View Full Version : Softail Models
- Front brake improvement?
- LRS 19" Review (Heritage)
- Crossbones riders
- Whats the cost of JUST doing cams on an EFI bike?
- Cleanup after oil change
- Extended Cables Help
- *&^%$#@ intermittent problem!
- 03 deuce apes and the questions that come with
- Really want a saddle bag, side mount or handle bar
- Lowering a Softail, drive me crazy!
- rifle cruiser fairing
- TW-555 kit (with pushrods), V&H Bigshots Staggered, Arlen Ness Big Sucker and PCIII
- American Iron and my bike
- fuel light stays on
- Sissy bar cushion removal
- Buffalo Apes 16"x1 1/2"!!
- Crossbones seat
- Q on Rocker C
- handlebar advice?
- Anyone know where to get these?
- My First HD was it worth what I paid??? What you all think? PICS Included
- vinyl seat recovering????
- Gas Cap Rattle?
- My 04 Deuce rebuild....
- Help Whistling noise and I dont know 1994 Softail Custom
- Carb Issue?
- luggage rack removal takes the passenger pill mount with it?
- Road Glide wheels for my 09 Fatboy
- WTK 2003 Heritage short rear signal bar. Wiring cut?
- Check engine light
- Seat Change 05 to 95?
- help with Harley purchase.
- Blackline seat
- fatboy efi high idle when warm
- Buying new tires for my Custom
- Stage One + Power Commander question
- Move from Sportster to Deluxe
- about stuff
- Need Help Finding Finder Trim & Rails
- Happy 4th of July
- Free pipes!!
- Something happened.... weird
- Carlini Evil Apes on Rocker
- So if I had all the money....
- 88 or 95
- Throttle Body Disassembly
- Mustang solo seat for 2012 Fatboy
- Heritage springer saddlebag guards on '11 Deluxe
- need some help with coil, and module
- need some advice
- Need Some Opinions before I go too crazy with powder coating
- 2-1-2 exhaust for heritage
- Connecting xbone to CVO SG Tail light, help!
- Key Light Stayed On
- Sticky clutch cable
- RB Racing LSR 2-1 exhaust
- 36" Samson baffled long tails, stuck with them
- 2006 FXSTSI with 3800 miles!
- Updates pics of the 95 Heritage Nostalgia
- Let's see those Beach and Bikini Bars
- bike wont start
- ECM Question
- 40mph wobble
- Turn signal auto cancel
- Softail Nacelle, Black???
- Gasoline Shelf Life
- Few rolling shots
- Inexpensive foward controls
- softail deluxe
- 2008 Crossbones gas tank?
- What would you do? Im out of ideas
- SE 204 Cams just released?
- Nacelle Install Tips
- Deluxe brake cylinder issues!??
- Loose spokes
- Higher Octane gas cause problems
- Need new rotors, have Ride Wright Twista spoke wheels
- Rear Turn Signal Stays On & Won't Blink. Any Suggestions?
- Shock adjustment
- VALLEY Ride --PICs--
- Little help? Brake rotor tq values for my fatty.
- Thunderheader Exhaust on 88
- Oil cooler with fan for ABS equipped?
- Visor trim ring
- 68000042 Custom Auxiliary Lighting Kit
- heat makes bike run bad
- Help with Identifing this custom softail
- whats the little hole on my front brake fluid reservior for?
- Mounting front turn signals on forks (relocation for 2007 FXSTC)
- Night Train fender kit/sissy bar help
- I Pulled the Trigger!
- New LePera seat...does this look right?
- Tranny dipstick ?
- super tuner software
- Softail Slim now sounds like a Harley!
- 2012 Fatboy Problem
- Night train help..
- What would you do first?
- Adjure Blue Dot?
- What oil to run in Fatboy?
- Need Deluxe with ProPipe pics
- Rear brake caliper
- Someone here put Michelin Commander 2 on a Fat Boy ?
- HOW TO: Xbones To FLSTS/SC Front Fender Swap
- Mikuni 42
- Kickstand came off on road - what am I missing?
- combination sissy bar/passenger pillion?
- Wife is sensitive to noise.
- Got The New Fat Boy Done
- thunderstar wheels
- Will a 99 Fatboy tank fit an 04 Fatboy?
- Reinstalling Front Wheel..
- A few basic questions to get more performance and more volume!
- torx head size for the timing cover
- Cooked Headlight Wiring Harness. Replacement??
- steering head nut ?
- Re-sized Z-Bars for that custom feel.
