View Full Version : Softail Models
- What kind of engine oil does a 2020 Heritage Soft Tail use
- lean?
- Handlebars
- Forward Controls Floorboards
- DIY Saddlebag detach kit
- Drive belt tightening with axle nut?
- Which seat will sit you back further on a Slim?
- Rear Brake Issue
- Fatboy 2010
- 2017 Heritage Classic Exhaust
- color-match a flush gas cap
- turn signal one side rear not working
- La Pera seat upgrade
- using a wiseco fuel tuner
- Quick Detach Fitment
- Adding Cruise Control to a Non-S Slim
- Speedometer issues
- cam-tensioner's at 34K-pics
- Headlight Help!!
- EFI Rough Idle??
- Suggestions?
- spoke covers
- 1999 flsts
- 2016 Fat Boy S rear turn signal relocation for hard bags
- Might have a compensator problem, need advice😕
- top end for 2016 heritage
- Deuce rack bag
- hard brake line in rear
- Who makes a small swingarm bag
- 2017 Heritage and Deluxe Pillions
- My 2017 Deluxe
- 2017 Fatboy S Oil leak Air Cleaner
- Does a 2001 Road King seat fit on a 2006 Fatboy?
- Joker machine turn signals
- Softail Seat options
- Highway bars/pegs and us short (fun sized) guys...
- Who knew spending money would be so hard...
- 31511-01b relay keeps blowing
- Dash/Gauge Bulb
- Any one running an Ultimate Seat on heritage?
- Fender Bib
- 97 odometer issues
- First Long trip
- Those with BCT monster baffels?
- Does this fuel filter need replaced? FXSTBI
- Windshield help
- 2003 Heritage springer paint set: is it factory?
- Seat height discrepancy...
- Breakout black rear fender struts
- Removable/removable
- Softail Slim Hard Bags????
- Heritage tins comparability
- Suggestions for a '04 softail Deuce FXSTD rear shocks needed? ...
- Clunking noise when starting
- Fatboy pricing question
- 04 fatboy dim left rear turn signal
- Slapping sound
- Softail slip-ons
- My Rocker C/Breakout build
- Anyone running vintage bars on their Springer?
- FXSTS / FXSTSI with Engine Guard?
- Oil Capacity
- Battery Fuse
- Fly by Wire Throttle grips
- both front blinkers?
- Crank but doesn't have a spark?
- Quick Detach Backrest/luggage rack with Throw over bags
- Did I Buy Stolen Saddlebags?
- Floorboards from 2015 Roadglide
- how to remove front fender and wheel from 2003 heritage springer
- Codes
- Engine problems
- It's June and finally finished winter mods
- Breakout rear fender on a Rocker???
- Quick Release Fork Rack for 49mm Tubes
- Brembo Brakes on an 1992 FLSTC
- cross bones top tree clamp
- Fuel pump runs on accessory position
- FXSTBI Stage 3 is Missing After Paint Job
- Turn signal anomoly
- too much rear brakes !
- Up in smoke... thats where my brake switch goes
- Softail rear brakes
- Need Some Wheel Fitment Help Deuce
- Ignition conversion
- I don't have a trike
- Seat mount on a deluxe
- Alberta License Plates are YUGE!
- Engine re-tune with exhaust change?
- Speedo light goes off and on
- The price you pay to be original
- Need part # 1990 shoftail ingnition switch
- '16 FLSTF idles high; Neutral hard to engage.
- Replacing cam bearings with case split
- Fuel Moto Problems
- 2000 Heritage classic no spark?
- First bike with Fuel Injection questions
- 200mm swingarm swap
- Floor board removal options
- 2 into 1 pipe for night train
- What is the best engine Fat Boy
- Installing dynamic Led cluster turn signals
- 2016 heritage classic speed/engine
- Any Breakout Owners With Flat/Matte/Denim Black paint scheme?
- Top Hand Ventures Sissy Bar Instalation Question
- Nighttrain Noise After Shut Off Draining Battery
- Fat Boy Sticky Throttle or K and N Airfilter issue
- 2016 flhtk 103
- My first harley. 2011 heritage softail. Need help
- value of 2015 fatboy stock chrome rims?
- heritage softail
- changing bars with stock internal wiring
- Fishtail length for the 700th time
- How loud are Samson Cholos
- STEALTH batwing fairing
- A Close look at Willie G's Fat Boy: Past and Present
- turn signal security
- Best mustache bar for Softail Breakout?
- How many miles before rebuild?
