View Full Version : Softail Models
- Long fishtails?
- Long time lurker - Hello all
- Harley's 5 Spoke Vapor Wheels
- Feuling, Andrews, or Crane?????
- hi, hope you all are doing ok!
- 2011 heritage lowering kit questions?
- Oil Leak Shift Shaft?
- Powercommander
- Visit to Harley dealer in Australia
- Clear Wheel! WTH??
- up and down type wobble
- Some noises coming from my engine
- headlight switch
- A Mod Screw UP, Maybe Not....Your Thoughts?
- FatBoy Lo vs. Softail Deluxe
- fxst front end leaking oil help
- engine vibration
- HD Swingarm Bag on 06 Deluxe
- Where to start chroming? First 3 pieces...
- Springer saddle bag guards
- Moving a fob to another bike?
- Am I the only one?
- -New-Grips & here's a >PIC<
- Heritage Extreme?
- need some help!
- Fair price for 08' softail deluxe
- # 1000 and more!
- 1985 FXST, No Neutral light/Won't start..HELP
- Happy Belated Mothers Day!
- 2012 Fatboy
- 02 fxst starter has a mind of its own- help
- 2012 fatboy lo trany problems
- Need definitive answer on spark plugs
- Black Pharoah's new ride, Blackbird! He's Baaaaccckkkkk!!!
- Anyone at the classic show in Frenchtown, PA right now
- best riding shades for the price
- Which exhaust is quieter?
- 2011 BCM codes?
- Blackline oil tank cap size?
- Rear Brake Caliper Removal Question
- Problem w/ Hand Controls on Evil Ape Swap
- Back from a long ride...
- As promised, 09 Fatboy with Cutom 18" Whitewalls
- Front seat for 2006 FLSTNI
- Anyone in the market for a cheap Night Train?
- Rigid Mounted Seat on my Train??
- Lower the front on '11 FB?
- 2007 Heritage Softail Fender Question
- I just want a simple "GO" or "NO GO" for pinstriping my sled.
- 2009 Fatboy Security package
- Solo seat recommendations
- acid dipping tank
- Powder coating In the Nyc or Westchester area?
- 36" Cholos on the night train !!
- new from Utah
- Risers for Deluxe?
- DMV driving test (California)
- Blackline / Todd's Cycle Strip Bars, anyone got'em?
- new to me 09 Heritage
- Rear axle wrench size needed?
- 2005 softail deluxe?
- Stupid question......
- New softail 2013 model "CVO Softail Breakout"...others.
- Detailing details...
- Not sure what to...
- Push Rod Tube leaking?
- Best product to clean whitewalls anyone?
- 23" whitewall
- Throttle by Wire
- Overheating issues, need your expertise please!!
- Apes on a fatbob
- Avon venom 21 ww
- Softail frames
- ProStreet Softail w/ Passenger Seat
- Best Way To Black Out Chrome Parts (Besides PC)
- 2011 Blackline "split drag bars" on an 07 Train?
- Sunmax 8.2 MM wires
- Passenger Comfort
- Gun lock for helmet?
- Help Me Understand the Entire Exhaust System
- Russ Wernimont Rear Cruiser Fender Finally On!!!
- 09 Fatboy floorboards and controls, what are they worth?
- Why is my bike dead?
- Almost done.....
- screamin eagle deuce seat
- What's next?
- My Softail Build
- Springer Risers
- 1994 flstn fender trim rails
- exhaust
- This girl is bike dumb!fuse location
- softail rocker 21'' front wheel ?
- New Member/Custom Softail Build
- Sprocket bolts
- Removed baffles from screaming eagle II slip ons
- Big tip for you
- Just ordered my ultracool oil cooler
- added Carlini Pist apes and a nacelle to my fatboy
- HELP !! me find the problem
- '08 Night Train hard starting after tank swap
- FYI on Saddlemen SaddleHyde Renegade Deluxe Solo and Pillion Pad
- Samson 33" Tru-Dual Fishtail Exhaust
- Hub widht? Spacer width? Fork width?
- Need More Performance
- Removing Stock Exhaust
- What is this part called? Heritage Springer Front Fender...
- Swithback lighting
- Moving FLSTC floorboards forward
- Plug wires
- Night Train Rake?
- Timer cover just like this...
- 05 Heritage Softail
- Matching Fender Bib for '12 Heritage Classic
- Dakota Digital Speedo
- Forward control extensions for Night Train
- Removing stock baffles on 12 blackline
- '09 FLSTSB bad MPG
- What f'n weight is type e fork oil???
- 07 Softail just started to run sluggish
- Ready to Stretch Fender(s), Ideas, Help and Pics?
