View Full Version : Softail Models
- Cut in my rear
- FXSB Breakout Solo Seat with Studs and Concho
- Buying 11-year old FLSTCI -$5500 vs condition
- Trying to change my exhaust on 2001 FXST
- Handlebar riser bushing torque
- Fuel gauge 04 night train
- Debating 18 inch spokes on a Slim. Opinions?
- Met JD At Sturgis...One Cool Cat.
- vance & hines fuelpak 01-11 softail
- 2012 Deluxe floorboard spacers
- Loose handlebars
- 30 day, 1200 miles on 03 Softail
- anyone redone a rocker c seat?
- Early Fatboy wheel on my Blackline fitment..
- Starter removal on 03 Heritage
- New to forums, clutch issues
- Monotubes lowered 1"
- Bowman sissy on a slim
- Passenger heel guard for Heritage
- My 2015 softail.slim review
- 07 deluxe over heating
- Extended passenger foot peg brackets?
- Q about my new to me fatboy
- After market swing arm
- Want new pegs, shifter peg and passenger peg.....will these work?
- Helmet question.
- Breakout Stage 1 w/ Andrews 57H dyno results
- Spy photo of new 2016 model??
- mustang tripper fastback or le pera silhouette for BO?
- help picking out a cam
- Tour Pack lock
- How to raise floorboards on 2014-15 Heritage?
- Riser and Drag Bars for Fatboy Lo
- Yep.. I joined the Kilometer high club.. :)
- I am needing to check for a cross referenced
- bars
- Softail Slim W/ Mustang seat W/ Backrest. Pic's ???
- Packed up and ready for sturgis. Lets see yours!
- 96" or 103"???
- Breakout turn signal modification
- Fuel Tank Question
- Question/help please.
- 18L-BS Battery in a Heritage instead of 20L-BS??
- Breakout wired for phone
- please help with wheel identification
- 08 Rocker C, Deal or no deal.
- Softail Slim saddlebags
- Fuel Tank removal.
- Variable Pressure Clutch
- '94 FLSTN To Customize or not to customize
- Breakout comfort, could you do multiple 600 mile days in a row?
- 2001 softail standard tail lights
- Added Stretched Bags but they Flare out
- 2016 Softails: Change is in the air?
- Slim seat rebuild and it's great!
- 1996 flstn
- Rear shock on my Fatboy lo
- Softail sturgis.
- Softail Deuce
- Fatboy passneger floorboards
- tripometer/odometer
- Starting Breakout project. Might not proceed?
- Help: Fatboy lo Rear shock washer spin
- Aftermarket 11.8" front rotor for 15 Deluxe
- Painting hardware (bolts etc) or other option
- deluxe fender tip!!?? where or what will work?
- Rear Brakes on 2003 100th Anniv. Heritage
- flstc 1993 dual pipes
- Fuel Moto
- hypercharger install intructions for 2005 fuel injected springer?
- Question
- V&H PRO PIPE fit my 2015 FLSTC ?
- Tail light removal
- Do new fork tubes come with internals ?
- 2015 breakout engine noise
- lowering kit that is 1 inch or less?
- Local techs says my fatboy'15 doesn't have an abs
- Different Needle Profiles CV carb?
- How do I remove the 7" frenched trim ring 69626-99?
- FXSTC oil splatter ???
- BO front turn signal relocation?
- Clutch Vibration looking for Ideas Early 84 (3 finger clutch)
- calling on engineers for leather saddlebag redo
- Looking for advice on changing my tin
- Vance & Hines Fuel Pack.
- Long Ride Shields 50% Off this weekend
- 2008 Heritage Scraping Sound
- 09 crossbones wiring help
- 2 questions
- Stage 1 kit on deuce
- Fanboy lo with white walls?
- This looks expensive
- Clutch problems
- Breakout stalling when downshifting
- False Neutral - 2006 FXSTS
- Lo Pro tank console and combo speedo/tach
- Looking for specific FB tires
- Fatboy, seat recommendations
- Quiet 2 into 1
- Stretched Fender, with a few questions
- Install heat shields on slip ons?
- What To Do Next
- Well I went and did it, and I am OK with it. Kinda long
- Help finding 98 fatboy passenger footpeg mounting kit
- interchangable seats
- Contrast Cut Mods
- Detachable Leather Bags
- Help with Handlebar Mods (1995 Fatboy)
- Lwr Front Rocker Box Gasket
- New set of wheels in Deluxe
- oil mist on oil tank 99 flstc
- No Power
- starting issues
- someone explain forks to me...
- A Different Oil Filter Removal Question
- 2003 Heritage Rebuild is complete. Pics inside
- Transmission feel when shifting?
- dash lights
- Fat Boy wheels on Heritage
- Dobeck EJT does it work?
- Night Train/Black Line/ Standard on the horizon?