- 6th speed indicator light failure
- LED Tank Console Wiring Harness
- new BCM / ignition switch wont work
- 91 fatboy sgifter sticks in the "up" position
- 03' FXSTD Front Turn Signal Indicators
- No Tail Lights.
- Raking a crossbones
- Wiring Question
- '04 FLSTC Walk-around
- Torx Tank Bolt
- oil filter baseplate plugs
- Raising the rear of a Heritage
- Cat
- Arnott airride trouble for flstn
- 1990 Electra glide nacelle on flh?
- Softail Slim- Custom
- 02, 05 or 06 Heritage Classic
- 2005 harley flstsc
- First trip on the Heritage, looking for some answers
- Heat deflector for seat pan?
- Toolbag on downtubes of FXSTS
- heritage softail axle
- Anyone tried these?
- Street Slammers vs Heritage bars
- Any Ladies or Gents on a Heritage tried recurves?
- Blackline Info
- Mod for more lean angle
- Please help. Fatboy shut off no spark.
- Oil dipstick
- 2003 Softail Standard......dies
- Scuff marks on denim.. How do I remove?
- A different Seat / Pillion Question
- 2017 Softail Slim saddle question
- Anti-slip riser mod
- 96 Softail... How do I tell which version?
- Heritage Reveal / Review
- Engine Bars with Extended Forward Controls
- PleaeHelp
- left turn signal gremlin
- Cleaning spokes on Heritage
- Hello installing fork mounted wind deflectors
- Hydraulic clutch question
- bullet fairing on inverted H-D forks
- Dampening rod bolt keeps spinning when tightening
- saddle bag mounting posts
- Kuryakyn adjustable passanger pegs
- Piece fell off While removing brake controls
- Brown bags on black denim Fatboy Lo??
- 17 Softail Slim rear brake lock up
- Shift pegs
- Help finding these pipes?
- Engine guard?
- Sres24
- Registration
- Oil pressure problems
- Arlen Ness telescopic kickstand install
- motor
- Break lights not working.
- Determining swingarm size. Custom bike
- New to the forum riding a 08 softail looking for advice
- 2010 Street Bob
- Lock for Rigid Saddlebags
- Air Ride Suspension Softail Deluxe
- The Switch from Dyna to Softail?
- Apes for Fatboy S
- bigger wheel
- Springer risers on non-springer
- Rocker oil tank
- Which heritage 88b, 96b,103b
- Solo spring seat for FLSTSC
- Brake pads
- 1998 Fatboy (New Rims)
- Metzeler 888's in rain
- fuel management
- Which Fatboy would you choose?
- My Right Turn Signal Starts My Bike?!
- New to HD. Noise.. What is normal?
- 107" build complete
- 86 Heritage picked up today
- 07 Deuce, 96-B, 6 speed, vibration problem
- O ring size for oil drain plug 2005 FXSTBI
- Oil pump 2006 FXSTI
- Front/Rear Master Cylinder Rebuild kit?
- rounded carriage bolt neck
- Tsukayu "Patrol" bags on a 2016 softail
- Front Brake not working
- Raising Springer Front End
- Heritage side plates
- Heritage Saddlebags side plates
- Mustang Vintage Solo Seat with Driver Backrest 79716
- Passemger Foot Peg Tool
- My Winter Project; 07 FXSTC to FXSTB
- Decel Vibration
- Passenger Arm Rests
- Breakout elite 4?
- Harley Maniac
- Handlebar Risers/Clamps
- Need Ideas on how to clean up rear end
- Plastic 97 leather bag liner
- 2006 heritage softail, spare connectors under the saddle
- Newb question: 2009 Heritage
- Is this factory paint
- Sportster to deluxe
- 21" Rim Upgrade Softail Deluxe
- Help with hyper flash turn signals on 14 Breakout
- 96 Fatboy front turn signal help needed
- 1990 Fat Boy Gray Ghost Question
- Opinions
- 06 softail rebuild / tail light directional help!!!
- starting issues
- Heritage riser
- Softail Deluxe Rear Wheel spacer placement
- Psa: V&h fp3 issues!
- Plugs why the difference
- New Easy Start HD Calibration for 110 Motors
- Loud rubbing front brake noise
- Inrtoduction/Opinions on levers
- The sun has come out!
- Fatboy paint and chrome quality
- Softail heritage 09
- 2016 fatboy
- Firing issue
- Softail front end question.
- spring(winter 2016) 2017 mods
- 2010 Heritage issues?
- specifications, harley crossbones
- Fatboy S Auxiliary Lights
