View Full Version : Softail Models
- Vance and hines short shots bracket
- FXBB floor boards
- Cross Bones VS Bad Boy
- Narrower ape suggestions
- Ape Hangers...
- S @ S jett setting
- FatBoy/ Softail Calsci screens
- Risers for 2013 FB Lo 1.5" bars
- 2010 Fatboy lo Interchangeable parts?
- Softail Rocker owners with stock seat... need pics
- Windshield Identifcation Help
- Help: Decision to make
- Why am I running out og clutch cable adjustment?
- cyclesmiths horn
- Fat Forty Spokes - Post Em Up
- Nasty Hog Softail CVO rear end kit. 2018 Heritage Silver Fortune.
- 2007 HD softail springer custom charging problems
- Bobtail fenders 7in lighting options
- Question
- Need help with cable length
- 07 FXSTB front wheel upgrade
- Shutdown
- 19 x 2.75 wheel versus 19 x 3.5 front wheel
- Just showing off.
- Need suggestions.
- RK Classic Bags on a Heritage
- Handlebars, (Beating a dead horse)
- 103 stage 4 race kit spark advance map
- Pingle Fuel Petcock
- Traded in my Deuce CVO
- Not charging
- 2016 softail slim s mirrors
- Headlight Recs for a 92' Softail Custom
- Colony chrome pulley bolts?
- Wind splitter install
- Just to be sure Primary Fluid 2006 Deluxe
- Baker Kicker Kit / Stock Exhaust fitment on '95 Heritage FLSTC
- New seat
- I need to move my passenger footrests fwd........
- Quick Release Hardbags?
- Tire Size Question - 18x4.25 Wheel
- New bars installed on 2012 Fatboy
- Question About Springer Front Fork
- Budget Heartland EZ200 kit
- Bike burbs when cruising
- Wind Buffeting...I'm at a loss
- CVO Deluxe Mufflers
- Fartboy Rear Wheels
- Crossbones Dyno results, build lists, and pictures.
- Finally installed my saddle bags...I had to make my own brackets!
- Did I buy a touring brake pedal?
- SE Ratchet Air Cleaner Cover - 08 FSXTB
- Deluxe with Blackwalls
- Looking to do some improvements to the Heritage would like opinons
- 2007 Softail
- I'm back on a softail
- 2007 Train with Low oil pressure, why?
- Engine Swap
- FXBB 21" front wheel?
- 88 B Motor Upgrade 2001 Fatboy
- Primary whirling noise
- NEED HELP,venting,not sure what i have/need
- Lowering the front of a DELUXE beyond 2 inches.
- want bigger gass tank 2020 breakout
- 07 Night Train handle bar cable help!
- Saddlebag Question
- Big Radius 2 into 2 Exhaust
- What brand is this saddlebag locking detach
- 2007 softail springer clutch hub issues
- 2000 deuce
- I am searching this air filter
- 2016 Slim sissy bar w/integrated rack
- Flame stamped fuel tank
- 2015 Breakout info
- 03 FATBOY male end of check valve o-ring size
- Deluxe with Fatboy wheels
- Tank dash
- Softail starter switch spring missing
- Replace chrome Fatboy wheels with black powder coated ones?
- 92 fxst carb priming?
- Barn Find?
- Help finding possible fuel pressure leak
- What size axle does the 2013 Breakout have ?
- Quiet exhaust for Heritage
- Rocker Locker Question
- C Clip size
- Softail handle bars
- Air intake after slip ons installed
- Battery
- mirrors, mirrors, mirrors
- Headlight and spot ,turn signal wiring
- Taillight/brakelight/turn signal issue
- Question on installing H-D Detachable saddlebags
- 103ci big bore
- 2012 FLSTF Fork issues
- Installing Heated Grips on ‘17 Heritage
- So Oregon Hotbikes chain tensioner
- what air cleaner
- 2000 FLSTC Idle Issue
- Would the toolbox fit with pegs and saddlebags?
- Passenger foot peg mount for 08 Fatboy
- HD Saddlebag Quick Release Kit
- Deuce fork tube removal from triple tree. NEED HELP!
- Fatboy Lo stock bars
- Possible or not: 2015 FatBoy - delete ign switch on dash housing?
- Saddle bag rails on 2012 heritage
- Anyone added a tour pack to the '19 Deluxe?
- Bought 07 softtail custom, no fob , lights just blink, no pin number for me, help
- Passenger pegs/boards
- 1988 rear caliper
- New To Me 2004 Dyna Low Rider
- Saddlebag Guards
- Help with fuel filter install
- 2009 Crossbones
- Fat Bob 2020 Side Mount License Bracket + Light
- FL springer pm brakes
- Do I need remap or something like V&H FP3?
- 07 Night Train Handlebars
- Heritage springer seat fit a deluxe?
- Anyone running Andrews 48 cams in their Heritage (96)?
