View Full Version : Softail Models
- Tank lift on a '10 Heritage - any pics?
- Has Anyone Upgraded their Head Lights?
- Oil temp dipstick - analog, or digital?
- 08 Heritage FLSTC tire pressure?
- Running like crap - once again questioning my work
- tank lift pic
- Hope my electrical experience can someone else
- A Couple Issues with my Heritage...
- Anybody Wanna Trade For Louder Pipes?
- My little brothers truck and my bones
- Will This Tire Fit My 05 Heritage Classic
- Wide tire fender bib
- Clutch Engaging on Starting - 08 Train
- 2010 Fatboy - Spoke Wheels
- Boss Bags or Hog Deluxe
- Night train problems
- Keep the 16" rear or go 18" rim??
- Off to the dragon.
- Tool Kits
- Saddlebag question.
- Headin' out Wednesday
- Willie G Teardrop mirror install questions...
- 08 Night Train rear brake light
- 1925 Seat on the Bones?
- New to the forum.... & confused a little.
- She's turning into a seat ho
- Milage on a full tank?
- Defect or just too much gas in tank?
- Battery Issues - need assistance
- Tombstone Tail light
- Bad "wiggle" on Heritage STC
- two mystery electrical plugs
- Fatboy and deluxe lowering my forks
- Rocker custom seat
- Insurance Cost in California????
- Good Day, Good Ride, Bad Starter
- speedometer
- Slip-ons
- Check engine light and battery light with code p0562
- brake ?
- my 08 heritage done!
- Radius Pipes - V&H vs. Freedom Performance
- softail78
- Heritage bars going to the right
- springer drag bars
- hd tri bar tailight or kuryakyn lay down
- Aftermarket muffler and air cleaner
- electrical help
- New member of the black mini ape and riser kit club!
- Night Train (some newbie questions)
- my new 2010 Softail seems sluggish
- No 2011 FXSTC
- Rear Brake Light Sensitivity Prob. - Switch??
- Pics of Barebones or C&C on a 200 rear tire bike?
- Show off your FatCats
- i need help?
- andrewsdm.. I need your contact info!
- night train = 700lb dirt bike
- Speed sensor O-ring size?
- Steering Head Adjustment "Fall Away" Test
- 09 Deluxe cost to purchase
- When does your gas warning light go on?
- Help finding performance pipes that aren't loud.
- '06 Night Train questions (the right bike?)
- Oil Temp
- 08 Swingarm fit on an 04 Frame
- Vance and Hiens Big Shot Longs with Quiet baffles (Video w/sound)
- C&C Faux Ostrich seat with fender bib...
- OEM deuce handlebar specs
- 01 Softail Deuce capacities
- Got bit by the Harley Gods
- Oil Light
- swingarm bolt alignment...
- installed apes n got a wiring issue
- Open belt drive on a Rocker
- can i take out my baffles
- Question on lowering
- Rocker C tire
- Newbie with Fatboy exhaust question
- Regular service requirements for 2008 Heritage
- power commander III map
- 97 fxstc new vibration
- V&H Short Shots for Night Train
- Charging system upgrade?
- Sticky Throttle
- added a bagger to the stable
- Need info on wheels- DNA vs Rideright vs Hogpro
- Help with rocker electrical problem
- New Squeak after Installing Upper Swing Arm Cover on Deluxe
- 21 " wheel advice HELP PLEASE
- How Bout This Price?
- Wheel sizing for a Rocker?
- 4" pullback/riser 09 fatboy
- brake light wont go off
- New Custom Apes for my Sled!
- Ride of a 1994 Heritage
- Springer seat on my 01' Heritage?
- Deluxe seat pushes you to far forward?
- Just bought my first HD
- 03 heritage lights on 03 fatboy??
- Heritage bars on the Deluxe
- Do you recognize these pipes?
- Duel exhaust on Heritage Softail classic
- Silhouette Up Front on a Deluxe?
- Simple rocker c backrest mod!!
- Lowest seat for a 2010 Heritage
- 2007 fatboy tank scchhhh
- Paint help
- Deluxe question
- Alarm Beeeeeeeeep
- Ignition help
- Not tracking straight
- Rear Brakes on an 05 Deuce
- Front tire size...
- Tranny Leak?
- Melt Down averted
- Manual tire change laced wheel
- Progressive 422's on a deluxe question
- Rocker Mod updates, with pics
- Just had first service on the bones
- Rear wheel bearings bad at 11,800 miles
- After Stage one...
- Nighttrain oil check
- Member needing so help with parts...
- 2008 Fatboy Front Caliper Seal Kit??
- 14" Apes on Deluxe.. Let's see them
- Nightrain vs. FXST Custom?
