View Full Version : Softail Models
- Throttle/Idle Cable adjustment.
- Hog Deluxe - don't go there!
- Softail Slim: Fill 'er up!!!!
- 98 Heritage won't start after ape install
- FatBoy Seat on a Night Train
- Detatchable Saddlebag dimensions
- Hardware Refinishing
- Saddlebag guard bags on FLSTC
- bags and shotgun on a fatboy
- New to the SOFTAIL forum
- Heritage with Fairings Pics?
- LED mirror turn signals
- swingarm bag
- What Brand Spark Plugs Do You Like
- 1 1/2 year old Dunlop
- low fuel pressure
- NEED Apes! Need help piecing out parts..
- need info about 2000-2006 21'' wheel
- Freight Train Nacelle question...
- New guy here
- Another Samson convert
- changing spoke on harley wheel?
- Cholos and a swing arm bag?
- 96 softail springer idle concern
- New wheels for the FXST......goodbye 200 tire!
- how to clean the black wrinkle?
- 2002 Springer FLSTSC Headlight
- Help!! Blackline heartland 200 conversion
- (Pics) Tired Of Crappy Phone Pics...
- club style softail
- Help needed - brake ??
- Removing baffles from Samson True-Duels
- Primary offset kit
- Seat For Fatboy lo
- 09 Rocker Blowing Accessory Fuse after Speedo install
- Mystery Item
- Please help to choose Mustang seat
- Gone Soft!....
- Fuel Moto EfFI tuner on 07 deluxe
- Is it possible to get more length out of my factory forks?
- Loctite on Toppers?
- Alignment?
- front end difference
- New Guy, New to me Deluxe...
- New Paint!
- Bolt Covers/Toppers
- Garage Leathers Solo Bag, Custom 2" Tank Lift
- Jammed fuel injectors.What to do?
- Lets See Your Bone Stock Fat Boy !!
- Workshop / service manual
- Monotube question...
- 1 1/2" drag bars
- What's wrong with just replacing tensionersa with the same type?
- SPRINGER: Partial Burly Kit Install, is it possible?
- Need help - Rear wheel removal
- Where to get parts now?
- Motherwell Rack on Slim
- Jam Nut On Shocks
- Best Bags for a Fat boy Softail?
- Higher Floorboards on Fatboy Lo
- Anti-squel for brake pads?
- A few pics of my boing boing...
- rocker c
- Plasti-dipped Thunderstar on my Springer!!
- Just bought my first Harley LOTS OF QUESTIONS
- Help replacing pawl arm in 97 Fatboy...please...
- question about wheels
- My "new to me" softail
- Another first Harley thread.......
- Need Dual Pipes for Softail Deluxe
- Baffles for my cholos?
- Just thought winter was done..
- slip on
- Fat Boy to Ultra and back to Fatboy?
- Wiley-X CQC Goggles.
- Sissy Bar for 07' Custom
- What to do with the Fatty...
- D&D lowcat installed. LOTS of vibration... Anyone else?
- Need some Tech Help - '12 FXS
- Lets see you Breakout (CVO or Standard)
- 2009 Harley Davidson Fatboy with new Lepera Custom Seat
- drive belt.
- Rocker HHI conversion and wider 23" wheel
- 2012 fatboy rear fender
- Sticky shifter - oring question
- intake/heavy breather of 07 train
- tries to start just by turn of ignition
- Rocker c/ Breakout conversion
- Shotgun Shock alternative switches
- video of my 06 standard
- Is there more than one HD reflash?
- 6spd gearset in 5spd twin cam case...anyone do this?
- Okay I lied
- Opinions needed on f.i. To carb conversion
- O2 Sensor Adapters
- Laughlin River Run
- power vision tuner
- 95 Fatboy
- Braided Fuel Supply Line
- Small Fork Bag on Swingarm (pics)
- Windshield for FXSTC
- tire help please
- which cams for Breakout
- My Fatboy, what do ya think?
- Crossbones fender/seat options?
- 04 fxst starter sticking in?......
- Ignition
- Kuryakyn engine guard lights
- Rear Fender Struts question (00-05) narrow tire..
- Installing the 422's this weekend.
- FatBagger questions....
- Captain Itch
- tube stuck in the bottomed out position 05 night train
- A question about throw-over saddlebags
- What's wrong with my alarm?
- frwd control extensions
- 93 Softail back fires on dec. and cold blooded
- 98 Heritage 21" wheel?
- Question for the guys with Rolland sands vintage kit/solo seat
- Is There An Aftermarket Seat For The Breakout?
- wheel bearing on '10 Fatboy Lo
- Rear shock loose?
- Wheel fitment question, 1/4'' off center
- A little help with fork oil change on 02 fat boy.
- tach/speedo confusion
- Highway Bar Q&A
- V&H Big Shots too loud!
