- 1966 shovel, questions/ advice
- Won't start when hot
- 80 lowrider
- Fafnir/Timken X-Reference #
- 1985 FLH Coughing
- H-D/Veglia RP"V" vs. H-D/Veglia (RPM) Gauge ?
- 75 FLH Project
- 67 flh
- "H" grind?
- Backfire through the carb under hard throttle.....unless I remove the air filter
- Barnett scorpion
- 84 Lowrider Rebuild
- Are solid cams that much noiser?
- Noob here....
- Snap ring size
- Starter engaging
- getting fed up chasing this engine noise
- Oil Shut off valve
- Bore measurements
- Baker 4 speed?
- ISO rear master cylinder for 83 FXWG
- Repair manual
- FX limited model 1 per dealership 1980's
- comfort flex seats
- '77 FXE neutral switch question
- fx prices
- Picked up my new to me 71 FLH.
- Is a sifton 55q a hydraulic cam?
- Does anyone have...
- Motor reassembly: pleasant surprise
- Solenoid question
- Bogus numbers or not.
- Points and electric start.... change to kick only?
- conrod thrust washers
- Supertrapp 2 into 1 exhaust opinions
- New England guys swap on sunday in CT
- Well it fell apart
- How to tell 2:1 or 1:1 speedo drive?
- what make springer front end is this?
- '72 FLH timing question
- I've gotten a Bike/ Title
- Tell me what you see
- Removing drive chain
- I’m looking for a shovelhead.
- Aftermarket replacement hydraulic tappet inserts
- Shovelhead clutch/kicker issues
- shovel head timing
- Aftermarket risers
- Performance Machine Calipers
- Starter oil deflector q
- Buddy seat overload springs installation
- Stock foot controls for 1973 super glide
- CV carb into my Shovelhead FLH cable problems
- Day 1 with my totally fixed up '74 - stalling and popping
- 1976 FX Owners Handbook
- Timing
- 1971 Night train boat tail super glide
- '77 FLH cranking too quick
- Genuine HD FX/FL Seat
- 1980 Starter relay location
- Replacing cam cover
- Quick question about 41mm fork damper
- Turn signals only work when I hold the button in.
- building a shovelhead
- ‘78 Shovelhead Ressurection check-list?
- Do I need a new clutch?
- OEM Spoke wheels 1980
- Points Static Timing - WTF...
- New 1970
- Transmission Question
- Starting
- Crankcase breather for a 72 FLH
- New Front Rim Suggestions....
- 83 flht restore
- '76 FXE: Primary too full of oil. Not draining?
- Default 73 electra glide cant find throttle cable replacement
- Shovelhead inner primary/ oil pump hose question
- 75 FLH Mainshaft Bearing Support
- help with electrical trouble
- 79 shovel rocker arm shaft and spacer install?
- A Real Gem.......
- lifter help
- Rear cylinder won't fire but everything checks out
- What happened to my clutch?
- Fxe inner primary cover question
- FXWG Seat
- Front Brake Switch Thread Size
- Dual plug heads / coil choices
- Super glide tank fit
- 1979 shovel head
- '77 FXE transmission emoval q
- FXS Rubber mount
- Do fishtails sound weird?
- transmission
- 1982 FLH classic shovelhead
- More wheel spacer/alignment issues
- Shovelhead Inner Primary Part Manufacturer
- What did I do wrong? 81 flt rode into garage 2 weeks ago..now wont shift?
- lower fork tube/sliders
- 1981 Flt leaking oil under enclosed rubber chain cover?
- 73/74 Electra glide help? I’m a motorcycle noob
- 73/74 Electra glide HELP-I’m a motorcycle noob
- 82 flh
- 1981 Flt battery cable orientation?
- what backrest fits my 1983 FLT Shovelhead
- Shovelhead Rotar Removal (Shaft Extension)
- Rocker shaft end seal
- No fire to rear cylinder
- wow OEM Reference: 31445-85
- what year ? engine DKM 187085
- Front Brake Light Switch Blues
- New owner of a 1981 Flt Classic...battery tender harness question
- Replacing rubber oil lines
- 77 crusty shovel home
- Dyna S to Points
- Clutch retainer question
- 2" over Wide Glide oil capacity.
- relay issue
- Coil
- Oil and Maintenance advice 1983 FLT Shovelhead
- 74 zenith throttle cable problems, please help
- 84 Shovelhead no spark to spark plugs
- Wiring 72 FLH
- No fire part 2
- No fire part 2
- Low charging with lights on
- Turn Signal question??
