View Full Version : Softail Models
- Flush mount fuel gauge problem
- Who Switched Brands Because of new 2018 Softail
- Riser bushings for Fatboy
- smartphone garage door opener apps
- WWW for the Heritage
- Speedometer Stop Working
- Lil' help? Cam basket SNAFU
- Clutch won't disengage
- passenger floor boards on a 1997 heritage springer?
- 07 heritage springer passenger floorboards?
- Calling All 2018 Fat Boy Owners !
- 2018 Softail LED signal lamps 67800640 and B2141
- anybody here ever rewired your tank mounted dash?
- Combo Analog Speedo and Tach with Fuel Gauge
- SE Stage II is perfect for me
- While doing my clutch......2012 fatboy
- Rocker Lockers
- Self-bleeding front ABS module?
- got my 2018 fatbob 114!
- Anyone tried a HD Torque Cam on a '18 114 Softail yet?
- Tires!
- Collection day '18 Heritage
- Loud pop when starting and slow turning over when hot
- S/Tail Springer
- Loose Shifter Arm
- Another twin cam mileage check
- fat boy looks with breakout seat position, possible?
- Primary Cover Finish?
- where do i find a rekluse clutch for 1993 softail heritage stock clutch setup
- Are you bothered by the primary protrusion on the 2018's?
- Stage 1 and Fuel management question
- 1990 Heritage Clutch issues
- Suggestions For Illnois Toll Pass
- 2018 Fat Boy arrived today!
- Hot bike magazine
- Breakout - weld on tank extension
- Caddy Blinkers On A Heritage
- Tallboy Two-Up Seat - Fat Boy and Breakout
- Handlebar vibration
- 2012 Fatboy Lo battery light flashing
- Finished the bar and cruise cntrl install on my Breakout
- Anyone running Street Cannons on 18 Heritage?
- Right Brake/tail-light inop only
- Short risers for a breakout?
- 2014 StreetGlide exhaust fit a 2008 Fatboy?
- Help with nacell back to regular
- Custom Dynamics
- Model difference halp!
- CVO Prostreet forward control relocation
- Compensator Sprocket swap from Dyna to Softail
- Police solo seat for softail?
- trans.
- 2018 Deluxe ?
- Blackline front end axel spacers.
- 2008 FLSTN: Feels like the bike loses power for a split second
- Softail 2018 side mount licence plate
- MY new 2018 st bob - vivid black
- couldnt wait for winter for winter mods
- '18 Heritage 114 Softail-Mfg Date ?????
- Wicked Red/Twisted Cherry on a Fat Boy
- Is it possible to rubber mount a twin cam 88 B (balanced) engine
- How do I clean out my Rocker's gas tank?
- Two brothers on a breakout
- Will wrapping the pipes reduce heat?
- Test Ride on a 2018 Street Bob
- Softail Stripped Transmission fill hole
- Klock Werks fenders
- RC Components Slip-on's
- relieable of 103 2015
- Blacked out 18 Fat Bob (pic)
- cam tensioner and general maintenance
- Springer Bushings - Need Help!
- 2018 heritage Engine care
- Windscreen Creates Buffetting!
- fat bob 2018 17'' wheels - 120 front
- Taillight conversion help 2012 faboy
- 2007 Night Train electrical manual/codes?
- Ignition knob 2015 breakout
- What are people paying for 2018 Fatboy
- 2017 Heritage Classic runs really hot
- Frame Changes
- 16 Fat Ape Handlebars for my Breakout, but...
- What size front wheel bearings in a 2008 Fatboy?
- Introduction w/questions
- 04 night train rear wheel
- Catalytic converter locaation?
- Dubai Police To Patrol Skies On Flying Motorbikes
- Starter?
- breakout wont start
- IF you are considering a C&C seat..
- I have a question about my 2003 Softail
- Hi all
- 2018 = 10mm Banjo bolt are the early model 7/16?
- 2018 Fat Bob Handlebar Options
- exhaust recommendations please
- Blinkers acting weird
- No Running Lights 2007 Night Train FXSTB
- Looking for help on a front rim
- Fat Bob 114 on Ebay
- Streeet Bob OTD price
- ECU Relocation for Slim
- 2018 Rinehart exhaust
- 2004 Fatboy FLSTFI
- Deraking a softail
- Back in the saddle !
- 2018 Heritage 107 Stage 1?
- Wiggle
- Cancelled my 118 '18 Fatboy order...
- 114 vs 107
- Need help: Stock length springer front end
- Led light kit
- Interesting Facts About the 2018 Harley-Davidson Softail Lineup
- 240 to 260
- They really are just toys!
- 2018 Fat Bob Street Cannons
- BSL Long John Exhaust on Slim
- new 2018 street bob!
- car tire on a 97 fatboy - 130/90 - 16 - is there any?
- Speedometer
- Stock rear pulley 2013 Blackline FXS
- Shotgun Shock - had a problem and got top notch response
- Over Before it Begins !
