- Offset disc brake rotor
- Have one to sell? Sell now - Have one to sell? Details about D&S Performance Dash Rubber Mount DS-105
- Anybody still selling Shovel inner shock bushings?
- Belt removal
- 1973 w/ Hydraulic Lifters
- Timing mark changes from early 1980
- 1980 to 1984 flt rubber mounted frames
- Fxe carb question
- 76 FXE S&S Super E With BATES ADAPTER For Oval Air Cleaner
- S&S Adjustable Pushrod Kit #93-5067
- 1982 tranny swap
- leaking shovelhead rocker shaft end cap .
- School me on windshields
- Help with dismantling my shovel
- Time for paint
- 76 FXE Silly Question Time
- New to me 82 FXR with fully built S&S motor
- Chopper Transmission 5th Stud Tab
- Miss My 78 FXE
- Adapting Ham Can to S&S Super E
- Upper shock stud options - Crash bar elimination
- Speedo Tach for 1975 Superglide
- replacing indicator lights on headlight visor
- Confused primary oiler
- Battery Question
- wrist pin or button
- Breather gear opinions.
- wiring terminal block behind head light bucket
- Parts compatibility help
- FSM for 80-83 Shovel FLT & FXR for sale
- Can anyone identify these parts?
- Test ride with new oil seal 1983 FXR
- My fenders and tanks are in!
- Oil pump cover?
- speedo cable 1983 FXR
- Brake light doesn't work with the front brake lever
- FX & FL - Same Frame?
- supporting rear exhaust on 1983 FXR
- Cleaning up the bars
- 1984 FLH Rebuild
- Identifying this oil pump on my 1980 Shovel
- Well the ole 82 FLHS.. hit 2000 miles today
- [QUICK] What's the deal with this James oil pump gasket?
- 1983 front fender
- Buckhorn Handlebar Specs
- Anyone use this for their exhaust header?
- Help needed with clutch adjustment with cowpie / rotary four speed transmission
- oil pump ?
- 66 out of the shed
- Wiring starter solenoid backwards?
- Rivera Primo maybe out of business
- Thinking of buying a 82 FXR
- New to the forum
- 1980 FXWG Help Needed
- Battery Losing Charge
- 40 weight oil question
- Changing motor oil, and primary
- This Clutch is Killing Me (Mousetrap vs Diaphragm)
- 1983 FXR compensator nut torque 80-100 ft/lbs?
- Banana Caliper Too Tight
- 1980 FLH VIN Check Help!
- Police Solo Air Ride
- Acquired a Couple of Gems
- Pinion Bearing clearance
- crankcase misalignment
- What to look for ???
- Pulling my hair out - Lower Legs & Seals
- 1968 FL Shovelhead Scrambler Fusion Build
- Primary Build Tips - Clutch Hub & Lubricant
- Venting 1983 FXR primary
- 74 FLH in SLC on KSL classifieds
- 1980 FLT Starter spinning
- Bad lifter?
- LED headlight
- Belt Drive?
- Weird tourpack
- Introduction // Help needed - FLH 80" Wiring/Full Repair Diagram
- Production numbers
- 1980 FXB Sturgis Forward Controls
- ‘78 shovelhead question
- GAs Tank Venting
- Oil Overpressure
- 78 FlH Lifter Advice
- 76 FXE Front RIM Chrome Replacement Debacle
- Oil Tank and Lines
- '76 FXE: Primary with a hole in it.
- Desperate part hunt!! 90759-79
- Clutch Adjustment
- Rotor clearance to wire clip
- rare real wheel
- Clutch Questions
- 84 FXS, 4 way flashers possible?
- Buck horn bars
- 1969 vin
- Max valve lift on '82 Shovelhead with high lift springs
- LED's on a 1971
- Stock Front Fender
- 1975 FXE blowing oil
- Favor to Ask: Cutaway Primary...
- Dynatec DS6-2 Dual Coil No Spark
- 1982 FLHS oil line clean up
- sprocket alignment 83 FXR
- Electrical
- Throwback Thursday: Chop Work's 1976 Shovelhead Trap
- Not a show polish.
- Breather gear causing sumping?
- front brakes on 1981 superglide
- 76 FXE End In Sight, But Still Need Help W/Exhaust Spacers
- Engine sprocket shaft spacer removal
- 66 issue
- 74 FLH Not Starting
- $800K shovelhead
- Hot start issue
- Flanders handlebars for fxe shovelhead
- 74 FLH Whirling
- 76 FXE Interconnected Dual Exhaust Hardware Question
- new lifters
- My 1973 FX1200 during its 26 year garden stay
- 76 FXE Shovelhead Rear Chain Oiler & Crankcase Vent ?
- Parts ID
- 76 FXE Clutch Adjusting Srew Nut Question
- 76 FXE Starter Solenoid Issue - FRUSTRATION
- Ultima Drag Pipe Bracket?
- Dyna S timing issue
- 1970 FLH Front Drum Brake
- Hard Start When Warm
- Shovel head rebuild, is it difficult?
- 76 FXE Shovel Parts Install ?
- Spark plugs in shovel
- 1983 FXR crankcase breather hose
- Mallory Electronic ignition?
- 1983 fxs
- S&S Super E - Throttle conversion
- 1973 Exhaust Flange Fitment
- very original 1967 Police Special FLH
- speedometer reads fast
- NOS Genuine HD FX/FL Seat
- '81 FXB Clutch Cable
- Super Nut q
- Tank liner
- riviera primary on 1982 Sturgis
- Pushrod won't fit.
- erratic voltage
- e-start problems,....
- 76 FX 1200 motor paint
- Motor oil vs transmission oil viscosity q
- hey pans -- help
- 2-1 HD Exhaust.
- 81 Sturgis general info
- Original 1969 FLH
- Petcock to Tank Gaskets
- calipers
- Dual Plug wire routing
- 1980 FLH Fork Question
- S&S Super B Throttle Cable Routing?
- New member new paint
- New member and new Harley owner
- Valve guide dimensions
- Shovel trans Speedo drive issue
- No fire part 2
- Replacing Oil Seal Motor Sprocket
- Cam Gear/Pinion Gear
- 80 Shovelhead stutter
- amca terryville Ct swap
