PDA
View Full Version : Softail Models
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338
  1. Consensus on cost-effective front lighting upgrade?
  2. tank dash trim/seal
  3. Engine noise, at wits end, need help
  4. Electrical issue! Speedo, other things stopped working
  5. Transmission Oil Check
  6. Scavenger On 2014 CVO Breakout
  7. Looking For Help Deciding
  8. Ness light drop down kit
  9. 2012 fatboy cam tensioner problem
  10. Curious Problem for You
  11. Please Identify This Horn
  12. How to: inner bearing and race on the output shaft
  13. Taillight conversion
  14. Cant find screw part number 2006 softail fxstd
  15. Heritage Passenger Seat Question
  16. Starter Issues
  17. Softail Oil Check - Jiffy Stand or Standing Up...?
  18. 08 Softail Pulley > Teeth count
  19. Bike Shuts Off While Rolling In Neutral
  20. Engine swap
  21. 30 x 70 pulley upgrade. Wow
  22. Top of belt rubbing with slammed softail
  23. Rear caliper 2001 softail deuce
  24. 03 deuce
  25. New tubes for tires ?
  26. Custom Dash?
  27. Does anyone have experience with MRI center stands
  28. Help to identify this bike please
  29. Hard start problems 2011 FLSTN
  30. Mufflers, HD SE equivalent
  31. Neutral Indicator Light Not Working
  32. Need some help on this one.
  33. Crossbones 18" wheel with wide tire.
  34. 2006 Fatboy won't start
  35. Give the Heritage a lighter look
  36. Fuel Tuner necessary?
  37. Seat help
  38. Fuel leak help
  39. GP4-AR Air ride switch, not to happy
  40. Starter issue/question.
  41. Volt Gauge
  42. Heritage with V&H big shots staggered exhaust
  43. Firing one cylinder need help
  44. 2015 fuel tank capacity question.
  45. Cranks but won’t start randomly.
  46. Help with adding floorboards to deuce.
  47. Fender extension and fillers
  48. Security System Problems
  49. 91 fatboy voltage issue?
  50. Wrap Pipes
  51. Heritage softail no turn signals odometer speedo or horn
  52. Heritage Classic
  53. Vance and Hines aftermarket slip on mufflers
  54. CVO B/O Instrument Conversion to B/O
  55. Pulley Bolts
  56. Extended Rear Fender Railway
  57. Engine light code?
  58. Searching for blacked out wheels/rims for 2017 Softail Slim S
  59. Can I add Bluetooth security to my 2017 HS?
  60. O2 sensor elimination
  61. Hey guys! First post and it’s a doozie
  62. Belts don’t last for me
  63. Cam selection
  64. Question about brake fluid - 2005 FLSTFI
  65. Batwing fairing installation
  66. As 2020 model year approaches, I’m wondering if the softails sump and transfer just like touring bikes..
  67. 2009 night train rear brake pad change?
  68. 2014 Heritage Back Rest
  69. Heritage tank lift
  70. 10" Bars on 17 Fat Boy
  71. Stupid Person Question - Starting in Gear
  72. LED Turn Signals and Tail light
  73. Runs only with choke out
  74. What for is this wire & plug
  75. Softail frame
  76. Seized TORX- tips wanted
  77. Brake light is not working
  78. Shifting from neutral to first
  79. New stator has chips
  80. 1997-1998 FLSTS front wheel offset
  81. who is it everyone suggests on here to modify a seat
  82. Rear Wheel Bearing Went Out
  83. Hawg Halter 13-inch rotor with 6 piston caliper on Fatboy?
  84. EFI to carb
  85. lookingfor quick detach windsheild brackets
  86. Heritage conversion...
  87. Softail Deluxe Passenger Floorboards with Samson True Duals???
  88. 2006 Carb FLST dies after long rides.
  89. Heritage, older vs newer
  90. 99 Softail riding light
  91. Extended shift toe/heal pegs
  92. Neutral Switch Location
  93. Incredible Softail Build Is Many Years in the Making
  94. Draining gas out of a 1994 FLSTN
  95. Opinions on some softails and the numbers we're kicking around
  96. 1988 Flstc Service manual need more
  97. Lost one of my saddlebags - where to buy?
  98. Night train vs Night rod exhaust
  99. need to upgrade to a new seat
  100. Looking for White Wall Tires
  101. Which seat to choose?
  102. Suddenly become hard to start
  103. Thoughts on heritage Softail classic for a shorter person?
  104. Viking Bags on a Fat Boy
  105. 97 Fatboy turn signals
  106. ABS fault that can be fixed with magic. Or can it?
  107. Cold start issue
  108. Custom stuff bites me in the ass,..
  109. 2011-2015 Softail Stainless Steel Mid Frame Heat Shields
  110. Crossbones shocks
  111. Laid it down...
  112. Adding weight to swingarm
  113. Help - weird electrical fault
  114. 98 Heritage Softail Classic randomly dies
  115. Speakers and Amplifier for 2003 Heritage Softail Classic
  116. 1988 flstc riser movement
  117. 2006 Fatboy spoke wheels
  118. Not So Sure about Installing the Reduced Reach Bar
  119. Battery Tenders and the ECM
  120. Fatbob 2019 low speed rear wheel rubbing?
  121. Buzzing in Handlebars
  122. Brake lights blinkers and horn not working
  123. 2013 front brake pads stuck
  124. Fat Boy Rear Fender Screw - Screwdriver Size?
  125. Heritage questions from a newbie
  126. Custom Leather Springer Seats
  127. Pinstripe paint code for 2008 Cross Bones
  128. Turn signals not working when engine off?
  129. 2000 Fatboy windshield mounting hardware
  130. ABS Scan Tool after bar install/ Brake line change
  131. P1353 ?
  132. Fender Bib choices.
  133. Forward controls fatboy s
  134. Help! How do you remove the pins from the throttle by wire plug?
  135. S&S big bore kit for twin cam
  136. Ignition Switch Question????
  137. Need information on your Rocker
  138. 96 Fatboy Short Circuited and won't start
  139. Fatboy lo stalled but started back up
  140. Mainshaft inner race too far on
  141. Oil Level
  142. 09 Heritage rear brake noise (Drag??)
