- Non-adjustments
- bendix z
- How's the ride on an Ironhead?
- S&S Carb
- another 68 ironhead -craigslist
- 84 ironhead-craigslist
- 75 ironhead-craigslist
- 68 ironhead-craigslist
- carb troubles
- Flames shoot out of tail pipes & has some piping
- 68' xlh starter engagement problem
- 83 seat swap
- 70 XLCH newb needs help
- 85 Ironhead Sporty backfires under load!
- tach installation
- No spark
- 72 ironhead speedometer port
- Need Help Identifying This Tank
- i have a couple questions
- 73 sportster question
- need help
- starter
- Timing marks on flywheel
- "75 Ironhead starter circuit
- Stupid newbie question
- 75 xlch charging issues???
- 69 running issue
- carb question
- 1975 Ironhead
- Got a gear and it's not what I was told it was
- need help w my old ironhead
- oil
- 81 sportster 1000 trans problems
- 38mm mikuni vm
- Really high oil pressure???
- Identifying motors
- chains and case compatibility 1966 XLH?
- 2000 Miles
- 84 xlx Help
- trying to figure out this ignition
- '80 Ironhead with Super E won't idle
- 85 Sportster Ironhead - Loud Valves
- 81 ironhead sportster fuse box
- 1981 Ironhead
- Calling for Ironmick or Scott......
- '73 Shifter popping out of pawl
- Drive Sprocket Thread/Pitch ???
- Chains a slappin'
- which carb is better
- new 74 sporty. "garage art" ever seen this
- On the road again!
- 1980 ironhead questions
- 1973 Ironhead XLCH
- 74 xlh
- 74 xlh
- 82 IRONHEAD electrical power loss (newbie here. pleas help)
- 73 sportster xlch charging issue need help!!!!!
- Lots of oil in the Crank! HELP!
- a few pics of my 74 Ironhead
- Please help, I have no idea
- 1972 right side shift ironhead
- 1976 Liberty Edition Questions
- Replace Intake Seals ???
- Rear Axle Breakdown
- Power just cut out
- 1982 sportster zeinth carb
- Thottle 1971 ironhead
- Service Manual / Parts Catalog Question
- bendix carburetor... 75 xlch
- Engine Blasting
- 1985 Ironhead Sporty low miles
- Need help identifiying my 79'
- mikuni or bendix
- 1977 Ironhead burning oil.... Trouble!?!?!?!?
- Choke Question
- Some shots from my camping trip
- battery loos on 75 ironhead....
- loss of power - '66 XLH
- clutch problem for 75 ironhead
- How to avoid stolen bikes?
- CDN Laws concerning Custom bike builds?
- Oil Issues
- Do you like Chop's or bobs?
- 67 XLCH help needed various areas
- Please Help 74 Ironhead XLCH
- 75 xlch straight pipes
- iron head popping through the carb and exhaust
- Iron head starter issues
- DP Customs: Seventy Three
- ignition switch conundrum - '66 XLH
- Wiring Questions
- Starter Problems
- Removing Cam Cover
- 75 xlch electrical problem.
- original paint colors
- Rebuilding Motor on 1977 HD sporty 1000.
- 75 xlch shifting problem
- Problems using a newer rear master cylinder
- trans overflow spitting oil
- Warm weather carb performance
- converting to electric starter....
- 75 ironhead gearing
- Help Reading Plugs
- 68 xlch help
- 73 IronHead Wierd Spark Issue...??
- 73 XLCH Carb Tuning
- AGM battery for old ironhead
- Ironhead starter issue
- Happy Birthday
- valve adjustment video
- Average oil consuption of a 74xlch running 60wt
- 1981 XLH1000 oil filter and location
- Quick questions!
- 79 sportster xls
- weird steering issue
- 72 Sportster 1000 questions
- tachometer gear drive
- Thinking fo up dating a few thinks on my 1977 sporty.