- 1976 Shovel OUTER Primary Interchangeability
- Rear wheel spacers 74 flh
- 77 FXE Question
- well this is it shovelution in the making but my coil not firing right now my hand level statrer works good best $150.00 i ever spent
- '77First Gear Problem
- Extend brake pedal 1983 FLT Shovelhead
- 84FLH has spark, fuel...will NOT fire...?
- 81 FXE starter trouble
- Shovelhead Inner Primary Part Interchangeability
- NOS FXWG Side Plates
- No fire to plugs
- Will it fit and how?
- Popping noise from engine
- Seating IP transmission shaft main bearing 9040
- Hard starting
- FLH speedo
- Swap faring for light-bar and windshield
- No fire
- What's going on ? the spark plugs come out with oil on the electrodes
- 84 shovelhead broken Ignition timer cover STUD
- I Keep snapping wires...what to do
- Spark plugs fouling. Dry carbon? pictures
- '76 FXE: Clutch cable keeps getting loose
- Spark Plug Threads Question
- Static Timing - 1975 FXE
- Date of Manufacture
- Uneven rear brake pads
- Will a Scissor seat mount fit my 1984 FLH? Pics attached
- Need SEAT help!
- Converting from aluminum wheels back to spoked
- 1979 FXE quit charging
- Exhaust Pipe Bolt Removal
- Question for the originality crew...
- Forward control brake lines
- Bendix zenith float height
- My 77 Clutch Basket...
- Backwards Shovel
- New-b Shovelhead question
- Choke Cable
- Original FXWG Seat
- Super E hiccup while coasting
- Just pulled the trigger on a 1983 FXR
- NOS Brass Eagle Sissy Bar Insert
- Front fender interchange flh
- Need help converting 71 fx to jockey shift/foot clutch
- Passenger foot rest options for 74 flh with kicker
- Setting Super E float level question
- Is there such a thing as a 77 FXE Willie G Edition?
- Question about solid lifter conversion parts
- Inner Primary question
- Help identify this tank
- New Member - Hello
- So i got this '74 flh...
- Baker 6 to 4
- 1982 FLH rear chain size
- Noise in rocker = engine out?
- New project
- 69 Electra Glide Generator Shovelhead
- Putting intake back together again
- 1984 FXSB Handlebar Vibration
- White smoke out of carburetor
- 1969 FLH Shovelhead Build is a Radical Swingarm Chopper
- Advice on rear sprocket
- 1974 FLH Misfiring
- What rebuild kit for these Lifeline forks on 1980 FLH?
- What to do with this 71 FLH
- 66 FLH lamps in nacelle
- Lifters
- Starting problems...
- Clutch issues
- 4 speed tranny wont kick!
- Clutch mod recommendations for '80 FXEF
- 1984 fxwg
- Tamer and BDL Big Fix Roller Bearing way to go?
- The dog dish carberetor cover
- Ignition points cam questions
- S&S Super E Shovelhead Blues
- Need Head Work done anyone know of anybody in Ma
- LED Flasher Issue - '75 FXE
- 1976 shovelhead
- Springer brakes
- FXS restoration : Can you help me ?
- Muffler rankings
- trying to roll on this for real
- the shovelution is ready
- starter housing
- seat height 1983 FLHT
- Clebrake front caliper on '75 FXE
- Did the 78.5 fxs lowrider come as a 1340 even with the vin starting with 2f
- Tank model/year question
- '76 FXE: Starts cold, won't start warm. WTF?
- 1978 FLH Swingarm hitting crash bar
- front end interchange
- Converting hydraulic tappets to solids
- Inverting hydraulic tappets to solids
- Headlamp Wattage & Amps
- Dumb Question....
- superglide tank on flh
- '76 FXE: Can you identify these?
- Bone Stock FXS Rear fender
- reusable oil filter works I think
- Messed up pretty bad,need advice
- how to adjust a ultima 2 carberetor
- Compression for stock cases?
- '76 FXE: It started!!! And then it puked....
- Saddlebag Gasket Residue
- Bottom End Longevity
- my shovelution
- took a trip on the twinkie after the rain
- rear pegs
- scorcher tires
- shinko tires
- 73 Shovel Carb leak
- Points conversion
- Break
- Time for new cases
- Starter Ground Wiring (Y/N): '76 FXE
- Dash Wiring
- Progress with the 1982 FLHC Belt Drive Classic "barn find"
- oils
- Wiring harness pin thingies in headlight?
- Tach Shows 1500 RPM - Engine Off - '75 FXE
