View Full Version : Softail Models
- Tuner for a 2004 Deuce CVO
- Clunking noise at start up
- Retuning after fitting spike air cleaner.
- 2018 sport glide rear wheel adjusters
- Spark plug leads .. breakout 2018
- M8 Engine Temps
- Seat Repair
- M8 Fuel pump issue
- FXBB, I’m back on a Hog
- IAC issue
- Replacement seat for 2018 softail slim
- Leaking oil dipstick
- Arced Ignition
- Child Seat
- Riding Impressions - Finding the long way home
- Saturday ride with the wife
- Rear fender mounting stud loose
- A Stand-Alone Tachometer For Fat Boy?
- Belt pulley bolts all broke
- Switched Live wire 2018 FXFB Softail
- Plug and play wire kit
- 2006 Deluxe FLSTNI-wheres the maxi fuse
- 18 Heritage soft lowers?
- 21 inch front wheel on 2018 Street Bob?
- Denim blue
- 14 Inch Wild1 Chubby Ape
- Best 103 Cam Plate?
- Pickin' up my 03 tomorrow
- handlebars
- Slim rim/tire help
- 1980 fxb
- Strange Whining Sound
- One good looking 18 year old
- Oh man, it’s hot...
- Checking Primary Oil Level / ‘17 Slim 103
- Breakout rain riding?
- Progressive lowering vs progressive drop in
- Primary belt with an adjuster
- 2018 Fat Bob Torque Cam
- Traded my 48 for a 2019 Sport Glide
- Harley part numbers
- Help - brake light flash once only
- Does this exhaust look right to you?
- 2018 Harley Fat Bob Tall Boy seat
- screaming eagle air filter install on 2018 Sport glide
- 2018 fat boy gas caps
- 2018 Breakout headlight swap
- Monoshock replacement?
- Battery tender
- Charging
- Breakout tank badge refit after tank paint
- looking for part number for this HD sissy bar leather bag
- 2018 Fatboy
- 2018 Fatboy stock seat backrest
- Heritage leather saddlebags on a crossbones
- Clutch Replacement
- Check valve lower o-ring hack
- Best cams for accelleration
- After market 2018 Softail Slim ungrades
- Plate relo and new gas and fake cap install.
- 93 & 96 Springer Handlebar Wiring Diagram
- Got a question
- Removing Passenger Foot Pegs
- I'll have to do better ... Some quality Deuce time
- 2016 Fat Boy w/ 120R concerns.
- 18 Deluxe risers
- Help needed “coil relocation”
- Instrument cluster dead
- Is this right?
- DIY Walo horn mount
- 17 Softail Slim FLS footboards for footpegs
- What do you think?
- Fuel tune on m8 softails
- Swing arm damage from saddle bags on 2018 Deluxe
- Cannot find slim black dipstick
- 2018 LowRider Left gas cap
- CVO breakout cabling question
- Night train handlebar options
- Bat Wing for 2008 Fat Boy
- Anything put on 02 sensor
- 2018 FatBoy Tranny Fluid Change Procedure!!!
- Brain dead. Pulled out in 3rd gear on 18 Heritage
- Weird: Never seen this before
- 18 Fatboy - ANyone have Bags, shield or backrest installed
- Up an inch, back two, on 2018 FLFBS 1.25" bars
- Vaguely Softail related......artwork
- fatboy handling
- 2001 heritage rear brake caliper
- wrap around fenders
- What do I need for tire change
- 2006 vs 2007 Saddlebag mounting
- Engine hesitation when accelerating
- Deuce foot controls
- 2018 FXLR Luggage Mount
- ordered a clymer manual need help
- New noise in M8 when cold
- Taller sissy bar for 15 Fatboy lo
- First Ride real ride 2018 Deluxe
- rider backrest for 18 heritage
- Do M8 factory oil coolers have a thermostat?
- Word of warning. If you have an ESP don't touch your bike yourself.
- Will heritage front fender fit softail standard with 21" tire
- Hard Bags on M8 Heritage
- Holy Sh!t
- FXFBS Big Al's Bubba Clamp Risers
- 2006 Deluxe. Red flags?
- Sport Glide 2018 Speedometer
- Seat Recommendations
- Confused
- Connector
- Thoughts on Price - '15 Fatboy?
- HD Windshields ‘19 Fat Boy.
- CVO Bars in Black
- Who’s running chrome apes with black cables
- Screaming Eagle advice for a noob with a Fat Boy 114!
- Compensator
- Shotgun time
- Sound of styrofoam rubbing together while riding
- 2000 heritage code d08set
- 2018 Paint Colors
- Suspension 18 and up Softies.
