View Full Version : Softail Models
- Mirrors
- New on Forum with first question
- New seat for my springer classic
- Broken jack shaft and ring gear
- Lets see your grips.
- 18 in the front 16 in the rear on a deluxe
- And so it begins.. My 2013 Breakout FM 107" Build
- Chance To Buy A 2004 Deuce...
- Question about battery, aux connection, etc...
- For all my snowbound friends...
- got my train back!
- stretched fender for fat tire bikes
- samson true dual exhaust installation
- trickle charger
- Best solo seat for tall guy on a xbones?
- DirectCycleParts
- CVO 2011 softail ride quality etc
- B&B Reproduction bags
- 2000 Fatboy sputters a bit
- What are your favorite Fatboy handlebars?
- Fatboy Auxillary Lights 2011+ canbus HELP
- Breakout Exhaust..Intake finally done!
- its almost done!!
- Anybody got 10" ape pics?
- detachable backrest
- 2006 Softail Springer Classic Project/Build
- break out dash part numbers
- Vance and Hines - Short Shots vs. True Duals
- Top endm bottom end?
- Does 05 Softail Deluxe Exhaust HARFXS 1450 fit 02 Deuce?
- Ignition switch hinged cover is stuck
- Which fenders fit?
- Good luck selling THIS Breakout...
- Upgrading Fuel Injectors
- adding fairing to heritage classic
- Newbie Question (Cheap 2001 fatboy)
- New here
- Low mount tag
- Lowering my Night Train
- Breakout Sound Fix and Cat Delete
- softail slim tank slap
- Fatboy fender options
- New Throttle/Clutch cables
- Mini tach for 2000 Heritage tc88
- Deluxe Fork Springd
- Softail ride.
- Lowering Harley inverted front end
- Help, oily gasoline liquid pouring from ignition
- Removing Frame Horn help
- spoke wheels & WWW tires questions .. are they all the same weight ?
- Do I have the "right" clutch?
- Turn signal Relocation with Fairing
- Headlight/ spotlights for 1994
- Continuous whine/noise from primary in 2007...suggestions?
- Aeromach crushing pegs
- 2014 Heritage Softail Classic
- Any way to test a used Stator before install?
- WorksPerformance Springer Dampener Review
- Running Deluxe without any pipes...
- Breakout stock height
- rocker arm question
- Will the HD tool box fit on a 2012 deluxe???
- Roland Sands Tracker Fender
- eBay score
- gel or foam type seat
- Combi Speedo/Tacho Gauge will fit 2007 Softails
- Got $200? Transform your front end!!! Ricor Intiminators / Race Tech Springs Combo
- Is this bike worth the price?
- Taking apes off a Softail Deluxe...
- Extended rear fender
- Truck Lite on a Fatboy
- redoing my bike..
- Apes on FXST?
- More clearance with forward controls?
- Help on extended foward controls
- CVO Deluxe tank emblems
- 98 Heritage shifting
- need expert help!
- longest ride on a bare bones....
- Cool front fender
- front end loose feeling under braking
- Info on samsons true duals for 06 softail deluxe
- New Dyna / Breakout Hybrid coming out soon by HD.
- Need help removing a dash from rocker C
- I need the model # for a Big Crank battery
- Would you please vote for Peg's Softail Breast Cancer bike??
- Advice on fitment
- Gaskets Engine/Trans
- Before and after
- Softail Slim Question?
- Need some advice
- Oil Pressure 0psi at idle.
- Should I be concerned?
- Deluxe bars on a Heritage need cables?
- Help, Please Identifying this License Plate Bracket
- Ultima el bruto 120 will it fit???
- New (to me) Heritage Springer
- rear fender rail
- My Softail Rebuild
- DNA Wheel Review, do you like them?
- No front fender - do I need a brace?
- MMM i love my new flyin apes
- S&S Mod
- Ape Hangers
- Willie and Max swingarm bag
- Help
- Need opinions from fellow Ape lovers
- Fatboy Front Fender
- Fatter front wheel and tire on a FXSTC?
- changing out heads/ jugs
- Some clearification of Screamin Eagle please
- Dakota digital dash for softails, any one played woth them?
- 97 Softail Shifter Sleeve Bushing
- Drag bar cable lengths
- Custom seat pics needed (i.e. stitching, fabric/material, etc)
- Will applying a Softail front fender rail require drilling holes?
- Internal Handlebar Wiring
- FATBOY Headlight trim ring help
- Expierences with Osprey Limited???
- Thoughts on BodyPartNation Bagger rear end
- I need something chromed
- Oil lines changed to braided?
- Breakout - 1.5" Drag Bar
- Softail Drag Pipes
- Has anybody received their Samson cholos since their move?