- 21” tyre for fatboy
- How High
- 2004 Fatboy rider seat mounting screws
- Spring Seat on CVO
- Softail rear axle alignment plugs
- Cold motor oil level
- Saddleman Seat
- Where to get cheapest battery
- Heated Grips
- Slip Ons for 2017 Heritage
- Modify 2007 Fatboy or 2019 114?
- 130/90-16 or equivalent on rear of 2012 heritage?
- The Flying Dip Stick...again
- Bullet headlight lamp removal
- Dakota digital for my train
- 48 fat spoke wheels.
- Question about Softail triple trees
- 88 FXST starter wiring
- Engine light coming on
- While I am doing my cams, anything obvious to do on the way?Oil pump?
- Thoughts on the TC vs M8 Softail
- I have a 2002 Fatboy - what year seats fit my bike ..?
- Root beer bags
- Breakout front fender/guard
- 2016 Softail Slim S
- My Fat Boy touring set up
- New tires installed that are old
- Brake rotor question
- Anyone running a 130/70/21 front tire on their softail ? Front fender question.
- cams
- Heritage now a touring model?
- Which Model Year Heritage Softail.
- Softail Slim LED transformation of the front. Please Help
- Auxiliary lighting for 2018 FLSL Softail Slim
- Chevy badges on a Harley
- Start/Side stand lock system doesn’t work
- Left switch housing dead
- Installing HD Detachable Saddlebags on ‘16 Slim S
- Lower passenger seat anyone?
- TC 103B in Softail question
- Outlaw chubby apehanger
- oil leak + upgrades twin cam 88
- The 2020 Harley-Davidson Softail Standard Is Here!
- Tag relocation.
- 2015 Fatboy Lo Curved Riser advice
- 2005 Softail Deluxe Pricing
- Ape Hanger Suggestions for Breakout
- 2016 Softail deluxe- great price, should I take the plunge?
- 2012 Fatboy Lo - Bar/Riser heights? (Are these stock?)
- Help with Fishtails on Heritage Softail 91
- Primary Bearings - Replace?
- One issue solved another pops up
- V&H Hi Output short scrape?
- Heritage winter project complete
- softail wiring
- Master cylinder
- heritage 114-front wheel removal first time
- Extended(tall) mirrors '09 Fatboy
- Bike won't start
- 13 Slim Stock Air Cleaner Modification
- Correct oil level!
- replacing ignition lock and/or fork lock
- Fatboy 93 ... is her the chosen one?
- Help for a bud, stalling at low speed & downshifting.
- mounting bracket
- Custom Night Train build
- Fuel filter question
- Tail light removal/cover
- 2011 Fatboy Lo Max Handlebars on Stock Cables
- Fatboy seat questions
- 422 shock broken shaft
- Fork Brace
- Economical Upgrade
- New seat for the wife’s heritage
- 2018 fxlr front turn signal relocation
- Tire pressures
- Heritage owners (2010-17) please help me!
- Eliminate Rear Shift Lever.
- strut cover fitment?
- Brackets to install Heritage bags onto Fatboy?
- Usb port
- basic fluid check question
- Chrome center cap for fatboy wheels.
- APE handlebars
- Wheel fitment help?
- Thunder Header 99 Softail Evo
- oil lines 99 softail
- New to Softails. Need knowledge.
- 2014 breakout triple trees lower steam and bracket
- 2013 Heritage Softail
- Online parts
- Finding chrome wheels for my 2016 Heritage Classic
- seat and pain (location)
- Evo era springer axle nut covers
- Stall after TSM eliminating
- Getting crazy ideas again
- Is there an inverted fork kit for a 2015 Breakout?
- 2017 fatboy S cable kits
- Slim seat
- New Arrival
- Tank Console
- 2012 vs 2013
- 04 Softail- Vented or Non Vented gas cap??????
- Breakout 103 vs 114
- Longer Luggage Rack ('14 FLSTC)
- Long Ride Shield on a Fatboy with nacelle
- Blacking Out, How Much is Too Much?
- Static vs. Corrected comp?
- Fuel Filters
- finished the deuce
- 2013 Heritage Softail w/44 miles
- My Softail Deluxe build finally finished
- Need help finding forward controls
- New member, question about taller bars on 12 fatboy
- Do I have a Big bore or regular 88ci?
- New to Softail forum
- Blacked-Out 30th Anniversary Fat Boy is Wicked Cool
- 2 into 1 Exhaust for Fatboy
- Milwaukee 8 107 Stage 2 v 114 Stage 1
- 07 Softail fork oil
- 2018 fxlr foot peg bracket bolt size?
- Rust below fuel gauge?
- 2017 Softail Frame Specs
- Springer front shock
- When we're catalytic converters first used on softails?
- 2018 Fatboy mini apes
- Custom slip-ons on V&H duals
- New Toy
- 2010 fatboy cable and hose lengths
