View Full Version : Ironhead
Pages :
10]
11
14
- Crane HI-4 rear cylinder timing
- 1977 XLH compression
- Looks like the forum is fixed
- Super E or Super B?
- new to this forum
- tires for XLH
- Hey Pyro!
- Help. Gas in oil tank?
- Thanks for all the help!!!!!
- ITS FINIALY ON THE ROAD!
- 1973
- Cam Gears Won't Align
- Brushes in a prestolite starter
- TAMMER II
- compensating sprocket shaft extension removal
- generator question
- Birds in my engine & tranny ?!?! HELP!
- Speedo Drive problem!
- Restoration complete
- Wiring Question, Dont want to set it on fire!!!
- 1975 Rehab getting close!!
- Starter Switch!!
- Put bike back together!! Problems!!
- 1973 Restoration
- Coil
- Im Convinced....
- pg heading out......
- HTML code
- Petcock Installation!
- compu-fire question
- SELONOID IS HOT!
- difference in volt reg.
- Took a short ride this morning
- only two questions this time
- voltage regulator questions
- Battery install!!
- Mikuni Carb
- Oil leak in 79 iron head
- Installation of Adjustable Main Jet Kit for Keihin
- Posting pictures
- hard to kick start...got to be a common thread
- grindin' rocks with an ironhead
- Smoking Ironhead
- Thank you Everyone!!!!!
- need simple help with s&s carb
- leaded gas
- GENERATOR/REGULATOR PROBLEMS
- New here an would like some adivse
- Starter Relay !!
- setting idle with no tach
- Smoke Out 9
- Longer front forks
- Timing Question
- New Exhaust mounts
- Gas problem??
- FrankenHead is alive!!!!
- HELP!
- Lots of problems. Need help from all the experts
- Curcuit Breakers!
- HD Factory Service Manual
- Tachometer 78 Sporty
- Removed front directionals!!!
- cant keep the bike running
- 1965 HD Sportster in great running condition with some alterations
- What should I do?
- Rpm gauge Cable!!
- 79 xls puker
- Ignition and service manual questions
- what is the best way to adjust a clutch
- HEAD BOLT QUESTION
- 1973 Bendix carb jetting
- won't shift
- Central East Illinois Mechanics?
- Shifter shaft bushings
- My '76 XLCH Bar Hopper (BRHPR)
- generator regulator help
- TOP END ASSEMBLY - 1974 XLH
- Need New front end help
- have a 1975 iron head need help carb
- rust in my lunch box tank
- Tranny fell apart---------
- Ok, what is it
- timing light woes
- Mainshaft roll pin ?
- 77 xlh oil from pipes
- rear rocker box removal
- anyone have bendix tuning insructions?
- Rocker Box ArmĀ“s
- Jumping In & Out of 1st Gear.
- 72 chopper value?
- 73 XLCH Clutch Adjustment
- lowering 1980 xlh
- 75 XLH Rebuilt
- primary oil
- cam cover
- 3rd gear noise
- Bendix questions
- 1977 and 1966 IRON HEADS
- Generator/ Regulator question
- Starter Issue on my 78
- replacing my carb
- Do I need an oil cooler on my 77????
- gear case?
- Rode is calling
- Another Screw up from the Previous Builder!
- New bike!!!
- Primary belt for sporty?
- Ironhead Oil Drain hole stripped Question
- 1976 Ironhead forward controls
- clutch issue on 68 xlch
- Help!
- 21 to 24 tooh sproket
- Primary fluid level?
- Oil Pressure & Temp gauge??
- quick question-shift lever travel-rebuild
- Replacing front brake pads
- ignition question
- bike was running at 300 degrees!!
- 73 front brake pics?
- starter solenoid
- Bendix needle size
- 84 forks, can't get 'em apart
- So how many of you have been here before........
- what is this? 73 sporty
- 1973 1000cc stock cam lift?
- Loose shifter
- 1969 XLCH- front forks
- Problems installing Solid State Regulator
- saddlebag hardware
- '57 upgrade & needed parts
- Paint Codes
- Boring, Stroking 1000cc
- DEAD BATTERY!
- 1970's a puker
- VIN numbers?
- handlebar help
- Transmission Sprocket
- kickstart bind/ story and help
- Carby... what type?
- cam cover torques/gasket/finishing
- 77 sporster forward controls
- Average MPG
- Generator Gear
- Cams and Timing
- anyone have a spare carb for sale?
- Front brake mounting bolts
- New thread for old stories......
- HELP!!! '73 Only firing on one cyclinder
- intake seals? carb recommendations
- 73 sportster help me please
- to seal or not to seal? Prim/cam covers
- needle in a haystack?
- sporty pawl carrier loose???? constant problem?
- torques for 71 trapdoor not in clymer
- 74 Ironhead ( Starts - Runs a little & Dies )
- Primary Cover!
- flat spot and sputtering in 4th gear
- charging/electrical problems
- Timing Frustration!
- wheel swap
- top end
- Last Year of Ironhead?
- RT SIDE SHIFT CONVERSION KIT
- need a kickstand, any for sell?
- transmission and primary oil question
- cam adjustment ironhead...
- starter wont turn it over at all
- Finally got a handle on it...
- '76 xlh low end miss
- lowering 1980 sportster?????????
- a note on Bendix carbs....
- OK, Do I have the bike from hell?
- Electric Starter Not Holding - HELP
- what is a good starting point with the bendex carb
- No Spark....
- how tight should the drive chain be on a hard tail be
- 74 XLCH Help....lol
- kNOXVILLE,tn
- Side Mount Coil
- getting tighter
- 74 XLH STARTER DISENGAGES
- front brakes
- some new pics of the scoot!
- front drum on a 73 XLH
- difference between roadster and sportster
- '73 Petrol tap fixing
- generator for sell? I need it.
- PIPE WRAP
- TANK HELP
- I need help changing fluids in my 74 Iron Head
- Chain info
- Your own touch
- I know, dumb question
- tripple trees
- help lowering
- Delco Voltage Regulator
- Last S&S question, I promise
- Was it the Bell?
- Attention "powdercoater"
- 71 XLCH Timing Marks Don't Line Up?
- Chain Size
- kickstart slipping through
- Bendix Carb - 74 Ironhead
- Ticking noise from engine
- Chain lubrication
- Adjusting carb 85 XLS
- Oil Leaking from head
- 80 xls lots of ?????
- Drive Sprockets
- OIL & GEN lights
- Electric Start not working
- 1970 xlch Tire recommendations
- Running lean? please help!
- Chain Oiler
- won't start, need help
- electronic generator regulator
- 76 Bicentennial ironhead ?
- finally starts but takes a lot of kickin
- 79' elec. problem
- compression release
- generator question for someone with alittle electric smarts
- S&S Super E questions
- Goblin Mill worxs
- CENTER STAND
- 81 Ironhead Electrical Problem
- Mikuni VM Carb Question
- cylinder head intake boss and identification
- another newbe question, will not start.
- cam end play question
- Need front end help!!!!!
- adding front brakes
- Free Gaskets
- clutch/transmission il
- Need confirmation on a brake question
- rear wheel
- 68 xlch,is electric start possible????
- Top End Starved for Oil .... Help Please
- 73 Ironhead will start but won't f@#k'n run
- Value of 72 XLH Basket Case?
- A friend had one
- help indentifying sportster engine
- shock bushings
- 74 XLCH - Value Guide Seal
- cafe seat
- i need an oil tank/battery box unit
- FRONT CALIPER..74 XLH...out of ideas
- out of ideas!!!!
- lots of newbe questions
- Poor Acceleration question
- gear and clutch
