View Full Version : Softail Models
- 08 FXSTC Ignition Fuse Blows
- Fuel Leak
- Alternative way to retain the speedometer in console? Missing retention ring
- Passenger exhaust guard
- 03 Heritage Carb to ESPFI
- where's the screw to ajust headlight
- Lift Point
- ‘13 slim codes
- 68t pulley mod for 08 night train 20mm belt
- Please help - rear fender bag fitment
- Is it possible to fit saddlebag supports AND quick detach hardware
- Help with fitment cross-reference - 2005 Fatboy SE 16 ga Double Barrel on a 2006 Night Train
- Handlebar switch problems '02 softail
- 2012 Deluxe slight wobble at 85+
- The 2006 Night Train Resurrection thread
- Am I Missing Something?!?!
- Cable lengths for '13 Breakout
- Softail fuel pumps and year interchanges
- Looking for bracket
- What brand is this master cylinder
- need advise
- Front end whacked
- S&S 509/510 vs Andrews 21/26
- 2003 softail standard right signals blinking on its own
- Clutch basket fatboy Lo damaged, can it do any harm?
- Fat Boy Rim question
- Transmission question
- 160/60R18 whitewall
- Heritage Softail mini apes
- Help with new-to-me 2006 Night Train (bringing it back from the dead)
- Best cornering softail
- 110ci CVO engine fitted on my Breakout :)
- Does anyone know which wire is my ignition wire for my 08 Harley Rocker
- Question about the use of Battery Tenders
- Quiet exhaust wanted for '07 Fatboy
- Another Stupid shock adj question
- Bobtail fender width
- Rdw-92/61-0067
- 2006 harley deluxe
- Question without an answer? Desperately needing help!
- Buy headlight bullet but great quality
- What is this capped plug?
- 2K mile 2014 Heritage 103 problem for new owner
- 2007 Softail Springer Classic Passing Lit Kit
- A very strange issue and solution
- Stripped Transmission oil drain
- Rear Wheel Size
- Fatboy torx bolt size
- 1988 Softail Ignition Issues
- Seat with lower back support for 2020 FLSL
- Rear lift for slim s
- FatBoy Solid Rims
- Changing Rocker Box Gaskets, etc...
- Is my swingarm powder coated or painted?
- Dakota Digital Gauge Issues - 2003 Deuce
- Rear fender question
- Value on my HD
- Mustang Driver backrest fell off @80mph
- Normal tank on earlier breakout
- Heated Grip Interconnect (206)
- 07 Fat Boy Head light
- Please help
- Right side blinkers
- Better Brakes
- Stock Deluxe Handlebar Dimensions.
- Memphis Shades Windshield Width
- Gas leak
- 2006 deluxe with 5k miles issue
- Tire and wheel question for my heritage springer
- Question on exhaust
- Mini Apes on 2012 Deluxe
- 8” rise T-bars question
- Problems with new bars
- Airbrushed Fat Boy Brings Back One Old Trend
- Long Rear Fender
- FXFB mid control inner primary
- Looking for opinion
- Anyone know what handlebars these are?
- A/C backing plates- pre vs post 07??
- External VS Internal breather system
- Fatboy Spoke Wheel Question
- Dashcam on a softail?
- shotgun shock question
- 2006 Night Train - need opinions
- crippled
- Fork Twist?
- Older style canted handlebar clamp
- 2018 and up FXBB Springer front end?
- 2009 FXSTC, need new handlebar bushing and riser extensions
- Best Alignment Method for me
- Softail Frame question
- 2009 softail problem.
- 2005 Fatboy Anniversary Edition cam chain tensioners
- 8000 miles new tire?
- New to me 88b PMCS
- 2004 Softail Deuce is lifeless
- Shaw Speed's Nescafe Racer Harley-Davidson Softail
- Batwing fairing for softail deluxe
- Help with 2001 Fat Boy Vent instal.
- 2000 88 heritage soft tail
- front axle and rotor torque specs
- Rear shocks
- Softail seat
- Battery & Warning lights on
- Anyone know how to install siren on 2018 Fatboy ??
- Spring seat on 1996 Heritage
- Fault Code B2262
- Pls Help!!! Slim S Paint
- Warped front rotor replacement...
- Seat bracket
- Does the nissin brake caliper from a fat boy ‘15 fits on a’ 10 fat boy lo?
- 2008 Softail Custom
- Brake light stays on
- Late 90's softail - buying advice pls
- HD heated grip install on '16 Deluxe
- rear caliper mounting bracket 2008 Crossbones
- Batwing fairing
- 2019 FXDR Mirror Relocator
- Shorter shifting arm/Softail Heritage Classic
- What replaces Digital Tech
- My new projekt
- Slim S Spring seat
- To clean a K & N air filter ?? for free.