- Lowering my Train
- How many of you have found the sweet spot on your Shotgun Shocks?
- 2014 Softail Deluxe CVO Part Numbers
- DK Customs stuff installed
- Bottom of riser spike caps
- HOT Tech Tip: Ignition coil spark plug connectors
- Frames
- Samson cho Lo 39 36 42
- Lowering blackline front end
- 2014 Softail Slim with Extras
- Low beam problems?
- Need more performance from my carb'd 02 fatboy
- do I have poly riser bushings already?
- Need help removing passenger seat on 93 Fat Boy
- Looking at changing the bars, suggestions?
- Klock werks 20" windshield
- Need help for short shift lever for Softail Deluxe
- Looking to move up
- Trike forks for dual brake?
- Looking to do hard bag conversion
- Breakout Shock removal
- Need help with possible wheel switch
- Lever Action Solenoid
- Heritage Springer Saddlebags.
- Adjusting Softail Shocks at home ---doable?
- Hand controls without the switch housing???
- Wife's new Deluxe - exhaust question
- Heritage Softail Springer Buying Advice
- CVO Breakout seat part number?
- West Coast Chrome
- Re-chroming Thunderheader exhaust problems
- Extended Forward Controls For Breakout
- New Slim Additions
- trouble changing rear brake pads cross bones.
- Deluxe Chrome Parts
- Am I crazy? Streetbob over my Softail Custom
- Screamin Eagle II Slip On Mufflers
- HD Bullet Headlamp Housing with Daymaker
- Pissed off with softbrake
- 02 fatboy rear tire
- Hate Having No Fuel Reserve On Breakout
- 2012 Can/Bus System with Beach Bars
- Going with a side mount plate with tail light...
- Step by step for Ape hangers ?
- Anyone mount a gauntlet shield?
- Help with these Ape Hangars. What brand???
- Idle speed eratic
- companies that can modify seats
- Accutronix Forward controls- Footpeg Help
- can't decide between chrome or black exhaust
- another cables , beachbar question
- 2013/14 FatBoy Rear Tire size
- could use some advice and some ideas!
- My low Low
- HD DAY MAKER LED HEAD LIGHT question
- wind deflectors on forks Deuce
- Opinions/advice appreciated
- Frustrated- Outer Primary Cover Stripped
- Cheapest place to order true duals for a 12 Deluxe?
- New paint, What ya think retro
- will the carlini road king riser work on my softail?
- 2012 Heritage performance
- craigslist ad I just found
- ride safe for 2014
- 2014 Heritage Cruise RPM
- Help! Pre wired bar kit for a 2012
- Happy new year to all
- Solo Heritage Pics
- Before and after pic
- Windsplitter Windshield on Heritage
- Did you Buy New or used and why??
- Does anyone here know this bike?
- Heritage Chrome Front & Rear Fender Rails 91080-93 and 91402-00
- Opinions on doing black powdercoat on a Black Breakout
- Another Fuel Tank question...
- Looking at Bobber Seat Style for my Rocker - Not Sure About Spring Seat
- chrome fork legs
- Q about the HD Combination Speedometer/Tachometer for Heritage...
- Another "Progressive Spring Install Help" Post
- is there such thing as too much customization?
- cheapest forward facing air cleaner - knee clearance
- Problem installing headlight hood type visor ring
- auto tuner for 2013 fatboy
- New Slim
- Stage I
- Sissy bars on Breakouts?
- 09 rocker vs wide glide forks
- pics of deuces
- O2 sensors unpllugged. Why?
- PCV Threw Bike into "Limp" Mode
- Breakout lift/lowering
- When to update ECM
- compatibility
- V & H Pipes
- Installing new brake lines with ABS and Speed Bleeder
- Cheap batwings
- Heartland USA ez200
- I want to see some 21'' spoke wheel on a fatboy with the stock fat boy fender
- Windshield bug remover
- 200mm softail handling vs 150mm softail handling
- Need Help with gas tank
- Choosing between exhaust brands?
- Electrical problem
- Beach bars for short girls!
- how to adjust ur stock shocks
- Just order 39" Cholos
- 1993 Softail Heritage
- Breakout Wheels on my ROCKER
- 2005 Heritage Classic seat fit an 06' Fatboy?
- Heads question...
- Avon 230 60 15.... Anyone?
- Another ape hanger question
- hate seeing my bike like this
- Clutch advise?
- Clutch advise
- Rocker with a Mini Beast horn?
- found a broke rear spoke
- Fuse size............SS????
- Installed A Dakota Digital Speedo..My Initial Review
- Rocker C and Danny Gray seat
- -fork oil-
- night rod blackline
- Gas gauge scratches
- Anyone ever run the SE HTCC 113?
- 5th Annual Were You Naughty or Nice?