- 68' sporty is running strong
- Speedo help
- General questions
- smoked then died
- just some questions on my old iron
- My new 1971 sporty
- 73 xlch dash
- 68' ironhead clutch questions
- Kick start ratchet plate
- Does anyone make a complete clutch kit for my 68' sportster
- 75 ironhead kicker,brake plunger
- taking off primary cover 84 ironhead
- Starter issues with my 68' sportster ironhead
- Seat
- oil issue?
- 84 xlx bobber - keep main harness or not
- Carb quirks
- 1971 XLCH Update - Video Link Included
- New Owner - 1971 XLCH - Carb Issues & Build ??'s
- Rear belt drive conversions
- 72 sportster forward controls
- New guy, Older bike
- Handle Bars
- First bike and customization
- Spring - Any ideas
- Sporty died
- Internal vs. external throttle control
- 75 Ironhead - Bike dies when shifting into first gear
- Quick battery discharge
- What years are engines interchangeable?
- Piston Slap Questions
- CV carb question
- 1981 sporty
- Enrichment full on!!
- Buying a 74 Ironhead
- need some help
- Finished my project: Replica XLCR
- Winter Riding
- Rear Tire Question
- Merry Christmas!
- Weird Starting
- Name that bike!
- new harley rider..please help
- 1st time Ironhead owner
- Cold = lean?
- I threw in the towel
- 1972 xlch
- Pinion Gear and Clutch Repair Combo
- 75 Ironhead Starting Issue
- Starter issues escalating
- Mikuni VM38 Questions
- Lowering the front end
- Just bought an 71 XLCH.
- '79 Sportster Seals/O-Rings issue
- Lets see your Ironhead
- dumb oil question
- Reddish / brownish gas
- 69' XLH checkin in
- Guess its a wrap !
- 1980 ironhead
- Transmission / Primary Oil Leak
- Frustrating Problem...interesting conclusion
- Ironhead -shovelhead diff
- Decaffinated the Ironhead...
- Oil pump
- Anyone ever see one of these???
- 73 XLCH bogging down on acceleration
- generator replaced wont start!
- electric start problem
- Shifter replacement?
- What causes backfiring thru the carb?
- Waking from a 30 year slumber
- Main jet adjustment??
- rear jug won't fire....stuck valve?
- 75 Ironhead idling / electrical problems
- Timing and points for my ironhead
- I actually got that Ironhead!
- 1975 ironhead
- late 84 short
- stripped starter gears
- 74 Ironhead
- Oil Diagram for a 74 sportster (ironhead)
- 78 Ironhead Electrics???
- 74 sportster front brake
- Manuals etc
- oil leak trough gearcase vent
- Float no longer there
- fork stem removal 83 sporty??
- Temperature problem solved (Long post)
- Front and Rear tires for 1983 Iron Sporty "Wider"
- generator bosch voltage regulator problem
- round two
- What to do with this rare bird
- For you iron head guys
- Need crankcase covers for 1981 1200 Ironhead
- 75 sporty original
- 76 bicentennial sportster possibile bad motor, what would you do?
- tranny oil early 84
- Smoking Between Shifts
- Ironhead value?
- Turns over no spark
- Clutch problem
- 0il pump
- oil puking
- What year is the last real ironhead?
- If you could own any year of Ironhead, which would you pick?
- Another one to the fleet
- Gunna buy Ironhead tomorrow
- maybe last ride
- 74 XLCH Starter stays engaged
- ironhead 77 or 79 custom build
- Headlights
- trade a rat 73 xl for a 61 xlch chop??
- Cleaning metal particles out of engine
- I need a lesson - ironhead
- "New" Ironhead in Michigan
- ironhead wiring
- I think this will work
- Looking for an early Ironhead
- Generator?
- 77 sportster growl
- Looking for advice on 1971
- Problems in the rear cylinder
- Bendix carb tuning
- '71 clutch ramp woes
- IronHead stock exhaust - Drag pipes?
- Reliable company for springer front end.?
- Push rods question
- rear shocks
- Hello fellow ironhead's. Need info.
- voltage regulator issue (I think)