- help with a 21 inch wheel
- Forward controls on Fat Boy Lo
- 18x7 black bike rear wheel
- Sprocket question
- Need inspiration for my 10' Fat Boy - Pics needed!
- 2010 Softail & SE Compensator
- Who has a Breakout (CVO or Standard) with aftermarket pipes?
- over torqued my poly bushings help
- Tube size for Avon 120 x 70 x 21?
- custom mpg?
- Another Breakout Owner!
- 03 deuce wheel on 05 deluxe
- Oil Leak?
- Extended or folded Heel shifters....
- ABS Brake Line help!!!
- Tight fit
- Rough Starts
- springer rocker jam nuts get loctite?
- For Those Wanting An "Old School" Exhaust
- Helmet Shrinkage
- Supertrapp mean mothers
- 90/90 vs MH90 front? Duece tire Help
- simple green
- looking for a solo seat for my Heritage
- Searching for Owner
- SE204's: Which TTS Base Calibration?
- Fork boots on my Springer?
- Stiffing up Shotgun Shock
- 2006 Springer Rear Tire
- Vance & Hines fuel pack
- Shotgun shock on and se254 cams
- Deluxe's Tombstone Taillight Broken Again
- '10 Softail Deluxe / Samson True Duals BAFFLED / No Air Intake / Which Controller?
- Having Brake Light Issue -- Need HELP
- Installed D&D 2-1 LowCat on my Blackline
- Winter Mods done , First spring ride
- License Plat Relocation
- Custom Badge for front fender
- Blackline 16" Dukes Cables
- Samson Time!
- Better brakes
- 2000+ swing arm on a pre 2000 fatboy
- Would Deuce Quick Detach windshield fit on an FXST ?
- pullin the trigger?
- "Deluxe" Heritage finished for now - Thank You!
- Seat Thumbsrew nuts for seat on 08 Heritage
- Mpg?
- 2007 Softail Custom Vibration
- dielectric grease when changing plug wires???
- Winter mods finally finished on my Heritage!
- New Breakout with Saddle bags pics
- 2007 FXSTC Rear Master Cylinder Cover
- Breakout License Plate Options
- Question on Synthetic Oil I need answered right now
- Anyone knows what this is?
- Went Down for the First Time
- PCV with auto tune on a Rocker?
- smallest fender for a 21 - 120 tire
- FXST experts?? Please help!
- new license plate frame - whatcha think?
- Replacing FB front fender/matching HD paint
- Boom Windshield Install???
- Certain run/brake/turn combo possible?
- 2003 FXST Bags/Engine guard?
- tires for the deuce
- Stretched Tank question...
- Need quick answer - 08' Deluxe V&H pipes fit my 10' Fat Boy?
- New Fatboy Lo
- Black Chrome Hardware
- Custom Wheels
- Wannabe Yard Ornament
- clutch
- Trouble Adjusting Shocks
- King spoke wheel
- Factory Fatboy risers
- If You Were To Do It All Over Again?
- Blower, cycle dryer
- Chrome Lower Slider Assembly
- Deuce Facelift
- Metal slivers and small metal flakes in oil ?
- Does anyone know what this triple tree came off?
- looking for 68 tooth rear pulley
- Camshafts???
- mono tube question
- TC88 cam plate question
- Crossbones Passenger Pillion Options???
- Got me a new fatty!
- Pulled the trigger on a Deuce
- Question about the adjustable H-D side plates for sissy bar
- Sundowner on Fat Boy - Followup
- Rear Wheel Question.
- Fuelmoto build complete!!!
- Freight Train Nacelle Lamp Issue
- Springer Breakout???
- Breakout Mods...Apes Installed
- Flex Pipe Question
- Dash / Instruments must go
- Bell Rogue Helmet On Order.
- Rubber fork boots over cowbells???
- 2008 Deluxe leather saddlebags
- avon cobra or metzeler marathon?
- Front Master Cylinder ??s
- heritage triple clamp question
- Luggage/Bag for a detatchable sissy bar.
- Fort Lewis/JBLM, Tacoma riders?
- Blackline - Single use only Handlebar nut??
- 04 fatboy upgrade ???????s
- Hwy peg mounts with a mustache bar
- Todd's Strip Bars
- 2011 heritage abs light on all the time
- Clear Lenses + iridium bulb + brake module = Cool!
- Re-learning My Bike
- Who is going to Strokers Spring Fling in DFW
- Saw a Fat Boy Lo - What do you think?
- snortin back into carb
- May have screwed up. rear tire issue
- I need help with finding a passenger seat for slim!
- Crossbones Springer RISER thread size???
- FXST Tri-Bar LED Compatibility
- Harley Crossbones Ape Hanger Question
- Saddlebags - Deuce
- Mustang Seat, Viking Bags, and Great Bike Gear big review
- Headlight issue
