View Full Version : Softail Models
- 2017 Heritage softail rear fender trim
- Take a look at these plugs ....
- Cam’s for Rocker C
- 2018 FLHCS 114 ANV heat question...
- Deluxe solo seat
- Softail Slim Handlebar Changed
- Indicator lights on 2014 Softail
- New to me 05 FXST
- Diference between big sucker stage 1 reg or syn filter
- Fairing
- 2014 Softail classic will not start in gear
- Tyre pressure HD Softail standard 2005
- Turn Signal replacement/relocation
- 2018 Softail exhaust removal question
- getting ready to do the 30/70 conversion
- Softail standard
- front ignition coil driver low/open code harley 2016 harley touring
- Tire wear
- 1998 softail heritage classic
- carlini clean sweeps
- starter
- Extreme Flow vs. Heavy Breather Air Cleaners
- Denim Oil Tank stained !
- Bitchinseat store 21” wheel
- Having trouble selling my 2015 Softail Slim
- 2018 Deluxe Windshield Choices
- 2008 Night train front end conversion??
- Suggestions Needed for License Plate Frame & Mounting Hardware
- Recommendations on pipes for a 2018 Fatboy 114
- 2018 slim exhaust
- 95 Heritage
- Combination Speedometer/Tach
- 2018 Heritage Handlebar Position
- Slim's Saddlebag Fell Off On the Interstate
- Andrews 37 cams
- Back on a Softail.
- Anything out there to change gearing on M8's?
- Sputtering
- Stator plug fighting me
- 2016 Heritage Softail Classic rear seat issue
- engine oil capacitywhen changing oil and filter
- Seat switch
- Sheet metal for 2000 fxst
- Question about Turn Signal operation
- 2011 FLSTC rear fender torque specs?
- Kickstand
- Slim true dual help
- Crossbones headlight mounting bolt spec
- Fat Bob Handlebars
- BUSserr abs control module
- Crosspost: ulling trailer, lights are dimmer than they should be...P
- 2008 anniversary model fatboy wont start.
- 2016 Softail slim S.. new member
- Vance&Hines Big Shots Staggered Tailpipes
- Replacing Risers - 2016 Heritage
- 14 Fatboy. Tail light bulb. What is it?
- Fat Boy with S&S engine
- 88 fxstc no start - just a clicking relay
- 23" front and 18 rear!
- Advice Needed
- Synthetic or Conventional oil?
- 2018 Heritage Low Profile Shock review
- Andrew's 21, 26... S&S 551, 510 - which one?
- Compression test on M8 question
- Regular Season Introduction 1996 = "Early" Model?
- From 2014 Lowrider to 2018 Sport Glide
- "Early" vs "late" model 1996 FLSTF Fatboys
- new heritage 114 tires
- Stand on 2018 sport glide problem
- Slim cruise control
- Slim strut bolt help needed
- Swingarm conversion help
- 2000 heritage rear wheel
- 2018 Softail passenger pegs and minifloor boards
- new heritage 114-lower wind deflectors
- 2018 Deluxe FLDE - Recall Rear Fender Tail Light Assembly Replacement
- Day maker headlights ?
- Gas leaking out? Condensation?
- Build date ?
- I doubt between 2018 114 Bob or Boy
- 99' Night Train Tail Light Nightmare
- My first Harley, my first post, and a ton of questions!
- Reach seat on 18 Slim?
- 2018 FXFBS brake pulsing.
- FLST to FXST front end swap?
- Common issues to watch for?
- Looking for Narrow Seat Recommendations 2014 FLSTC
- Moving Over To The Softail Side
- Stock Fatboy clutch cable length
- Braided steel brake lines
- K & N for stock air box on flfbs 114
- 2018 heritage passenger peg more leg room
- 2018 Harley Tour Pack
- Anyone know if V&H are making the true duals fish tail pipes for the new M8 softails?
- 2018 Deluxe Fuel Guage Accuracy
- Windshield for 2018 slim
- Instrument panel
- Rear brakes started locking
- Loudest Air horns for softail?
- Craiglist scam?
- Strange idle problem
- 03 Softail body mod help
- Coil cover 18 softails
- harley dark custom horn cover
- New M8 Softails attracting new buyers
- LED Headlight
- Ultima Wheels. Rear 18x5.5 for 06 NT
- 2018 street bob riser thread
- 2018 Heritage maximum bar height with stock cables.
- reduced reach forward foot controls
- Softail solo bag hard mount?
- Engine Temp on '18 Heritage?
- Drive line slack 2018 Softail
- Shifting Issues 2002 Heritage Classic
- Still new in Arkansas w/ oil leaks
- 2005 Heritage Classic advice
- Harleys Burst collection.
- Newbie needs advice
- day 4 lessons with New Heritage 114
- Headlamp visor trim for 2018 softails (non-touring)
- Power Commander Bike Wont Start
- ODC Monza 2.0 front end
- Heritage 114 noise after 2 days
- 2018 heritage rocker box leak
- 18s stiffer ride then older Softails ??
