View Full Version : Softail Models
- Harleys are slow
- Elevated foot pegs with foot boards
- A perfect jacket for "Softail" riders!
- Shotgun shock question
- New to the Softail Family! Just bought a 2013 Breakout!
- Prog standard 422 vs 422 RAP
- stock hp and torque numbers
- "Recent" shadetree reviews??
- freedom performance Cust svc
- Japanese Harley Softail (model)
- oil out the air filter
- Upgrade:Brembo-EBC rotor-chrome sliders
- SEPST Map Request. '13 Softail 103
- Move tail lights from fender
- how to install stock pushrods..??
- 06 Deluxe Charging System
- slim/blackline sissy bar questoin
- 94 Fatboy Good Buy or no?
- Good Buy or no?
- Pics of license plate side mount please - Breakout
- Front wheel spacers for a Breakout
- interchangeable parts
- new to me 2000 heritage classic
- kuryakin mach2 horn cover
- what size eIII on rear for fatboy
- Installed Trucklites....however...
- question on led lights
- Explanation of Counter Balancing
- Oil extractors for performing service on a softail
- Let's talk Fenders.
- New LEDs in my stock speedo ('08 Night Train)
- New 9.5 inch risers, handlebars won;t stop moving
- The 2011 Bones is finally finished...
- Check Valve/fuel line leak when fuel pump kicks in
- Air Filter Question
- Headlight Set Up
- "Fixed" my fuel gauge today...
- Seat Suggestions Please
- wanting a 23 front fat spoke
- Any Fatboy or Fatboy Lo owners chop your rear fender?
- Front suspension & brake upgrade
- noise coming from tranny when in neutral
- Help me find bars similar to these!! HELP!
- Deluxe fender on stock slim struts
- New Breakout and a question
- DNA Chopper Headlight?
- Can the keyless fob be added on your own?
- Thunderbike.de reviews?
- Trailering question...
- Wiring, what a pain!
- Todays ride pics
- Danny Grey Seat thoughts?
- tires: to change both or what
- Mobil 1 V-Twin synthetic oil
- Rear fender & seat kit
- harley rocker c uk new paint job
- Motorcycle Jack
- Screeching / Shrill Sound
- Changing front caliper heritage
- Bike Selling Question..
- Moved on to the Bagger.
- Softail just cuts off
- which pipes
- brake pad spring clip
- Slim Exhaust Question
- What Fluids are you running?
- How are the breakouts 2 up?
- 2000 Softail just dies
- Helmet lock
- Lowering kit
- Harley "Disco gauge" FYI
- Today's ride...Waterloo (Trail of Tears site)
- Garage door opener for $14
- Speedometer reading slow - FIX INSIDE
- ok i got ripped off, need info
- Review of Captain Itch Crotch Cooler
- Harley e-book Road Atlas
- Captain Itch Crotch Cooler/Gel Insert Complete!
- Guys with reckless fairings come in
- *Advice* Gonna Install A ThunderMax This Weekend
- Just bought a Breakout
- Anyone install the passing lamp bypass kit?
- Rear axle nut socket size
- Softail Slim Headlight Nacelle Options
- baffles or no baffle??????
- Oil blow out from air intake on Fatboy Lo ?
- Raising or lower headlight aim
- Tested out LOW RANGE fuel warning today....
- 200mm Dunlop American Elite mileage
- Low Fuel Light question...
- brake line question….custom brake lines?
- passenger floorboards?
- Slim oil cap heat
- Night train seat
- 1990 softail jetting after new exhaust
- 2014 Fat Boy Lo bar swap for Heritage Softail Classic bars
- Painting wheels
- Squishy Forks on Heritage
- Mini Apes on Springer
- PowerVision Glitch
- Peanut tank on a breakout
- Jake at Heartland USA...
- New Brake Recall
- Softail Slim Seat Help!
- 2014 breakout alignment/frame issues
- V&H slip ons
- Coil Relocation Kit...
- Progressive 422 RAP HD, my review
- Danny Gray Seats ....
- Rear wheels spacers
- Decibel reading
- Just change my solo seat, picture inside
- Performance Machine Headlight Housing fit 5 3/4 Daymaker?
- 25000 mile service
- Boss 42D in a DELUXE.
- FatBoy Fairing Help
- Rocker C STOLEN, Lou, KY
- Error Code Help
- Rode a 2007 Dyna Low Rider today.... (Softail comparison)
- 2011 Softail neck...what triple trees/forks can I swap in?
- Led strip brake lights
- Which 20mm belt?