- shocks and gross weight for bike to handle
- compression
- Spokes and Cleaning
- matching fuel caps
- 2012 Deluxe Wobble?
- 16 Inch Ganster Ape Cable Length
- any conversion brackets for '14 and up saddlebags?
- Syncing turn signals with dash indicator after LED upgrade
- Has anyone removed a +18 Fat Boy/Breakout rear fender?
- Gas cap rattle
- 2018 Heritage vibration and noise from the brakes?
- Tires, Tires, Tires
- "Bib" for new 2018 Heritage Classis FLHC
- 114 fat bon stock A/C breather mod
- Lowrider handlebars
- Basket Case. What be
- Oil catch can location
- Fatboy
- Oil cooler
- Might come back for a third try
- Bad ECM
- Blown headlight fuse
- Progressive drop ins
- Who’s running custom plates?
- battery fuse keeps blowing
- Looking for a new speedo/tachometer
- What's She Worth???
- Help with forks
- Crossbones bagger?
- Fatboy
- Joker Machine turn signals
- First Harley, love it but the engine sounds.....
- Rocker C tyre sizes
- Me
- New Deluxe solo rack
- Dynojet power vision
- This just happened
- Thoughts and question re: the new suspension
- Belt Tension / Rear wheel alignment
- Ultra cool oil cooler
- Odometer trip reset
- 2004 Softail CVO Deuce
- 2018 Fatboy 114 Bounce
- HD poly riser bushings are now Alloy Art!
- 2018 headlight switch??
- Softail rear shocks
- One Touch Mounting hardware and latches
- anyone know what brand of frame has vin starting 1U9?
- Aftermarket Gas Gauge & Cap
- Seat conversion
- led upgrade
- Breakout risers
- Lean Running Bike
- Moving backrest rearward
- Laid down my 2018 breakout 114
- Softail Slim Licence Plate
- -2 Under Fork Tubes
- Might be a stupid question
- Strength of floorboards/kickstand
- 2017 Slim flasher issue
- Voltage regulator
- Any 2018-19 Canadian Fat Boy owners?
- evo softail seat
- The evolution of my ‘19 Fat Boy
- FX vs FL fork lowers - interchangable?
- Efi tank cover plate
- Lowering
- Forward controls.
- Any plate relocation kits for 18+ Fat Boy/Breakout?
- 1997 Harley BadBoy Worth it?
- Speedometer stops working after fuel fill up
- Quick release hardware
- Durability of the "black out" paint/powdercoat?
- FLSTN Locking Rigid Saddlebags Mounting System
- Should a DYNO affect RPM at Idle?
- BCM issues
- Quick report on the Rinehart 3,5" cans on my 114 Fat Bob
- Fatboy handlebars on Softail Slim
- Softail build
- Chain conversion sprocket ratio and tire sizes
- harley slammer bars on a Fatboy Lo
- 03 FLSTC...lean angle Q's with Dual Exhaust
- 200/55/17 vs 50/18 vs 55/18
- Heritage front signals
- Adding heel shifter?
- 2018 Deluxe light bar swap?
- Touring to fatbob - advice please
- Schuyler
- Introduced myself to the Softail group...
- Street Bob digital gauge on Fat Boy
- Signal lights cancel out early....help
- Does this passenger floorboard look right ?
- Night Train front fender or eliminate it
- Engine Rebuild
- Softail FLSTN
- Handlebar Wiring
- Riding RPM
- Acceleration pop
- New Night Train
- Weird no crank issue, 2017 Deluxe
- Bars, how high?
- FLSTC Saddlebags Fall off?
- Harley Heritage fuel gauge problems.
- Broken right turn signal switch
- Rear Wheel for my Deuce
- Re-mapping
- Installing Duece risers
- It took less than a day.......
- Throttle Cable Length?
- Bough a 2018 Slim. Finding neutral is a b!tch
- Harley Oil Cooler
- 2018 Street Bob Lowering Shock
- Softail Seat Interchange
- 2018 breakout seat question
- Question on 2018 Fatboy Brakes
- on/off rocker switch not working
- crossbones owners.....
- Passenger Grab Rail
- 2018 FXLR brake line questions
- Detachable tour pack 94 heritage.
- 2018 Street Bob Bars
- New To The Group
- Low Rider/Street Bob Exhaust
- Heritage Fairing?
- Street glide to 2018 Low Rider?
- Slim usb port dead
- 01nightrain starts runs 2 seconds the shuts down..
- 1996 Heritage seat question...
- Slim auxilary wiring help
