PDA
View Full Version : Ironhead
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14
  1. mufflers
  2. need help trouble shooting why bike will not start
  3. Speedo 2240:60?
  4. Ironhead charging problem
  5. Ironhead charging problem
  6. original cost of a 1976 Sportster 1000?
  7. Oil spitting out of breather on start up
  8. Project bike - Most of a ‘79 XLH
  9. New member first Harley but.......
  10. Just bought a 1977
  11. 73 xlh
  12. Forward controls E1973 sportster
  13. 1979 XLH oil pressure issue after oil change
  14. Ironhead brake questions
  15. rear brake cable on a 1976 Ironhead
  16. 900cc ironhead sportster heads on 1000cc lower
  17. Petcock seal
  18. Has anyone put this on a 76?
  19. adding an electronic distributor to a 1969 xlch
  20. tappet adjustment
  21. possible project/possible frame problem
  22. '74 brought back to life
  23. Front cylinder noise in Ironhead
  24. Engine swap 84 Sportster
  25. Ironhead loss of compression
  26. Clutch Question
  27. Chain case oil, '81 Ironhead
  28. Proper weight oil, '81 Ironhead
  29. where is the diode ?
  30. Merry Christmas Everyone!
  31. Piston ID
  32. Ironhead spitting carburetor
  33. Shuts off while riding
  34. My first Harley
  35. Sportster 1000 XLH Harley Davidson ???Brakess???
  36. handlebar knurls
  37. Bendix carb throttle shaft seals
  38. No spark condition, theoretical question
  39. 79 ironhead 1000
  40. Boat tail
  41. Original Ironhead I'm thinking of buying
  42. Buying My First Ironhead
  43. What does an original 76 liberty sporster point cover look like?
  44. Sprocket Cover Cracked
  45. anyonme have an opinion on oil coolers and filters?
  46. Valve question
  47. '72 Ironhead, Needs Work, I Need Help
  48. sporty rear wheel
  49. Interchangeability
  50. stalling after 30 seconds.
  51. Busted rear brake line
  52. Starting 1968 build - advice welcome
  53. Fresh front end parts for the '83
  54. 1970 XLH question
  55. electrical problem - 1980 Sportster
  56. 1983 Harley Davidson XL-1000 Ironhead Sportster
  57. One last thing beore i start my build
  58. Need a qualified ironhead engine rebuilder
  59. Any body know a professional shop that rebuilds ironheads,,,
  60. pics just because
  61. 1965 XLCH value check
  62. rear master cylinder function
  63. ignition switch wiring
  64. Gas Mileage
  65. My 72 Ironhead
  66. No key, hot start?
  67. 1977 Sportser XLH 1000
  68. 76 valve seats
  69. primary fluid for 1977 iron head 1000
  70. What are the advantages to a belt primary?
  71. High Mileage?
  72. 1976 Ironhead trouble please help
  73. 80 Ironhead with Super E won't idle steady
  74. Keihin butterfly carb adjuster for secondary
  75. Wet Clutch
  76. Swapping mags for spokes
  77. 1982 xlh 1000 rear brake
  78. Front brake banjo? 1982 xlh
  79. ID this caliper?
  80. Charging System Pick
  81. tach fitment
  82. bleeding brakes
  83. 79 ironhead. compression
  84. 1955 KHK Iron head
  85. 1967 xlh
  86. 80 1200 build
  87. Kick Start Kit for 79 XLS
  88. 79 sportster
  89. 1982 xlh rear master cylinder mount
  90. 1960 sportster
  91. Computerized ignition module
  92. Please help wiring 81 ironhead
  93. what is different in the 79 ironhead sportster than 78
  94. '79 Sportster XLH - A few questions
  95. 1979 ironhead xlh 1000 fork stem size?
  96. Electronic ignore. to points?????
  97. 1977 ironhead rebuilf
  98. Building a Bucket list bike.
  99. 74 ironhead no spark
  100. 1969 xlch sportster with a mag
  101. How Many XLCRs left?
  102. spotted on ebay kick&elec setup
  103. Posting pics in XL Forum
  104. 69 iron head chopper project (How bad have I screwed up?)
  105. ironhead wiring
  106. Wheel and tire swap help needed
  107. Should I buy this parts bike?
  108. What year gas tank can I buy?
  109. Need Help with TDC and Cam Timing for 77 Sportster
  110. charging voltage problem
  111. Bringing a 1973 back to life
  112. New Gas Tank
  113. 81 ironhead wants to start.