  143. Interesting predicament
  144. 96 fxsts transmission oil chang help
  145. Siphon oil out of crankcase?
  146. Part finder
  147. IPhone and Cup Holders
  148. Softail shock length with weight on bike
  149. Salvage Value or Sell for Parts
  150. Trip A and B will reset .
  151. Cable Length for 16" apes on a 02 Fatboy?
  152. Please help....gear issues!!!!!!
  153. Progressive 422 retrofit
  154. Heritage spits sputters
  155. Carb drain screw ?
  156. Which bolt is tranny drain?
  157. Torn between 14” or 16” ape hangers... opinions?
  158. Viking Bag Mounting Question
  159. Possible Fat Boy project question
  160. Heritage softail driver backrest
  161. Chrome wheels on ebay
  162. in hd shop for 7 months
  163. Looking at getting a new seat...which one for Two up
  164. Springer Fork Question
  165. Headlight Painted or Powdercoated?
  166. Progressive Rear Suspension
  167. Harley Davidson Rocker 2009 front cylinder not firing
  168. Cushioning for a rear seat?
  169. Need help
  170. New to the Forum and frustrating question
  171. Qustion for those with chrome handlebar controls
  172. High compression twin cam 95 cu issues
  173. Arlen Ness handlebar bushings
  174. Parts for softail deuce
  175. Ignition Barrel tumbler
  176. Heritage owners, pictures of aftermarket wheels
  177. '14 Heritage Classic and Windshield Updraft (Yet Again)
  178. Lower forks clean up
  179. 2016 Heritage hard to get above 80mph?
  180. any details at all on this front fender?
  181. Sport Glide fairing on M8 Breakout
  182. 14 FLSTN Deluxe Cuts off on Deceleration
  183. Fuelpak 3
  184. 2001 FLSTF Brake Fluid Question
  185. Charging/electrical issues?
  186. Fatboy 21" front wheel
  187. New fat boy style headlight on older fat boy
  188. Anyone have underseat passenger pegs?
  189. Rider floorboard compatibility
  190. 2003 softail EFI loses power at the coil after fuel pump prime ends
  191. Cleaner
  192. Neutral
  193. Darkside Details On the FLSTSB Cross Bones
  194. Slim, shock turnes when tight
  195. Fxst heel/ toe shifter
  196. Touring fender on Softail
  197. Question about Fork Sliders????
  198. Question regarding handling of the 21" compared to 19" pro street breakout
  199. Smart Security System Compatability
  200. Custom Frame
  201. 06 Night train worth the gamble
  202. 17" wheels on fatboy?
  203. 05 fxstsi flush mount fuel gauge wiring
  204. 1994 Fatboy Speedometer Removal
  205. 88 primary drain screw strip
  206. 88 fllstc oil tube what is this???
  207. cruise control on a 2014 Heritage
  208. Bike wont crank batter is full
  209. Deluxe rear lighting
  210. ABS bearing vs Non ABS bearing
  211. Auxiliary bulb options?
  212. Softail swingarm and shocks dimentions
  213. Harley Springer Red trim Vinyl cloth
  214. Passenger foot boards on a Softail Slim with V&H Big Shots?
  215. Blinker issues
  216. 18" WW Rear tires, anything out there yet?
  217. Calling 2018-19 Low Riders. How's it work for 2-up?
  218. Lower idle rpm 103cu
  219. 2006 softail standard handle bars
  220. Ciro 3D phone mount
  221. 04 Fatboy speedo head not working! Wiring diagram?
  222. Fxsts with 100" s&s
  223. Practically new battery — needs to be replaced?
  224. How do I fix a loose mirror?
  225. 2014 Heritage Softail Classic shutting off when I slow down.
  226. Passenger pegs with v&h grenades? Anyone? This is crazy
  227. 1999 Harley Softail
  228. Fxdrs highway pegs ??
  229. Metzler 888 16" recommened tire pressure
  230. Clutch slave cylinder issues - CVO Breakout
  231. Phone Charger Placement - Breakout
  232. Relocated brake lights left hole behind. Covers?
  233. 2 Up Riding
  234. Growing on me . . .
  235. Considering a 2007 Softail Springer
  236. Softail oil dipstick loose - problem fixed
  237. CrossBones Heat
  238. Indicator Wiring
  239. True Duals on a Deluxe
  240. Question about heritage
  241. Crossbones Question
  242. '06 Passenger peg mount kit work on my '07?
  243. Bolt on bottom of Triple Tree for Brakeline Mount
  244. FLSTF Forward controls
  245. Looking to upgrade stock saddle not replace
  246. 2018 Fatboy headlight options
  247. Weird Start 1988 FLSTC
  248. 2018 Softail Slim fluid capacity?
  249. Need help finding the acc/key ignition wire 2007 delixe
  250. Battery drains after 30 minute or 2 hour ride..?
