View Full Version : Softail Models
- softail wheel fitment
- Big bore plan..need insight before I pull the trigger.
- Vance and hines b/s
- Bassani firesweeps
- Already researching my second winter project
- Heritage bars?
- Cobra FI 2000 Power Pro
- Show me some good big mirrors
- Never heard of this softail fender manufacturer ..do you?
- 41mm, 6" Over Stock Fork Tubes
- Pipes on my slim
- Tank removal question
- spoked wheels on 2009 night train
- Cam support plate and oil pump upgrade
- Fuel question
- heritage hard bags
- Whatcha Got?
- Footboard Extension Options for Earlier Softball Models
- Thank you Veterans
- Fork brace on a softail?
- Vance and Hines pipes?
- Long Ride Shield Vet Day sale 60% off
- lottermanns custom rear fender for flstsb crossbones pics?
- Dual Disc Softail Slim.
- Bags on your Slim?
- show me your fenderless front end w/ a fork brace
- before and after My 2008 heritage build
- GoodYear Falcon SPC Rear Belt
- Dual calipers 13" rotor springer
- 180 tire
- 01 Deuce shifting ?
- Need help with possible used bike purchase
- Picking up my deluxe today!
- Wire question
- Stage one
- internal cable for softail pics please
- Softail on true duals anyone?
- When do you change Fluids?
- info stretched bag
- 2010 fatboy
- Softail Rear Shocks
- 12 1/2 ape hangers ebay 76 $
- Recommended Cam Upgrade
- Wild 1, 12" Outlawz, Install ?
- im new here and need little bit help!
- Ripsaws
- Scratched windshield
- How to waterproof ECM connector after moving?
- street slammer question
- Storage
- Crank Breather elements (twin cam only)...
- Hella e code 80w/100w
- Did my first TC B motor bottom end today.
- Help!
- new slim crashed today
- '01 Heritage! New to me with ??
- Playing with pictures
- Flush mount fuel gauge and cap for early twin cams?
- passing lamp bulbs keep going out
- One piece clutch cable
- Who's running ONLY one throttle cable?
- Big City Thunder Monster baffles
- Clutch adjustment
- Breakout color torn...
- Slow crankin Slim.
- Photos anyone!!!
- Anyone recently work with shadetree fabrications?
- Heritage Saddlebag Guards on 08 Deluxe?
- Redline Tranny Fluid, you use it?
- High Pitch Whistle
- Revolution Cylinder & Piston kits- Any good?
- 2012 deluxe- stretched harbags for true duals with lids and lathces?
- 2 into 1 for hard bagged softail
- Comfortable Handle Bars for Shoulder and Neck Pain
- belt guard? is it really needed?
- Rocker C, chage trim instert dash tank
- rear brake failure
- Had her for 3 weeks and...
- Back rest with stock seat
- New guy here with questions
- Considering a used Fatboy
- Heritage Softail Turning Capabilities
- BACK in the saddle - just picked up a Softail Deluxe
- Fitment: ~2008 softail fender fit a 2002 softail
- Slim hard bags
- 07 Deluxe - Batwing or Harley Rock Hoodz?
- Anyone knows who makes this axle nut cover?
- Which wire to power the passing lights
- 2000 FXST frame up redo
- lining up rear fender?
- compensator sprocket
- Wiring heritage headlamp without passing lights switch
- Sweet luck !
- Screaming eagle mufflers
- Anyone ever deal with spitfire motorcycles?
- Heritage seat removal
- Question - Fatboy Lo c/w Memphis Shade Windscreen
- Slim pickins for sissybar and rear fender rack...
- heritage springer baggertail?
- Wind deflectors & Bullet style signals......
- passing lights
- Fat boy?...yes or no?
- Riser Question
- 07 Night Train- Side mount plate & brake light wiring- HELP!
- Slim speedo problems/backlight failure
- 2000 fxst 07 nightrain swingarm and wheel swap
- Avon 120/70-21 White Walls are HERE!!!!!
- Running 15-50 oil in the Winter
- Installing security system (BCM), programing
- Getting there. Still a ways to go
- bar end turn signals??
- windshield question
- California black plate oppurtunity
- at what temp is it too cold to ride, for you?
- Springer Nightrain
- need luggage rack
- 1994 Harley Softail
- Anyone with Exile Parts on their bike?
- BAKER Anti-Overshift Pawl any feedback
- Bars changed out - brake bleeding question
- who sells ridewright wheels
- Slim 2:1 sytem options...
- Chromed Wheel Spacers for Breakout
- rims for 06 fatboy
- Fatboy idling rough
- A couple brake pedal questions (pics)
- your opinions please!!