- Stage I Down Load
- Blacking out the dash....
- 06 fatboy paint
- Just bought a custom fatboy with no speedometer
- HELP! Tilt or Tip Switch?
- I'm so freakin stupid.
- modifying factory risers for apes... need opinons
- Bike is sick - Kinda freaking out!
- side plates?
- Fatboy will not stay started
- Avon gangster or diamond back?
- 21"/18" DNA Mammoths on the Lo.......
- Engin guard on a fatboy pics? How much? Which one? Looks good?
- Bad Tank slap
- 10k Service
- Im looking for suggestion on Ape vendors @ Sturigs Rally
- Cleaning front tire
- Starting Issues
- Right Side Swingarm bag
- Custom hog from Renegade (the tv-show)
- softail primary help...
- oil change mistake
- no sparky to my plugy
- Missed the Ole Girl
- Ape hanger and cable question
- 06 FXSTB question
- Fender bib
- My Blackline / New to the board
- Fatcat bigbore baffle ???????
- I blame JIMSFBL for learning how to paint!
- Help with EPA Can????
- 98 Heritage, turn signal acting weird...what I found.
- Rear Fender Dented
- dual disk on a Heritage softail classic
- FLSTC Luggage Rack
- Which Softail?
- Fatboy highway pegs?
- Switching out my Crossbones front fender to a Heritage
- Back wheel..... solid...
- my deluxe
- Tank reads empty...
- Long-time reader; First-time Owner
- 07 FXSTC - Does the spoke front tire need a tube and liner?
- Seat choices
- FLSTN 2011 Back brake caliper
- Customizing a Heritage
- Tire reccomendation: 06-FLSTCI
- Exhaust for 2012 FatboyLo 103
- ECM password learn HELP
- More light on my Deuce?
- 07 rear bearing application, help me out!
- 210 tire on a fat boy low
- Experiance with Burly Brand apes?
- 23" front wheel on a heritage softail
- got some gas caps and headbolt bridge for dads day
- Replacement headlight for fatboy
- Anyone looking to get Led lights w/15% off
- ECM Relocation Pics Please
- Will passing lights from a road king fit on a fatboy?
- Break Lights Not Coming On
- Hacker Warheader 2 into 1
- Steering Head Bearings
- Break Lights Stay On (Help!!!!)
- Softail Slim with V&H Short Shots pics?
- givi top case
- Tank Badges-Finally On!
- Deluxe Seat Q
- Chain alignment issues, 98 softail with 6 speed trans
- Buy American and true customer service :)
- SE-204 Cam ?
- Best tuner on the Market
- Back from Laconia!!! Awesome except for my rocker...
- Can primed bags be canned?
- Confused about parts
- Happy fathers day
- Contaminated Fuel Tank
- Toolbag
- kuraykn phantom axle covers
- Like um WIDE
- ?? Single Best Mod ??
- softail problems
- New Mini-Floorboards + Kit
- PCIII help needed.
- Left Turn Signal Issue
- Poor OS Deluxe! LMAO....Funny Shit.
- My pristine bike ain't pristine any more....
- Looking to buy a Rocker
- Looking for a bullet fairing
- Customizing an older Heritage
- buy fairing from dealer?
- HD Kit 56364-02 for an 07 Deluxe?
- Electrical Question.
- 2008 heritage NO SPARKY
- Finally got all the "winter" mods completely ~PICS~
- New Stock Speedo (MPH) off 2010 Heritage
- New Solo Slim Seat on My Blackline
- Visit The General Discussion Much?
- Crossbones / Fat Boy Fender Conversion
- Docking Hardware Install Problem (for detachable sissy bar) 07' Softail Custom
- Any differences in cables?
- 2012 Fat Boy impressions
- Does lowering effect the ride?
- New Fat Boy Softail Prices
- I'm in love 2 up seat!!! where do i get it?
- Front master cylinder cover
- samson sidewinders?
- electrial short to frame HELP
- Looking for this
- DB Tires
- 04 FXSTI gas tank removal
- Danny gray solo seat
- Axle Or Lay It Down?
- 02' Fatboy - how many miles till you hit the reserve
- Tires???
- sheet metal
- FXS Blackline 200 Tire
- Relocated Coil = Higher Temps?
- Heritage passenger back rest -smaller?
- Night Train with 16" Apes Cable/Brake Line Length?
- No headlight
- Turn Signal Module Question.
- oil/grease on pipes
- A true chrome whore Fatboy for sale
- Deluxe
- Who's got a 26"?
- Updated Deluxe with Apes and Samsons....(pics)
- Solo Seat riders
- helmet