- softail lowering kit
- 21" front wheel question
- any good? https://www.softailloweringkit.com
- Caliper hits the wheel
- M8. Is this engine noise typical?
- Fuel Crossover Tube Clamp Tool
- carlini gangsta ape heights
- engine gaurd
- 1992 flstf fat boy rocker arm cover damage
- Rocker C to Heritage WILL THIS TANK WORK FOR ME
- 1990 Heritage highway vibration left floorboard
- turn signals dont work
- HD Breakout looking at Commander II Tires - Front Tire Questions
- diagnostic plug 2004 fxstdi deuce
- 2018 Low Rider looks cheap
- ABS brake line question
- Factory Springer Front end models
- Heritage handlebars
- Post pictures of 2018 heritage with bags off?
- I feel so bad for everyone who has never ridden a Springer.
- 2018 Deluxe
- F11 Topcoat
- Softail with Hardtail look
- 2011 Fatboy lo - After service
- Question on the purpose of the exhaust interchange tube
- New clutch stack height is off
- Fat bob stage 4
- Mini bagger
- New seat and tank bib on my Fatboy
- Opinions on this deal please
- Help! Run/Tail/Turn 69461-06D problem
- Is their anything genuinely new on the 2018 Harley Softails?
- Daytona twin tec (#1010) ignition
- Buying without title in hand
- What if..?
- New to the Softail family!
- '89ih softail
- pulley/ratio change
- Finding power but staying semi-quiet
- 08 Softail No fuel pump ?
- Need help identifying tail light.
- Are these windshield mounts?
- Bassani is looking for 2018 donors... giving away free exhausts
- some partīs are ready for the 18 models
- How Hot do slip ons get?
- Engine dress up kit - what's involved
- 2018 Softails - Do they have TPMS?
- Fatboy Owners - What Tire Pressures are you running?
- does the slim use same forks as the fatboy?
- Which model?
- Part starting to trickle in for thr 2018 fat Bob!
- '16 Breakout oil tank painting
- Handlebar phone mount for Heritage?
- 2018 Softail saddlebag options?
- headlight visor only in chrome? WTF?
- decel pops and burbles - good or bad?
- I did come close.
- 2018 Deluxe
- Khrome Werks 2-2 drag style on Heritage
- 1991 Fatboy motor swap
- Cam choice for new 114" Fat Boy S...
- Carb jetting
- Calling on Slim/Blackline owners - Need your help!
- D&D Bobcat w/ThunderMax
- fatboy tin on heritage
- 03 Heritage Pics
- Passenger Floorboards, FLSTCI
- can i put 19'' rim on 07 softail
- Looking for Boarzilla Pictures
- Quick question on forward controls swap from floorboards-2014 slim
- 2014 Softail Deluxe CVO brake light strobe
- Jump starting a 2016 Heritage (FLSTC)
- 2018 114 FB, Audible clunk while holding clutch lever
- Picked up my Street Bob finally !
- How much pullback on HD 6" curved risers?
- 2018 Street Bob opinions
- My new Fat Bob 114
- Will new lowrider Softail be just as smooth on the highway as its' Dyna predecessor?
- 2018 Heritage - After Day 3
- Utilize stock set up for stage 1 air cleaner
- How comfortable is the Crossbones seat?
- Tall vs. Short Sissy Bar on FatBoy
- 23" hugger fender??
- 2013 Street Bob
- Two Black Rear Seat Nuts?
- wont start
- 91 Heritage Softail - Primary Locking Bar
- Would wheels from a 97 Roadking fit a 2008 Fatboy?
- Fatboy windshield
- 2018 Breakout Gauges
- Need new brakes?
- got a fatboy, replacing Heritage
- Cats
- Vance and Hines short shots on breakout
- Street cannons
- Best Low profile seat recommendations?
- Idle issues
- Hogworkz LED headlight issue?
- Proper Harley Slim sissy bar modification without relocating turn signals
- Auxiliary lights on my Slim
- Adding Hardbags to the Heritage.
- What are my options for moving floorboards forward and tilting rear down for HD Slim
- Which oil filter ?
- CD Truflex connections
- 2018 Fat Boy Vibration
- demo rides today
- Picked up a new Heritage today, throwing a code
- Breakout Hidden Wiring
- One Thousand Mile Service
- 2018 Fatbob - Peg Scraping?
- Bike got hit and I have a few exhaust questions...
- Bought an '18 Fatboy today, need mods yesterday!
- DEMO truck came, rode that 114 FB
- Pictures of my new Heritage
- 2018 M8 114 Breakout customized
- '18 Heritage Fork Wind Deflectors ???
- Im old school tryin to keep up with the new school, any and all help will be much app
- Smoother ride on the 18s ?
- What cameras are you guys using? GoPro, Sena, other? Help!
- Wheel Cap (Covers)
- Paint Swap?
- What's Wrong with this Picture?
- loose brake lever
- Looking for Chrome or custom seat nuts
- Adjusting shocks on 2016 Faboy Lo
- Ness grip removal
- 03 Softail standard ez clutch sugestions
- Will just any Smart Siren II work on a softail?