- 2013 vs 2014 breakout
- Who Owns This LePera Seat (Softail Slim)?
- Tri-bar Bullet trims Headlight and Passing lights
- Wanna swap out that 21x3.5 on your springer?
- Heritage with shovelhead bags
- Will '04 Fat Boy seat fit a '96 Springer ??
- Hard Candy Custom Regrets anyone?
- Light bar help - pics inside
- Cutting Handlebars
- Engine hesitation?
- My Fatboy
- why don't the new motors sound the same as the old ones?
- So stoked - mod #2
- Added some lights to the bike
- Softail Riders V Touring Riders, what a difference!
- I hate the looks of this seat
- Battery so soon?
- Kuryakyn axle covers on an 07?
- Anyone move specifically from a FatBob to a Breakout?
- rear spring rates
- Shock Adjustment
- Speed-o "0" while at speed
- bolt torq
- Le Pera seat questions
- Are there other options for the "plate"?
- Rear brake master cylinder
- Jack's Night Train winter build in the Dirty Bear Garage
- 08 Night Train as a 50's style bobber part 2
- 2013 Heritage Softail Saddle Bag Guards
- Neutral
- true duals and heritage
- 93 Moo Glide
- Reduced effort and reach clutch for 2014 Deluxe
- Chirping Noise
- Slime in Tires
- Clearance Help
- HID: 2013 Softail Slim: ECM says high beam burnt out, no high beam
- Where are the pics of new color 2015 Breakouts !?
- CVO Bars on stock Breakout 2014
- Custom 200mm fatboy fender?
- Custom laced, wire wheels
- Observations
- SoftGlide ? New Bat Wing
- Frame Protectors Soft tail
- Neutral and down shift problem
- Rear brake not working
- "Buzzing" sound from front end
- Anyone have a Slim with
- My deluxe is almost there
- Vivid Dragon paint
- Touring on a Softtail
- seat help
- the Deluxe was in a Photoshoot!!!!
- Deuce advice please
- anyone have a wrapped exhaust on breakout?
- Timing Cover screws
- Who is taking the black OFF their bike?
- Screaming Eagle Heavy Breather?
- freedom perf. american outlaw with hard bags pic??
- Anyone Mounted a Klock Werks "Skinny" Fender on FXST?
- Wait is over, traded RK for a Slim.
- Who's got HD brand Ext Forward Controls on their FL?
- My Bike
- jockey shift kit recommendation?
- Oil leak on 103..
- oem rigid leather locking saddle bags
- chain case oil and gear lube. change
- First 100 miles with the Apes
- Anybody running extended bags on their softail?
- Turn signal keeps burning out
- Trucklite passing lamps Napa part number?
- what cable extensions should I get?
- Hand me down Heritage Springer
- Will this 21" fit my Softail Heritage
- Bitchin seats?
- Mean City Cycles passenger seat mod Crossbones
- New Italian Seat / Pillion Pad / Bag
- Headlight trim ring
- progressive drop ins???
- love ride shotgun
- Alarm and battery life
- anyone have a DIY on disasembling the triples?
- Anyone in the UK have Rocker touring struts?
- Question for Carlini Apes owners
- Pathfinder L.E.D. H4 bulb
- sealing a leaky 60 spoke wheel on rocker?
- Starter Problems
- How to lower Stock Heritage bags
- Fatboy 17" wheels?
- local Indy surprise
- Ashamed, but new front fender....
- Buy this battery
- new wheel help....
- Anyone using Renthal Fat Bars or Pro Tapers?
- My 1st mod. More to come
- Got 16" Apes, so whats your grip width ?
- 2010 fatboy tramssion stick
- 2008 Softail: Starter Covered In Oil And Dirt
- Fat Boy 2006 cvo exhaust dude
- Headlight issues (help)
- 7 hours for internal wires?
- Looking for darkside info for '96 Heritage
- 2012 FatBoy Lo part#?
- Can you strip Chrome from handlebars??
- Rocker style passenger seat for softail
- Show me your bar end mirrors
- Breakout: Front Fork Lowering Suspension Kits, What's Out There?
- Transmission Oil Leak?
- adding painted saddle bags to Heritage
- Dual Front Brakes
- 2014 deluxe slip on
- Exhaust Tips
- OEM tires in rain
- Bobtail Tailight void ideas
- 2007 vs 2011 fuel tank
- >>>How I Got Here<<<
- HD 4" LCD replacementspeedo
- Winter Project ideas
- Soft tail Heritage seat
- Fatboy BLACK Front turn signal relocate kit? Where to get
- ?Desert Dawgs GPS Windshield Mount?
- Shotgun shock install
- Fat Boy