- Need Big Help
- Need some help
- Need some quick help with exhaust, fuelpak and a/c
- Ruined drive belt !
- can anyone answer
- Passenger Pillion Remove & Replace Solution
- Nacelle with 18" Wheel?
- Starting my Ape install on the XBones!
- Help Fender Question
- Rocker help
- my fatboy project
- Corbin Seat Q
- Chrome & black textured part care.
- Fuel tank range?
- Ape size......
- absolute best stereo for softails ?
- Tall riser's or pullback riser's mounted backwards ANYONE???
- 99 FXSTB intermittent starting issues
- installed big bore baffle SWEET........
- burning out bulbs
- 04 Heritage efi tin removal
- Growling & Ticking ( Help!)
- clutch adjustment
- Air cleaner question
- Comedy
- Moisture inside speedo
- Whats the best for an older softail?
- Seat question?
- Night Train question...
- -Bad-Tire . New-Tire . >PICS<
- Updateing the new bike - running too hot
- primary leaks and vibrate's
- Smoked a 600 crotch rocket
- True Duals on a 94 heritage
- Woot First Road Trip Of The Year!
- Anyone install an aux lighting kit on a 2012 Slim yet?
- help for a new rider
- Dry Rear Master cyl
- 12 Slim Idle Management??
- Barnett scorpion under cover lockup clutch
- Big Bore Kits - 103, 107, 110...
- Could it be the heat ?
- 90+ degrees outside and now pinging
- pain from drag bars possibly switching to apes
- let's see some sleds w/18" fronts!
- Need help with D&D fatcat for Fatboy
- primary cover leak
- 2011 Balckline
- Darn it, did I guess wrong with my bars?
- 2007 FLSTC - Heat shields on stock mufflers?
- New Harley = New Tools
- Handlebar bolts
- softailloweringkit.com
- Changing to 30T and 70T pulley?
- Will this power commander fit?
- Intake manifold removal
- Where to start & saying hello.
- Downtube diameter
- Coil relocation Softail Cross Bones
- FatBoy ???
- Front Pulley on 08 Custom
- 18" or 21" SMOOTH rim?
- Signals aren't self canceling...
- Sneak Peek of the Next Mods to the Train *PICS*
- Bikini beach bars on a heritage
- Ok, another shotgun thread.
- Throttle not always returning to idle
- What pipes are these??
- Slouched on Fatboy
- Detachable Drivers Backrest
- PM brakes installed on a Springer! *PICS!*
- flush mount gas caps
- hot engine
- Dying Heritage
- Crossbone seat questions
- Getting pissy waiting for my apes, installed bikini bars...
- Signature Series Seat with Rider Backrest
- Staying Fat...For Now
- Blackline sissy bar mod
- Carlini Evil Apes... Opinion?
- Demon Cycles?
- New Cobras...wooo!
- Handle Bars
- first bike, advice
- blinker issues
- Primary leak?
- Security system
- New Bullet Turn Signals on My Fatboy
- Brakes rubbing/grinding
- FENDER MOUNT passenger seat backrest?
- Woohoo I'me getting an open primary
- 10" Strip bars, need new cables?
- Wheels on a Deluxe
- 2010 Front Brake Failure
- Airdrie Auto Werks: Custom Bikes & Mods.
- SE204 cams do i need spacer kit?
- Little ape
- Auxiliary Light Question...
- Custom Fender
- Changed seats, still hurting..
- 2011 Softail Factory Service Manual For Sale
- Advice Needed -
- Shift Lever
- Chrome tail light covers
- primary level question
- solo tour pack rack
- Strutless Rear Fender for 200mm Bikes?
- oil line in to oil leak.....
- Replacing Starter
- Looking for a new seat
- PLEASE HELP!!!! no left turn signal! 96 FXSTSB bad boy
- Rear Fender Help
- are the Deluxe Pillion seat comfortable?
- 16 Carlini Flying Apes cable length?
- new swing arm bag
- Buky bars
- Fatboy????
- Shocks only
- 2007 Heritage Softail won't run.
- twin cam 88
- How Long Do Your Aux Light Bulbs Last
- A Crucial Queestion for You Guys. Big descision.
- 09 Softail Custom oil filter question
- 110th Anniversary Models
- gas cap
- HS wheels
- So CA-Riverside Bike Show
- 07 Deluxe shuts down
- Bike Starts When Ignition Switch Is In Accessory Position
- help me please
- FATBOY Low with RSD Tracker rear Fender
- Long fishtails?
- Long time lurker - Hello all
