View Full Version : Softail Models
- 1999 Harley Softail
- Fxdrs highway pegs ??
- Metzler 888 16" recommened tire pressure
- Clutch slave cylinder issues - CVO Breakout
- Phone Charger Placement - Breakout
- Relocated brake lights left hole behind. Covers?
- 2 Up Riding
- Growing on me . . .
- Considering a 2007 Softail Springer
- Softail oil dipstick loose - problem fixed
- CrossBones Heat
- Indicator Wiring
- True Duals on a Deluxe
- Question about heritage
- Crossbones Question
- '06 Passenger peg mount kit work on my '07?
- Bolt on bottom of Triple Tree for Brakeline Mount
- FLSTF Forward controls
- Looking to upgrade stock saddle not replace
- 2018 Fatboy headlight options
- Weird Start 1988 FLSTC
- 2018 Softail Slim fluid capacity?
- Need help finding the acc/key ignition wire 2007 delixe
- Battery drains after 30 minute or 2 hour ride..?
- No speedo
- Rear Pulley/Rotor Fitment Question
- What is this wire harness?
- Issues with cables for 5.5 or 6 riser???
- Bike wont start
- HD Slim vs Softail DeLuxe handlebars
- Softale Starter Replacement
- Paintable Hard Saddlebags on 06 Softail Deluxe
- 17" wheels on 2003 fatboy
- Throw-over bags on a Slim
- Harley disc part source
- Component I have never seen
- Breakout TBW debut year?
- heritage 114 gas guage
- Breakout CVO Tires
- Part Number Search
- Any 1984/85 fxst owners? Need some pictures
- 2008 FXSTC Clutch Engaged/Idle Issue/Engine Dies
- Thunderbike does it again.
- 2016 Heritage Softail little leather braids
- ECE Certified Screaming eagle mufflers for Fat Bob 114
- 2000 nightrain foot clutch new or DIY
- LED TURN SIGNALS 88 FLSTC question
- 2005 Deuce Headlight
- backfire
- Fatboy S exhuast system
- 09 fxstc brake arm
- Need Help Deciding
- Rim size
- Stunning Custom Harley Night Train Spares No Expense
- harley davidson breakout questions
- Engine Rebuilder?
- 02 sensors
- Keep forgetting the damn stand
- Tail light question
- kuryakyn road thunder sound bar
- Vintage 1988 Softail Custom Clutch Issues
- Speedo trip reset screw ????
- V Twin Power Rotors.
- Which way to loosen the nut??
- Dunlop American Elite
- Deluxe Fuel gauge always full
- Completed a few upgrades
- turn signal problem
- 01 fxsti
- heritage 114 2 problems
- Fatboy Shield
- Rush 3in mufflers 2017 softail
- Accessory front fender for 89 fxst
- 1998 FatBoy Turn signal electrical issue
- Need input on going rate 2006 softail standard
- Oil pressure lamp/indicator panel
- Windshield For 2018 Slim
- heritage 114 rear wheel alignment
- FLSB Front Brake Torque Specs
- Front turn signal mounts.
- Turn signals
- 2010 fat boy Lo starting issue
- 96 FLSTN brake pedal
- 2016 Fat boy floorboards
- 06 to 16
- Debadging the tank.....
- Old Rider, Old member, New Bike
- Magnum 5 21" must find one!!!!
- Transmission issues maybe ?
- no start no nothing
- Advice for Clutch Cable Rubbing
- 2002 Fatboy Advise
- Fuel management / tuner
- Best Tires for Softail Breakout
- Red key showing
- Wheels
- Oil Sumping with new Softails ?
- 2003 Springer factory height
- 2013 flstc engine noise
- what to replace pillion pad?
- Clutch
- FXR fairing for 2014 Fat Boy
- Fluid Change
- how many Softail heritage classic were built in 1986?
- Indent on 1988 flstc primary?
- 16 Softail Deluxe Riser Recommendations
- Need a new seat, Suggestions?
- 07 heritage big bore kit.
- 1984 FXST Softail
- Need some help from someone with a Heritage or similar
- 04 Softail tries to start without touching the start button
- 2000 Softail Deuce problem mounting left turn signal/mirror
- Slip-on Muffler Mounting Help - 02 Heritage Softail Classic
- 1984 FXST Softail
- Custom Solo Seats for Fatboys
- 2014 FLSTC... Luggage Rack w/o Sissy Bar?
- Memphis Shades Night Shade for Cross bones
- Rear brake arm for Rocker
- 21 soft tail rim
- Shifter shaft, big side play, no engagement
- Rear tire size
- 21 front wheel with stock suspension?
- Tail light strobe patter LEDS
- Fatboy S hard to start
- Phone mount on softails
- Identify this Softail Frame?