- 02 Softail Frame Bike Build Questions
- medium low backrest pads
- $ Engine
- 2010 Fatboy Road Trip - 1400 miles
- Some examples of C&C seats fabrics and styles...
- Venting crankcase
- 18's on Fatboy lo!!
- Weekend Mods. For My Rocker and Me! (PICS)
- First ride this year.
- New bars (pics)
- 08 Night Train - Badlander seat vs stock seat
- A question for the fatboy lo owners.
- Help!!! Wierd wear on my front tire
- That New Harley Smell.....
- Pics...The progressive shock thread
- Hit the first 1000 miles on new fatboy.
- Blowing 15A ecm power fuse I have an 07 night train with Samson exhaust no baffles, s
- 16 inch front on a standard
- Okay, but can you RAISE a Deluxe??
- fatboy displacement question
- Torx on turn sig switch housing
- RideMaxx
- Syracuse Hog Rally I Need a Sissy Bar Bag
- X Bones/Dark Paint Bikes Check Here (Cleaning Products?)
- How many amps should my electrical be pulling?
- 21 " Front wheel on a deluxe
- Fatboy front fork travel ?
- Illinois Freedom Run Sat,6/19/2010...Support all our Heroes!!!!
- Newbie Deluxe owner here
- HD dealership says I cannot lower my Deluxe?
- question for crossbones owners
- Softail Custom/Stock Dunlops: What Air Pressure Do You Use?
- Fatboy Stereo
- Forward Control Question
- Pull back risers for 1.25 bars
- S&S 97" big bore kit for 88" - anyone install?
- Compression broke my starter clutch today on a ride!!
- cruise control on a softail?
- fuel or ignition problem please help!
- Hid kit?
- shocks
- 18" front rim on Crossbones 140 front tire
- Dr. V-Twin
- Got the new matching C&C fender bib today! PICS
- new Mustang seat arrived today
- Who's Ride? Black Deluxe w/ Lepera Wht Diamond Stitch
- tuning in 310 cams
- LED turn signals/brake lights help!
- Lighting high beam issue
- Neck cover and frame down tube covers are on.. (PICS)
- 2000 Deuce voltage regulator question
- flh bags on softail
- Drill and Tap
- Too hot to ride
- Softail Shocks vs Ride
- New Leather Fender Bib for my Fatboy Lo
- outer pulley cover
- One great GPS mount
- Tired of buring your pant legs on hot pipes?
- X Bones Owners: Ditched Footboards?
- Deluxe Bags/Pass back rest
- mix tires...no prob?
- A Matter Of Opinion
- Changing Tins
- 1988 FXSTC electrical problem
- newbie with 2010 heritage softail classic
- Any Rocker guys with the Heartland signal relocation brackets?
- Anyone having trouble with headlight burning out ?
- I'm back, sort of.
- New owner smart alarm question
- My First Softail!!!
- D407 and D408 Front Tire
- Question 4 Springer owners
- Need some cam help
- DIY Changing Handlebars.....HELP!!
- 2010 rocker blinker/brake light
- 150/80/17 Fatboy Front?
- New Deluxe
- Tranny oil !
- New Floorbaords ordered! Woo Hoo!
- ? 2010 Soft Tail Custom
- new grips
- What's a good price for an '09 Night Train in black??
- Americade
- 2006 harley nighttrain
- What fender/struts do I have - trying to get detachable backrest...
- Wild Pig Slip On
- E-Z brake on Heritage questions
- SS 106 Kit
- Ness forward control extensions
- clutch problems?
- Rinehart Racing exhaust for my 2008 Crossbones
- Project bike need the brand of bars, thanx !!
- 2008 Heritage Factory security system with no siron
- Street Slammer questions and pics?
- waiting for a tow truck right now...
- 2000 Heritage Electrical Probs Getting Worse
- Forward & out extensions...?
- Dealer messed up tune.
- New seat, need more room
- Newbie Night Train upgrade questions
- Red or Black?
- softtail compensator
- Your opinion needed for some new wheels
- My new foot clutch pedal with pic
- Turn signal popping fuse! Suggtestions?
- ride characteristics of 98 fxstc
- Question for someone with an 06 Fatboy
- Passing Lamps
- Stage I EFI update with SE cartridge
- Maint Question
- How to tell if a '10 Heritage is lowered?
- What's the best seat
- oil .... level misleading
- Pictures of new mods
- Stupid Harley Torx Bolts
- Nice Ride to Beach, Red Bay Store
- Today is the day! C&C solo seat comfort test!
- Fuel tank sender part number needed please
- Selling my Softail
- kuryakyn stirrups, any good?
- Installing Stage I AC. What Do I Do With Stock Sensor Plug/Wire?
- LED tail light bulb doesn't work?