- 2018 Fat Boy Aux Electrical Harness
- 107 vs 114 Heritage Classic
- Road King to Heritage Classic ?
- Looking for a GOOD Powder Coater for wheels...
- Connector pins
- Dash Mods for Breakout HELP!
- wave pipes for cvo
- Question About heartland struts
- What is factory fill for tranny
- I need some help !! fatboy 114 or deluxe 2018
- Just bought my 1st Softail
- I need some help !! fatboy 114 vs deluxe 2018
- Rinehart 2 into 1 install
- Peg to mount to engine guard fitment question
- Hey Jaystn62 look at this
- New 2018 Softail slim
- 2018 softail slim neutral
- Leaking oil around rocker cover on front cylinder...
- 2017 Service Manual
- Moisture in my speedo
- DIY Maintenance
- C.O.G. on deluxes
- drain plug location
- looking to trade '17 RGU for '19 Fatboy
- Screamin Eagle muffler issue on '93 FLSTN
- Just installed NGK Iridium (DCPR7EIX)
- Night Train Rear Brake Pedal
- Wheel bearing replacement problems on 2007 fat boy
- anti-lock brakes availalbe on slims?
- Cut in rear tyre
- 1998 fatboy rear suspension issues
- Issues with the 2014 103?
- FuelMoto software help!
- Passenger floorboards
- Exhaust question about DB
- Thunderbike Fatboy M8 114 Phynix custom
- Going crazy
- HELP! Bucking/engine cutting out on 04' night train
- softail slim help
- Please explain this clutch adjustment question
- 08 Fatboy No Power
- Softail Pin Code
- Moving rear brake lever closer to center.
- fat Bob bars and risers work on a FXLR?
- Cholo deluxe parts walkthrough and build progress
- 2003 Fatboy FLSTF Tire / Wheel ?
- 2005 Heritage Softail, Dead, No power
- Rinehart 2 into 1
- Road king dash on a softail
- Breakout - riding two up?
- 15, 16 Breakout question
- Swing arm bag Manufacturer Question
- Oil deflector in outer primary case
- 114” Fatboy numbers
- Speedometer Fogging repair?
- 2018 StreetBob Pulls Left
- Possible Yamaha R1 fork swap
- Saddlebag Braces
- 2018 Fat Boy - stock handlebar dimensions?
- Anyone with hard bags on a Deluxe
- 2018 Fat Bob Breathers Known Problem
- What should be expected to be changed on 2019 Fat Bob?
- Different primary cover?
- Oil coolers on the big 110 engines
- Deuce Backrest
- 2018 HD FatBoy customized
- Harley Davidson service lift
- Fatboy popping
- Fatboy seat on a Breakout???
- Top seed FLSTFB
- Excessive vibration
- Viking bags? 18’ Fat Bob
- Softail Safe Mode???
- 2018 Softail (Heritage) battery problem
- 2009 heritage softail rear directional bar
- Rear Brake depresses completely, then pumps back up
- 2001 Softail Deuce
- 2015 Deluxe Rear Fender Strut
- lowing kit
- New ds extended turn signal switch covers
- Blowing Oil Plug Out Of Oil Tank
- mounting WLA style bags
- 2018 Street Bob (FXBB) forward footboard&controls??
- 2017 flsct handlebars out of alignment
- CB Radio for Heritage 2015
- Anyone with a 2018 Sport Glide using the Bikescreen/Gustafsson windshield?
- 2018 Fatbob Front Wheel Hop
- 2006 Fatboy wheels
- Neutral Switch Question
- Just bought a new Heritage
- My Sportglide18
- 2018 Street Bob solo seat on a 2018 Fat Bob???
- New Member w/ a question
- Thought on Screamin Eagle end cans for 2018 Fatboy
- Will 69734-05 (headlamp trim) fit a 2018 Heritage?
- Trouble starting my Harley
- Fluid Clarification
- Please dont hate me ....
- Automatic Compression Releases
- Engine guard 2018 Sport Glide, Pictures
- 2018 Slim
- M8 Street Bob - rear brake weak?
- 2018 fuel leak
- Oil Filter relocation
- Hard bag conversion 2012 Softail Classic
- What years tins would fit my 2017 ???
- Switching grips, need help
- Harley Swingarm Bag?
- Some info about the 114 Ventilator air cleaner
- V&H Elliminator 300
- Kickstand kaddy
- Tallest apes
- New Deluxe whitewall question.
- 80cu in EVO puking oil on start-up?
- Bassani radial sweeper or two brothers Comp S 2-1 for 2018 Fat Bob
- 2018 Heritage - Light trim rings...
- OEM softail exhaust swap compatibility
- Sunpie passing /fog lights
- New Fatboy runs crappy
- 49mm Forks on FXST
- FXSTS wiring request
- Moon Glow Blue 1995 Fatboy
- Post pic's of your custom seats...
- 2016 Fatbob oth price
- Softail sounds amp in tool box
