- Hand control conversion
- Tranny lurks in 3rd. gear
- Stubby Weld on Hardtail? Who makes it?
- forward control woes
- 69 XLCH Build
- 75 XLCH teardown
- Rocker Box Leak
- Possable New winter Project
- wheel difference 78-79
- Winter build
- spinoff oil filter conversion
- Oil Coolers yes or no ?
- bobber project bike (HELP)
- New project.
- Selling the '79
- Frame/Engine Numbers
- Bottom Dead Center?
- S&S Super E
- oil line replacement
- Thanks to the Admin!!!
- Ironhead pr0n
- Thread/ThreadStarter too w i d e
- rear pegs
- Almost There
- hot wing glass, seat
- coil wires
- Bleeding w/ DOT3
- rocker arm cover to crankcase oil line
- Bed time for the season
- Desperately in need of Guidance
- carb pop
- BackFiring Help
- Voltage Regulator
- thank you iron mick!
- flasher wiring
- leaking exhaust fix
- Pics of the 76 liberty edition...
- turn signal flasher
- ignition wire routing
- new try@ posting pics
- 1958 dry clutch
- new paint and decals
- hardtail frame?
- Tillotson carb number 66 sportster
- ron trock passing
- starter
- tapered bead tires
- finding a trustworthy iron head mechanic
- Xlh or xlch
- starter drag
- Primary drive inspection, clue requested
- '73 Charging system problem
- I'm getting close y'all
- what's this mean???
- Low compression, worn primary: ride, or not?
- Timing lobe shape
- removing lifter bolts
- ironhead belt drive conversion?
- anyone needs used parts?
- 72 sportster $
- 21 inch wheel?
- fork oil specs
- 1960 XLCH timing
- '79 Sportster start up question...
- Complete electrical
- Piniongear has no more questions or complaints...
- Piniongear has a question and a complaint.....
- cam cover gasket leak
- 1975 XLCH - to buy or not?
- engine compression
- Manual Spark Advance/Retard questions
- oil pressure
- S&S Super E-98Glider
- 76 ironhead
- key blanks
- piston / cams 85 XLCH ?
- What motors can go in a 1972 sportster
- 1970 push rods leaking
- new 79 home
- new to me 79 sporty
- Riser Bushings
- 1976 sportster question...
- Hi volume oil pump
- iron head chain get tight and loose
- a few more pics
- few pics of a bike rally
- 74 hardtail project bike
- 81 charging system problem
- Lotsa pressure
- Early/late 75 xlh?
- Rewiring a 74 Sporty
- Engine Oil in Primary
- More stupid questions!!!!!!!!!!!!!!!!
- Drive sprocket
- lost compression
- Won't start
- Ironhead with FL shocks?
- Chrome voltage relay cover
- question about brake master cylinder banjo fitting
- Need Input
- Almost finished . . .
- 81 missfire
- Flat track action
- Re-installing a starter on my Iron
- '65 xlch trans issue...
- rear wheel adjustment
- 1977 charging system not charging battery
- Need help ID pistons
- Carb and throttle
- honing top tree
- exhaust leak
- 72 Cylinders and heads.
- fishtail exhaust
- 76 ironhead starter trouble
- noise after warm up
- 77 XLCH will not turn over!
- Ironhead parts for sale !!!!
- ironhead cylinder heads?
- stuck in gear
- Insurance
- Ironhead years needed
- 81 started Kinda??
- 80 xls
- carb issues
- Mick Got Ran Into ...
- oil fill tank
- picked up my sporster last night
- pics of my 80 iroinhead
- new controls on an old bike
- 76 won't start
- regulator
- cam shim/bushing question
- ironhead temp
- Those arent points?
- primary chain adjustment
- metal trace in primary
- Primary chain/adjuster shoe life
- single wire generater
- 71 ironhead oil change
- What is everyone's opinion of this bike?
- My first Harley
- first ironhead,need help
- I think I'm stupid
- just need an opinion
- chance for a trade need opinion
- Clutch
- 75 tranny/73 block?
- Just picked up my 80
- Diagram of 1973 Ironhead Tranny
- Steel clutch plate slot alignment
- '74 Sportster kicker
- OFFTOPIC but must seen...
- new to Ironhead riding
- 74 Sportster Carb Problem
- new to me sporty
- Clutch hub and main shaft bearings
- Spark plugs
- Any experienced shops in GA/Southeast for Ironheads?
- Clutch hub nut removal
- sprocket ratio
- gererator noise
- Primary breather valve elimination?
- Timing question.
- Mikuni VM38 trouble
- Ironhead oil pump
- Oil Filter For 1972 XLCH ?
- Shocks
- Gettin' close
- my wifes 72 Sportster build.
- pain in leg
- Help stop the Brake Rattle!!!
- do I need to use a horn relay?
- 72 XLCH sportster oil leak
- anyone familar with different rotors...???
- Gear shifter issue - '72 XLH
- chain oiler bypass suggestions
- Even mo' progress
- Mo' progress
- Ironhead oil line?????
- push rod adjustment
- ironhead to shovel conversion
- Figured Out What Snapped!
- japanese forks on an ironhead
- can anyone explain the #s on the neck ?????
- starter sylinoid
- 75 xlch. why does the generator light come on all the time.
- Rim Material
- compression
- Something Snapped?
- Project progress
- 1977 1000 sporty
- Timing on a 73 ironhead
- What ignition system in a 1972 sportster
- 1973 xlh
- 1972 ironhead FLCH right side shift leaking oil
- 75 Ironhead clutch slipping
- Check out my 78
- super gorgeous ironhead
- branch intake
- Tenino Antique Motorcycle Swapmeet Aug 15 & 16
- primary chain
- paint in gas tank
- Cylinders, Combustion Area and Carbon/Soot.
- Ironhead charging issues
- 76 ironhead (pinging)
- generator to alternator
- alternator noise
- lost compression and white smoke!
- Stubborn Starting
- newest motor in a 68
- 71 xlch that won't shift
- gas flow problems
- 75 Ironhead chain oiler
- 75 Ironhead fuel octane?
- Need Machine shop recomendation for valve seats
- oppinions please
- Spark Plugs
- primary cover
- What is the difference in 1000 Sportster Heads & Cylinders?
- keihin cv
- s&s super B jeting
- clunking noise in 76 sportster
- '80 XLS brake line question
- 74 XL Oil Leak at Push Rod Cover/Tappet guide
- 75 Ironhead clutch drag
- 76 Sorty timing gears pic
- Going Rigid???
- thru bar wires
- 4th gear slippage
- Electronic ignition?
- 75 Ironhead oil bag functions?
- New here, looking to make some friends. I need some help with an 82 xlh 1000.
- What's Considered Normal?
- Early vs. Late
- whats going on
- WTB hardtail frame for 1980 Ironhead motor
- 4 speed to a 5 speed
- intake / exhaust leaks
- '82 clutch dragging
- 1982 sportster generator ????
- xlh and xlch whats the difference
- 78 sportster electric start problems
- Cam chest assembling questions '80 XLS
- Fuel type for 1980 Sportster
- 73 XLH - Several fuel related questions..
- runnin hot!
- forward control problems
- Caliper for 83 XLX
- 75 Ironhead solenoid/starter problems