- 2016 fatboy exhaust Help.
- What would have come stock on my 2005 FLSTCI
- Looking at different handlebars for BO.
- 1988 heritage Classic instrument bulbs?
- Screamin Eagle Tuner reflash
- Softail Slim Handlebar Conversion
- Comparing Slim S and the New FLSL
- My 2018 Fat Bob Mods
- Where to put amp
- Rear fender seat Bolt
- New rear wheel
- Any good tuners in Florida?
- FXDR ThunderBike Exhaust
- Licence Plate Removal
- Cam chain tensioners
- New Seat - Just CAN'T decide......
- 17 Fatboy sissy recomendations
- Advice needed for 07 Deluxe build
- new battery
- Softail service manual
- Crossbones or Heritage Classic
- accessory plug for softail
- 1999 softail d02 error code help
- Wow, Love this Fatboy
- Old style brawler for 00-05' softails
- Fatboy handlebars on heritage
- freedom full exaust
- Soft tail rear fender
- Crossbones Gear Indicator
- 1988 FLSTC what's this?
- Been a VERY long time. Good to be back. Slim S w/pics
- softail slim
- What is the best fuel management system for a 2001 softail springer with efi?
- Low Rider Compared to Slim
- Back rest/ sissy bar
- trunk for breakout
- Running without a CKP
- paint code color softail heritage classic 1986
- New LA choppers "Nice curves" bars on my Deuce
- '08 Deluxe - Electra Glo Wiring??
- fuel gauge disassembly
- Softail Deuce primary oil leak??
- 2005 deluxe one piece dash
- full length dash console?
- Where to buy 21 x 3.5 80 spoke non abs plan b
- 2018 fat bob faring/windshield
- Does my 2009 softail heritage have Cush drive ?
- Help me figure out what all this bike is missing!
- Repairing scratched speedo lens
- keeps running after shut down
- Not another one!!
- Sport glide fairing compatibility
- DD Bobcat Install questions
- 1988 Gas tank schooling please
- Just running something by...exhaust, ait, tune...
- Primary Leak in an odd Area
- Slim S Pull Back Riser Kit
- 2000 soft tail starter Kickback
- Softail Deluxe Seat Bracket
- Chrome tube on top of primary
- Fairing for Heritage?
- spoked wheel tires
- 1984 FXST Exhaust options
- 2000 soft tail starter slam
- Fatboy service manuel
- I just need a little help with my 2000 Heritage
- Shocks
- 1993 Heritage FLSTC
- Thunderbike Breakout Fairing, anyone have one? US.
- Anyone 12 Carlini Gangster Apes
- Finished my woods 555 cam install
- Harley Hard bag conversion kits on Amazon? Good or no?
- Tallest apes with stock cables, etc? Will 1" bars work?
- My CVO Deuce
- Just picked up a New to me 2007 fatboy!
- 2008 96" Compensator going out.
- Heritage touring passenger pillion is jammed against backrest
- LA Chopper blue springs Vs other shocks
- Best rear shocks for Softail?
- Fatboy or Deluxe?
- 2002 Duece
- I want to put an 18 rear on my deluxe and need to whats correct size for 18
- Looks Like A Killer CL Deal On FatBoy Where I live
- Sound System for my 2006 Heritage Softail
- Heritage fender light delete
- Wrap fenders for 21" wheel: Lets see what your running !
- Fatboy wheels
- New hand grips
- 2005 Night Train
- risers
- Looking for 8" risers for 1 1/4" bars
- Looking for steps to remove fork tins 07 Heritage Softail
- Street bob wheels
- Pinion shaft scoring.... Is my motor going to blow???
- Wheel advise for my pops new fat boy??
- Finely Mounted
- Drag bars for night train
- 88B in softail vs 88 in touring
- Throw over saddle bags
- Upside down forks
- Tour Pak
- New AC and breather
- Rear tyre
- Used Harley Parts
- TBW Question
- Finally! I'm a member of the 100/100 club
- Cat in muffler or head pipe.
- Left front turn signal not working?
- Love the bike. Hate the seating position....
- Transmission
- 2003 softail springer primary oil level
- Night train 14" apes cable lengths??
- Amber/Yellow Passing Lamps (Lamin-X)
- Plastic under tank panel?
- How To Install 5-Speed Countershaft/Layshaft Bearing
- Rusted head bolt?
- Two-Up Tour pak & mounting Rack for Fatboy S (200mm back tire)
- Bad vibration
- trying to install old wheels on new bike
- 2004 Night Train - replacement gas tank
- Breakout clutch cable cover is cracked
- 2015 fatboy lo gps install
- Springer handlebars dilemma
- Flipped mirrors for 13-17 Breakout
