View Full Version : Softail Models
- Project Lo Blow
- Shifter linkage...
- adjustable rear floorboard brackets for 2008 softail heritage
- security system failure
- Just installed new Freedom performance Sharp curves on the Rocker
- Finally!!
- 2007 Softail Custom - Wood 555 CAMS, V&H BSS, Arlen Ness AC, PC III
- Help please! :) Flashing lights, no start...
- Fatboy lo black denim front fender
- Am I getting screwed?
- Need help with rear signals
- Who has the best deal on 21-3.0 rims now?
- Rocker C gone
- Loosing rear break
- Pics of my finished Crossbones....for now!
- I need an ape hanger supply list!
- Check engine light Help!
- Convert Evo solid motor mounts to rubber
- ***Wanted: Members to carry the Mascot further South....***
- Tire Pressure
- Progressive 2" drop kit HOW TO PICTORIAL
- k n air filter
- O-Rings for all three holes and Primary Cover Gasket
- just wanted to say thanks
- Need Clutch HELP ASAP
- Went for a ride and got fried thigh!
- 1996 heritage speedo problem
- What a fiasco
- Light module for Fatboy dash?
- Lowers and overheating?
- Best factory seat I have EVER sat on!
- 27 tooth compensating sprocket?
- Sundowner to Badlander (Deuce)
- Changing fork oil FXST
- Random misfire 06 deluxe?
- Solo Seat For Softail Deluxe
- '12 FatBoy rough riding.. Is there a fix ?
- American Side Road Cycles
- what tools do I need for changing all three fluids?
- Fyi, fork forks
- SS front brake line
- Crossbones Service Manual Question
- Tire mileage
- She's finally done! :)
- can I put a 23x3.5 on a custom softail?
- shotgun shock question???
- 2007 softail custom front wheel width??
- Santee apes
- what grease gun/fitting for springer?
- Swingarm Black Paint
- RWD rear fender
- Question about RSD 1 Inch Vintage Short Stack Handlebars
- Fat Boy floorboard upgrades?
- Lindby Linbar best price?
- Oil Fill
- Kuryakyn Airmaster Deluxe Fairing
- should of done this sooner
- Just had front row seat to a bad wreck
- Anyone try to install HD Dual Halogen headlamp (67700033)?
- Fatboy Seat Help
- Warrany question?
- Summer Road Trips
- Softail ABS brake line kit....
- My first Harley moment!
- Best tool for removal of boot marks on exhaust,
- Deuce died
- Crank positoning sensor
- Bag/Sissy bar question
- Heritage OEM Shield dimensions?
- How do i clean fatboy wheels?
- Apes on the Train With pics!
- SHe done for now.
- Popping on during decel
- Question about lowering
- Roll Bag over the Headlight ?
- New apes on my Lo
- Joe's Fork Bag Stereo
- Pushing the button on my rebuild...your thoughts please.
- Heat shields, or wrap?
- Duece Dash Removal
- Favorite Fat Boy Wheels
- Softail Slim Badge
- Who makes this horn? also RK Guards on a softail?
- Can't find a place for apparel (boots) so here goes
- What plugs and wires are you guys running?
- My 2011 Fatboy Lo conversion
- Fender LED lights?
- 2011 FXDC For 2005 Soft Tail Deluxe?
- Fuel Caps Vented? Non Vented?
- Lucas Synthetic Oil
- My new FLSTC may be totaled, how to tell ?
- Rear pulley swap?
- Please help!
- Stupid is what stupid does
- Info on Night Trains
- Front Brakes not releasing pressure
- New speedo problem
- Wow! Kuryakyn. What a bummer. Poor. Quality.
- Codes for deuce, voltage reg surge fried components
- DITY 1K Mile Service Experience
- Is this normal?
- Rocker C- what a mistake :-(
- New Heritage Classic
- 2011 Deluxe SE Exhaust Fitment
- Makeover updated
- a lil help with bags and guards if u please
- Shift / brake controls
- Opinion on Lowered Softail
- HD Detachable Sideplates and luggage rack with stock turn signals
- What size tire?
- Picked up my 2011 Fat Boy Lo
- Springers and RSD vintage bars/risers?
- 900+ mile ride this weekend
- Pushrod leaking oil
- Wheel Question???
- newbie sign in
- 2012 Blackline Question
- Speaker system for heritage
- Brake light hard to activate
- 2012 Fatboy turn signal relocation
- mva heads
- Need help asap
- Which year Deluxe is the one to have?