- 2005 Fxstbi....Want power
- Lower wind deflector fangs attached to removable shield hardware
- Question about Progressive Drop In Kit??
- FOB Battery life?
- Max bar height with stock wiringp
- horn wiring
- pillion seat on softail slim?
- Night Train wheel on a Heritage?
- Heritage Bars or Mini Apes
- 2014 slim forward controls
- Charging system
- Security FOB range problem
- Engine Noise Concern.........
- Bike cutting off for no reason? Try this.
- Tsm pn 68920-07
- Deuce Power commander, where to mount??
- Windshield help on 14 Slim
- Accessory help on a 14 Slim
- Need help with progressive drop in fork spring install
- LED turn signal question...
- Change brake discs
- Bleeding front brake....ARGH! (Newbie)
- pinion gear getting stuck
- 2001 Deuce with carb not running right
- Removing the Tank......braided crossover?
- help advice
- Fatboy Shock stems
- Anyone else having trouble with LCD oil level & temperature dipstick?
- 2015 fatboy lo colors
- Rear injector open/low efi
- Rocker to fit a rocker C flip seat?
- Changing turn signals without tripping the warning light??
- Custom forward control extensions
- freshly installed auxiliary lights (lots of pics)
- I thought a had a major problem
- Help! Jim G's Breakout attacked by almost naked women!
- Need a tune?
- How do I remove wax from
- I tell ya what.. nothing and I mean...
- How far can I lean my FatBoy '11 with HD front engine guard at speed?
- Cobra tyre pressure
- fitting options for saddlebags
- Inner Primary sealed bearing
- Harness hanging under right side of seat
- Wheels for Heritage
- Vance Hines TD install issue/question
- Happy 4th of July Everyone
- to go gear drive or chain drive..???
- A Breakout CAN do "light touring" :)
- Softail Frontends
- bad wolf led headlight
- tide
- Shock adjustment problems for soft tail.
- Some general Harley/Softail questions
- 2014 Harley Davidson Breakout: Where is the oil drain plug?
- Next upgrade?
- Fat Boy & Deluxe Windshield Part Numbers
- from the ground up
- Look at what big boy does now...
- Need help, won't start.
- Brake pedal help
- Added Stage 4, Big Shots, and more chrome
- EFI fuel line replacement
- Windshield on Fatboy
- Finally done, on the road.
- Need info about mustang seat, vintage solo VS tripper solo
- Rear footboards
- Buddy just scratch my fender!
- New C&C custom Seat for my Softail Deluxe
- Rake kit: Seeger or Chopper USA
- I pulled the trigger too!
- Power Vision and Soft Tail
- new 4" risers
- V&H Pro pipe question
- Yr and Mileage, or bling? How big a deal is 10K miles
- HELP new harley owner
- Help finding an item
- 2015 colors
- Carlini Diamond Risers anyone have pics?
- breakout torque spec help
- Slim Riser Swap
- 2007 flywheel issues
- FXCWC Rocker frame
- Little tip on shifters
- Just installed stage 1, product reviews
- Heritage Seat Height
- Reckless fairing folks...
- Reflector LED VS Projector LED
- Fatboy docking hardware for windshield ??
- Does anyone make a kickstand wedge for "raised" bikes?
- Backrest
- Exhaust for a Slim
- leather pro bags
- Helmet Lock
- What do you think?
- a new motor 2003 springer
- hid kit on deuce
- 2 step exhaust. what is it?
- Question for those with fl-vied's
- the deluxe. before and after
- Clunk when letting clutch lever out.
- Chrome Wind Deflectors Crash Bar Clearance.
- Wanna go to Sturgis?
- Rear Fender And Front End For My 97 Softail Custom
- White Wall Options
- 2003 tank ??
- Stumped headligh short issue.
- Samson waiting game
- V&H Big Shots+Quite Baffles+BCT QQ ?
- Fatboy Rear Finder/Wheel
- Extended Pegs for Deuce
- Extended Footpegs for Deuce
- Tank lift fuel scavenging ideas?
- Anybody else run out of gas today? Anybody? No?
- BigThanks to Jireh Cycles!!!!
- Frame horn question with 200mm tire.
- Deluxe rear fender on Heritage
- Heritage rear fender rail differances?
- Breakout into bagger when needed-DONE
- Anyone put Daymakers on their Heritage?
- Broken starter ring gear teeth... AGAIN !!
- New member
- Cleaning up the lines on a stock(ish) FatBoy
- Aaaand pulled the trigger on...
- Lost Trip Odometer Settings While Starting
