- progress update
- primary fluid question?
- Cam Mess
- 67 xlch rocker arms
- XL rocker arm screws
- Ironhead generator testing questions
- Rear fender strut interchange
- 59 XLH rebuild help.
- 900crank set in 1000cases with 900 barrels/pistons and top end can this be done??
- 1974 XLCH Sprocket Shaft Bearing spacer
- Shakin' baby Shakin'
- Its alive
- Transmission Questions
- 74 XL Speedo selection and connection
- more starter advice
- starter selniod
- Starter clicks but doesn't turn
- looking for wiring diagram or pdf for 79 sporty ironhead!!!!
- 1977 ironhead starter problem
- Source for circuit breaker holders
- Plugs fouling
- What type of baffle is good?
- 67 exhaust help
- wiring blinkers and horn
- breather/breather tube
- '80 XLS Ironhead oil filter -- ID ???
- 67 speedo help
- Sporty Specialties 2 into 1 exhaust
- Mikuni VM38
- rear shocks
- Electronic Ignition
- Changing tranny fluid
- 75 sportster tail light on
- no spark
- New Mikuni
- '59 handlebar exchange
- 1972 XLCH - KIckstarter Help
- one more glitch in an old bike
- compression problems
- lowering my '79 / stored for 27 years
- 84 iron head rebuild project
- Primary and engine oil confusion
- voltage regulator
- any short people riding ironheads?
- slip ons
- Rocker Box Fitment
- Air cleaner compatibility
- my 77'
- some pics of my bike
- Best weld-on hardtail?
- '73 Sportster brake caliper
- carb problems??????????????????
- 75 XLCH rough, what's it worth?
- Timing cause Lean (Red glowing pipes)?
- eBay engine assembly stand
- oil out of vent tube
- Plug gap
- Front End I.D.
- saddle bags
- Zenith Carb with adjustable main jet
- Points
- Tenino Antique Motorcycle Swapmeet Aug 15 & 16
- The Endless Oil Debate
- buying a starter?
- '80 XLS Keihin Carburetor - Adjustable Idle jet?
- Cam gear noise.
- Oil Pump Assembly Queston--Pinion please weigh in.
- buying a generator
- Zenith/Bendix
- I need help...
- 1983 xls value
- Best Rim Polish?
- Ironhead valve stem seals???
- '80 XLS gas tank mounting question
- cv carb brace
- Help Need jet size "72 xl 1000 Super E
- Forward controls!!!!!!
- roadway873
- transmission
- cam timing problems
- 81 XL issues
- Timing Mark location
- Cylinder raping noise
- 79 Only firing one cylinder
- Springer front end
- 75 Ironhead wiring problem
- Kick Start
- Top End
- 82 I/H Sporty transmission
- Hydraulic Clutch 71' to 76' Sportsters
- 73 Ironhead starter problems please help!!!!
- checking timing
- Unstable Idle
- Oil Leak
- my 77'
- Suspension Sorted Out
- What's a good year for an Ironhead?
- poping through the carb
- 79 xls side cover
- Left side shift kit?
- Looking for a Ironhead
- flush mount rear blinkers???
- Ignition timing on '73 XLCH
- Charging System
- long springer
- Engine Proformace (10:1 compression)
- anyone got pics of bobber type ironheads on stock frames?
- Starter Relay
- Bike of the Week
- Generator
- '67 xlch kicker trouble
- Looking for a carb.... 1985
- no spark
- still no start video attached
- check timing
- wiring trouble
- 38mm bendix main jet size
- oil leak(pour)
- Jimbe's starter problem. Please help......
- NOOB with 71 Ironhead
- Running rough - now won't start
- clutch questions
- Hotrodkid's 1974 Restore
- Need some help 1971 Sportster
- whats the scoop?
- battery amps
- still wont crank over
- Just got my first Harley - '78 Ironhead
- Air filter
- 85 Ironhead
- Hickup between shift
- purpose of a diode on an ironhead????
- Sportster fits again!
- Home made clutch tools and tips?
- fuel line clearence
- not charging
- circuit breaker size
- First start of season
- oil is foamy
- Marker/Turn Signals
- Still wont crank
- help! Put tranny fluid in primary drive
- S&S carb
- my paint is done
- Locktite
- anyone figure out how to fix primary oil leak
- deleted post
- springer frontend?
- 23 Tooth Sprocket
- blowing oil out the exhaust..Help
- Just venting (pun intended)
- my 75 XLCH
- new controls vs old
- kick start
- 74 xlh starting (crankin motor) troubles
- 83 ironhead
- Rod Play
- sporster year?
- 77 Starting/timing problem? Has Fuel and Spark.
- '75 ironhead starting problem...
- clutch trouble
- lights go out
- re- wire 79 xls roadster
- got an 82 sporty for$750, needs tranny work
- H-D "PB" cams
- Ironhead oil issues
- VIN Check
- Primary sprockets
- right side shifter
- Tank Liner
- check valve
- HELP! Extremely hard starting 1977 Ironhead
- magneto info
- still building
- what can you tell me
- accelerator pump
- dependable sportster?
- Mikuni parts availability update......
- need some advice
- Piniongear and all the other smart ones ?
- Mikuni 38mm or S&S Super E
- Want to toss the points
- No ride for me today.....
- Electronic Conversion
- Mikuni Backing Plate........
- just got it
- 1970 XLCH Clutch and hot engine problem
- 83 sportster xlx ironhead
- The Starter soleniod saga continues!!!
- Wideglide Ironhead
- Primary Over Filled
- whats next part 2
- Noise when rev'ing in neutral:
- whats next
- tire size
- OEM Sportster Tires
- no more highway for me
- 76 build forward controls
- High oil pressure - oil tank
- Interesting add
- 1972 XLH Paint
- Starter wires crossed
- tires
- Crank vent?
- rear mount
- petcock clearance
- I-RUN head!
- what kind of oil in an ironhead
- I'm Back
- oil tank bypass
- 108 link chain
- S&S Super E or an older Mikuni???
- how long are your drag bars?
- super E question
- 73' ironhead oil pressure question
- Sportster Starter Question
- goin' freakin nuts!!!!
- broken timing bolt
- 83 sporty 1000 front sprocket leak
- noise from tranny
- mid controls
- high idle when hot
- 78 xlh carb....mikuni vm38????
- Third Gear is Gone...Any Ideas
- Hey ironheads
- Blinkers
- tires
- Stuff to trade
- Leaky Tappet Guide
- drivechain some questions
- 75 100CC Ironhead starting issue?
- 72 ironhead part wanted
- 1970 xlch
- 72 basket case
- Ironhead oiling
- disconnecting battary
- 1966 xlch w/chrome frame? Mag question also.
- 73 xlch on a 53 (ish) model K frame?
- Weld a gas tank
- quick question
- shorts and voltage reg.
- Ironhead sporty to electric
- 75 Ironhead...
- no spark/ condensor
- Lookin fer help with my 76 XLH ~
- moving right side shift
- Randy, haven't seen an update lately...
- winter project: rebuilding the ironhead with questions
- Leaking Tappet Guides
- Where to purchase gaskets?