- 2006 Heritage speedo and turn signals
- Apes or no Apes that is the question
- New 2012 Soft Tail Heritage owner need advice on pipes
- I'm lost- did some mods, now P1352 code.
- 2002 Deuce seat
- thanks for the help
- 05 FXSTI -- In desperate need of the POTATO
- will shocks from '05 softail fit '96 ?
- 2012 Slim exhaust???
- 1992 Heritage FLSTC starter issue
- Cleaning Chrome Exhaust?
- Andrews 21G or 26G for Fatoy
- True value
- '95 STC front brake line replacement...any tricks?
- wheel axles - I want to change my bike to 1 inch axles
- Springer out of action :(
- Help with tire size please.
- Starting Pause
- fatboy project UPDATE
- Fat Boy axle size?
- Help, burnt ignition wiring
- New owner, didn't even get a chance to ride...
- stock exaust sounds weak
- Right Side Chrome Tool Box for 07 Fatboy
- Seat swap 97 FXSTC
- Best Sissy Bar, Luggage Rack combo for Softail
- RI bike and car show pics
- Trying to Move On... 2006?
- looking at Programmers, need some help...
- 2004 Fatboy won't stay running
- props to ultracool.....
- Fuel line inside tank....
- engine/battery lights on
- Vicla Extended Hardbags on Softail
- Longer seat bolts?
- SE Hyd Cam Support plate/Oil Pump question
- info FLSTC
- Balancer noise
- Dash fogged
- Sirius radio and scale rider 4 or 9 help
- blackish residue?
- Speedo/Tach combo 70900070 for 2008 Fatboy
- Pictures from Biketime
- Blew lights on Heritage - need help!!!
- Stalling with V&H Fuelpak on 2012 Fat Boy Lo
- UGH!!! One step forward, Two steps back...
- Loose Spokes Heritage Classic
- Running lean.....
- Fat Boy Lo Console
- springer problems
- Rush Baffles
- Headlight Issue
- Wow, did I guess wrong. Cut or sell?
- Gutteral Sound
- Just realized. Harley ain't too userfriendly.
- tail light problem
- Crossbones True Duals?
- oil blew out-- ideas?
- road king wheel on a 09 heritage
- 05 Deuce Pipes and Air Cleaner
- slim windshield
- DIY- Learn something
- what shocks are on my deuce?
- it's already started
- Trouble Codes on a 2011
- 2011 FB Lo Signal lights Flashing...
- Samson true duals install help
- Easy cam question, I think
- Halo rIng on a crossbones
- Finally a decent shot - NJ Softail
- HD Boom stereo cracking windshield?
- Backrest for 12' Heritage
- Mod Help
- Fatboy for two up riding
- 2012 2 into 1 exhaust question
- Pics from the Smokeout Rally 2012
- Batwings
- Let's talk Solo Seats
- What's in your side swing arm saddle bag?
- Lowering Kit On Sale
- Fat Boy Lo with V&H 2-into-1 and H-D detachable bags
- 1997 H.D. Springer - $5700 Good deal?
- Stock Mini Apes (rolling them forward?)
- What's My Next Mod? Under $500
- Stretch Armstrong......not really.....front fender ?????
- New Pipes for my '03
- Todds Cycle Moto Bar on Blackline?
- Forward controls?
- T-bars on a slim
- Calling all 08 FXSTC riders
- Blank black switch caps?
- Hardbag mounting to a softail - questions
- PIcs Different Bar Choices for WideGlide fronts (no Apes , no Drags). !
- My wife's new Slim
- Speedo Replacement Question
- apehanger fairing
- K & N intake
- FXSTC seat on a FXST
- reverse options in 2005 heritage softail 1450cc
- New FXSTC:
- Boot marks on exhaust
- 95" kits
- 2000 Softail Springer License plate mount
- talk about a blow-out!
- blackline triple trees replacement
- PC equip. As a stock part on 04 night train?
- brake fluid vs. paint
- Tank Slapping Type Steering Oscillation
- 05 Heritage Springer, Turn Signals
- Oil cooler with fan or no fan
- anybody with progressive 422's
- V&H Fuel Manager
- 5 micron vs 10 micron oil filters....
- Wiring a sportster pump to my softail???
- Parts Complaint
- Tool kit on a 98 Heritage?
- Best service/repair manual?
- solo bag mount?
- Stator/Regulator Replacement 2000 Heritage Classic
- Side mounted license plate (which side?l
- Dyna wheel on FXST?
- What Cams You Running?
- RayBay
- Cycle Parts For Less
- Cold Blooded!