- Windshield Bags
- fork tube length
- Brighter headlight options?
- is there a real cruise control for softails?
- Seat or shocks first?
- paint codes for 2012 softail deluxe
- Fishtails: wrong fitment, fit perfect
- Mini ape questions
- Boss Bags Heritage bag stiffener kit
- Crossbones vs Fatboy Lo
- Dealer took my 3 week old Deluxe away today
- evo vs twincam overall size
- 2000 Fatboy CEL Flashing
- floorboards to pegs?
- What brake pads do you use?
- Questions about a 2004 Deuce
- Shotgunshock update
- Is it just me or is it hard to find rims that will fit an 07 flstn
- Engine Over Heat
- Fork turning limits
- Total Rebuild: Rocker
- night train rear wheel
- pics of night trains with t-bars?
- what seat for 2000 night train
- 2010 oxygen sensors the same?
- Lowered Heritage Softail, needs different Jiffy stand
- question for you springer guys
- newbie
- Tube in the Tire?
- breakout fairing
- Bad Cop Ready For Sturgis!
- too low
- Wiring up a sidemount tail light.
- New LePera
- Crossbones Seat is it bouncy?
- And let the fun begin!!!
- Intalled DK Customs drop in LED bulb in my Slim
- Where to buy 21 inch 60 or 80 spoke Dna for 2009 flstn
- fork bag
- Fatboy w/ Aftermarket Frame
- Removing passenger seat?
- 2008 cvo springer engine light
- Need advice on aftermarket spoke wheels
- New member, and new Deluxe
- Breakout at last
- Newbie
- 2001 softail rear swingarm and frame section bent
- Any experience with LazerStar turn signal mounts?
- Deuce Solid rim: 17" AND 18" types?
- Kuryakyn Phase 7 Headlight ?
- re-build stock seat or Airhawk?
- seats for breakout?
- 2001 Softail
- Harley Fatboy Lo 92068-08a
- Daymaker high beam out
- Exhaust Year Fitment - 2008 on a 2000
- Has any one installed a Drag Specialties Coil Cover
- Attempting to troubleshoot a problem... doesn't sound good
- Best place to buy cycle vision bagger tail for Deluxe
- New(used) question
- 2006 Softail Deuce Seat replacement
- Folks with ECM mounted on top of battery...long term input?
- Rebuilding the Night Train
- Security light keeps popping on, 2012 Slim
- clutch adjustment
- Trying to get more info on cams
- How do you clean your spokes?
- replacing the windshield?
- Just bought a 2012 blackline
- options for music?
- Something went south...
- 2005 Deuce, Clutch grab near end of lever release.
- 2005 Deuce Front Fork rebuild?
- What brand of tire?
- 2015 Deluxe build
- Do you love your deuce???
- Looking for a good indy shop in San Jose/South Bay Area CA
- Fenders and Tanks
- Tunes on your scoot
- 1K service issue - advice needed
- 2011 Fatboy Lo- won't start
- FL-Vied installation instructions?
- HD oil or Mobil 1
- inner shift rod lever?
- Looking to add some bark to my 2013 Heritage Classic 103 ci
- 300+ mile seat for 2008 Night Train?
- 09 Heritage unknown connector
- Suggest a second seat for long hauls
- 2000 fatboy solo seat
- Foward Control Kit for 2005 FLSTNI
- Help identify this fairing if you can...
- brawler seat question.
- Why does the Slim ride so good?
- Will this seat fit?
- Windvest shield on the Springer
- please help 422 shock adjustments
- Runs bad/ one cylinder when restart hot
- 2008 twin cam Fatboy Inner Primary seal kit wanted
- Baffle Removal on NEW Bike
- Today was my maiden voyage....
- LaRosa Design Black Solo Side Zipper Bag with Fuel Bottle
- 1998 Heritage Softail Classic custom
- Hot Heritage
- Seat Ideas
- Issues after Big Bore Kit
- rear extended fender rail
- Dual exhaust
- What vent hose is this and why is it leaking on my Breakout?
- Samson Thunder Pro 2 into 1
- oil leak
- Anyone try TCB vs ABS on Softail ?
- Pivot point safety issues?
- Deluxe Suspension
- Anyone going to Sturgis from england
- Anyone Going To Sturgis Week Before?
- Stage 1 with stock breather lid on carbed TC88
- need saddle advice
- Just bought 06 train
- 07 night train help me pick wheels!
- Traded for a new BREAKOUT today.
- My New 2015 Deluxe
- nut welded on rear fender for seat broke off
- Installed new heads and cams
- swing arm bag
- 2007 back to 2003 front wheel bearings?
- Slim Clutch Cable...Two Questions?
- Carlini Gangster, Flying, Evil ape with a windshield?
- New here. 2007 Softail Standard. Questions re: O2 sensors and detachable backrest.