- 05 Night Train runs rough
- 2008 rocker c
- 2000 Fatboy Forward Controls
- Will these wheels work on my 95?
- Factory Paint
- Risers and bushings DIY
- Getting desperate
- So, this Springer followed me home...
- Handlebars Upgrade
- For Those That Have Saggy Bag Kit Installed, Longevity Question
- Forks fluid change
- Need tires
- 06 Deluxe handling issue
- Best pull back riser for my 07 Heritage
- harley horn covers
- Pic heavy,,,cleaning her up and handlebar ideas.
- Wobble on my springer
- ISO Hard Bags for '16 Heritage.
- 1995 Harley Softail Carb issues?
- Softer Seat Springs
- Need a favor from a TC88 Deluxe owner
- 2015 Softail Deluxe - 18" or 21" windshield?
- Fl Springer alternate risers
- I joined the Softail family today!!!!!
- Rocker c wheels
- Decode EVO Engine Number?
- Fatboy won’t start
- how to check a 1999 flstc frame neck for straightness
- Brake Dysfunction
- Rocker max front tire size
- What's a fair price for this 2015 Softail Deluxe?
- Anyone know the terminology for these handlebars?
- Can you please identify this seat?
- '96 Fatboy Losing Power
- 2003 FXST Duce how do I time the oil pump 88 CU IN
- 08 night train MX bars
- Help Relocation 2017 Front Turn Signal FBoy
- 2006 FatBoy Vibrations.. Motor mount Locations??
- Starting Issue Fix
- Speedo relocation
- What would you all do in this situation?
- Another seat thread
- Need help identifying this style of shock
- Installing progressive 422 shocks on 2014 heritage softail
- Push Start
- 2003 Heritage Exhaust
- What is this??
- Hard to start when warm?
- Starter Noise
- Pics of Panhead style rocker box cover on softail
- Need mounting brackets for oem chin spoiler
- 2004 Heritage Softail Classic - Miles to go / Fuel light
- Breakout swingarm
- RPMs Rises as Bike Idles
- Rocker steering head loose
- 2006 Fatboy V&H big shots staggered Vibration help
- Wheel hub
- Ques about shock adjustment
- Z bars. Post em up
- Exhaust leak fixed, still a problem.
- Found my perfect wind screen
- Bike won't run after fixed exhaust leak
- Apes or not
- Springer on fatboy
- 2003 Night Train Told to Lighten Up
- VH too loud for CA
- Breakout burleigh bars question?
- Tail Lights Change and Tag Relocation
- Short softail rider seat upgrade, Milwaukee 8 Breakout Sundowner or Solo Reach seat for a short guy
- 95ci to ?
- Not the usual blinker relocation question
- Float Bowl Accelerator Jet Test
- Question about hoses at carb
- Question
- Won’t start after tipover
- Softail Standard with or without a windshield
- How doable is stage 2 for above average wrencher?
- 2017 heritage running light install ( help)
- Antique tires for crossbones
- Weird sound
- Love Jugs Are Amazing
- Shift shaft free play at the rear shift lever
- does anyone know the thread size for this hole?
- Big City Thunder baffles
- Gear change issues
- 2017 FXSB electric wiring
- 2008 Heritage clutch cable routing
- Difference in Fatboy and Fatboy Lo suspensions
- Shotgun Shock let me down this weekend
- Maybe selling my 1995 FatBoy?
- 2008 fatboy rear brake disk colour change
- Change from "football" style air cleaner?
- 2004 harley davidson night train
- Deluxe FLDE 2019 APE
- Considering '09 Fat Boy Purchase and Need Advice
- engine guard for 09 FXSTC
- Heritage aftermarket Bags survey
- 2008 FLSTSB on the way
- Softail vs Dyna - Purchase Decision
- Heritage Front end question
- Need Dynojet Powervision map for S&S 110” kit for FatBoy 2016 model
- Changing rear brake line
- Advice needed please 96 Springer
- can i swap 2007 softail deluxe and heritage seat
- '04 NT 44k miles. Pics for ya'all
- Show your Corbin Fast Gunfighters
- Red Key light indicator on...and i did search around
- A $500,000 Fatboy
- 2015 breakout wont start on kick stand
- 2020 Low Rider S with Bassani Radial Sweepers
- Biggest engine in a Softail......
- Run, turn, brake light issues and others
- New tires for Slim
- Foaming oil 07 softail fxstc
- Neighbor Haters now even better
- 2003 Deuce Check Valve and Fuel Line Leak
- 1996 Heritage
- Arlen Ness BBK
- Vance & Hines Big Radius vs. HD stock exhaust - preference?
- Corbin vs C&C
- 422 shock
- Hard bag conversion
- Help ! P1009 code and my bike won’t start !
- Shutdown switch
- Pulled the red & white tins on my Deluxe
- 94 fatboy gas caps