  114. First bike
  115. Looking at 77+ Ironhead, any years better or worse?
  116. New Generator
  117. Iron head 1985 won't hold idle after a hot start.
  118. 81 sportster wont start after pushrod adjustment
  119. 67 sporty
  120. My Ironhead chopper is nearing completion
  121. How to start . . . a build!
  122. A happy, no problems thread...
  123. front brake trouble
  124. Replaced generator and voltage regulator on ironhead and now no spark! Please help
  125. coil secondary resistance only 12,000 ohms
  126. weak spark
  127. stutter/misfire
  128. Title out of state bike in CA
  129. Regulator Question
  130. 81 carb help
  131. 75 XLH Footpeg and other stuff question
  132. new ultima ignition
  133. Ironhead Get Together This Summer
  134. 1977 XLX Rewire
  135. Repairing oil pump
  136. A New Ironhead Fan
  137. 1981 Ironhead Firing Issues
  138. 1978 ironhead smoke
  139. 1971 Sportster
  140. 1980 sportster rebuild
  141. Rear Brake Plug
  142. 1973 Ironhead
  143. Starting a rebuild on a burnt 73 Ironhead XLCH
  144. Strap on gas tank
  145. sporty shifting problems
  146. Wiring a regulator
  147. starting issues for my 73 ironed
  148. ironhead brake trouble
  149. its time for a change
  150. Transmission on a 78
  151. bike stalling
  152. What to look for when buying
  153. idle issue
  154. ironhead wiring issue
  155. Primary Case Bolt Size
  156. second opinion on starter ring gear install
  157. clutch drum xlch
  158. 1978 Ironhead
  159. 77 xlcr
  160. 75 xlch starter conversion kit
  161. weird problem with my 75 xclh
  162. Bendix Zenith on 1975 XLCH or S&S?
  163. 1976 sportster bicentennial
  164. starting problems
  165. Dyna S ignition no fire on front Cylinder, key off fires
  166. Tank paint
  167. 77 XLCH project
  168. Tech Tornado Starter Question
  169. Lowering options
  170. 1970 XLCH sportster engine
  171. 78 clutch cable
  172. Rocker box gaskets
  173. Possible stator issue. Opinions?
  174. ironhead points/condenser
  175. Strnge speedo issues
  176. Carb cough
  177. Front Brake Rattle
  178. Carb and brake issues
  179. polishing rocker box
  180. '69 xlch n/r project-clutch issue
  181. shifter spline work in a 75 ironhead
  182. Hello New here from Oregon. Already having issues!
  183. My "new" Ironhead!
  184. 1974 Sportster oil problem
  185. How many links?
  186. Say what??? This is an IRONHEAD!
  187. engine location
  188. Push Rod removal 1985 XLS
  189. Road Test...Finally 1985 XLS
  190. XLCH with electric start cases
  191. 73 Ironhead
  192. Looking to replace my Super B
  193. Value of '67 Ironhead
  194. 1985 XLS Neutral Indicator Light
  195. 77 ironhead
  196. My first Ironhead...
  197. starter question
  198. 73 sportster engine question
  199. neck bearings/swing arm bearing
  200. 1979 sportster service manual
  201. Your Thoughts??
  202. Best Ironhead Mod, bang for buck
  203. Advice on my 1960 XLH 900
  204. Windshield suggestions for my 1985 XLS
  205. 1970 gas tank decal
  206. VIN and frame numbers
  207. Brake work
  208. 1976 sportster no spark
  209. I'm back--This time with a 1983 Sportster
  210. 1960 xlh 900
  211. help with tail light
  212. Happy New Year!
  213. Merry Christmas Everyone!
  214. 69 ironhead
  215. ironhead troubles
  216. 78 Ironhead on rigged
  217. '62 Ironhead Oil Pump Check Valve Question
  218. 78 Ironhead on rigged
  219. Leak Down Test Questions
  220. 1971 900cc Ironhead oil pressure spike !!
  221. Ultmia Ignition System on my 78
  222. Daytona Twintec ignition
  223. Engine oil in gearbox 1971 Ironhead
  224. question on shocks
  225. Compression test results
  226. Leak Down Test?
  227. More questions
  228. Fork size
  229. Wrong Parts from Dealership
  230. 78
  231. Tach, Speedo & indicator Question
  232. Got a Bad Genny
  233. '76 IronHead hard starting,'UpDate'
  234. Spark Problem
  235. '76 IronHead hard starting
  236. My 77 basket case rebuild
  237. Throttle
  238. 1967 sporty help needed
  239. 71 Ironhead Project
  240. First HD
  241. Need upgrade suggestions for an old Ironhead.
  242. Drive Chain
  243. '72-'78 Factory Starting Options
  244. Front Brake Problems
  245. Ironhead Torque Spec's, Where to find?
  246. 81 Ironhead carb issues
  247. 23t Drive sprocket
  248. My "new" ironhead!
  249. 83-85 Ironhead XLS Roadster Frame and Engine Case Numbers Discrepancy
  250. Carb Rebuild
