View Full Version : Softail Models
- FatBoy License Plate Relocation..
- Breakout Sightings??
- One of those days.....
- poor idle 2007 softail std
- Windshield and rpm 2013 deluxe
- Wow Spectro Platinum 6 speed lube
- Any advantage in switching to a 250 rear tire from a 240?
- Trigger pulled on the shotgun!
- New 2013 Slim
- Cleaning up rear fender on Deluxe. lets see pics
- Windvest on softail
- My breakout!
- I need someone to tell
- magnum cable help
- Question on older softail
- comfortable seats?
- oil voiding warranty? eh?
- Mods evaluation.
- How to Adjust your Shotguns for Various Rides
- update on king of kings build!
- Beep at Ignition but no ECM codes?
- positive termal melted 03 heritage
- Can anybody tell me why (head bearing grease)
- Baffle help
- Fixing then riding to Cali from Chicago
- P0051 code
- Fork brace suggestions for Rockers
- Breakout with a Smile
- Gas Gauge
- TOUR-PAK vs. SISSY BAR
- My 2013 Softail Breakout
- Front end wobble
- Aux light kit on heritage
- Harley/KBC Helmet shield
- Ride Dogs Ride & Best Bike! (pics)
- Passenger peg going limp
- Breakout - is something missing?
- Best leather saddlebags
- Bike pulling at low speed after dropped, help please.
- 00 flstc led turn signal problem
- Softail shaking @ 70+ mph
- Belt tensioner
- FL pic request
- cruise control for softails in 2014
- Softail Slim Ideas
- Rake my 88 heritage softail
- In Motion .. New pics
- Breakout Vs Rocker
- Any 30" Softails?
- Slim - hand controls and electrical issues
- Softail Slim Cable Routing
- Crossbones dyno number
- Side Mount License Plate...
- Need help installing Saddlebag Guards + Toolbox + Pegs
- ricor intiminators question
- Any Softail Baggers out there running Bag Guards?
- Defected to the Touring world today
- breakout bike
- ok im still new to Harleys, need some help
- Throttle Position sensor
- Advice on bubbling tank lining, please.
- no more hugger rear fenders on soft tails
- Rear Spoke Wheel for 2007 Deuce
- Ticking noise from primary
- Internal Wiring Handlebar 2011 Heritage Softail
- I finally bought one!!!
- For those with enclosed trailers
- FXCW/C with 2" lift & Drag Bar (Original 9")
- Anyone have their parts catalog handy (Slim)?
- Softail Slim Luggage Rack?
- Riser question
- Rush exhaust
- Zox Half Helmet & Face Sock = Comfy!
- Fatboy Tail Light Relocation question?
- Arlen Ness Inverted Deep Cut A/C and Big Radius Pipes
- Auto Gem Derringer tail lights?
- FLSTC Luggage Racks for Touring Bags
- Fatboy hard to roll
- Long Ride Shields "Heritage Recurve" review...
- nightrain side mount
- Primary and Transmission Oil
- Lower Pinch Bolts
- ? rocker
- popping deuce
- Daymaker Headlight
- Is Balanced motor noisier than non balanced
- proud papa
- DIY cheap mod to blacken upper fork tins
- Heritage and Fatboy fenders interchangable?
- Turn signal will not flash
- FXSTC Saddlebag help
- Passenger Floorboard Relocation
- new mods....
- Technical Information Required
- Deluxe with Leg Lowers pictures needed
- Done with seat and backrest.
- This is what it looks like
- Just delivered!!
- t-bars on 2009 fatboy
- LA Choppers T Bars on a Softail Custom
- which apes should i get??
- Wired some tail lights, now my fuel pump is making weird noise!
- $800 for 6" riser install?
- rear tire size on Heritage project
- Thoughts on a blackline bagger build?
- Question for those running the HD led headlight
- Has anyone used this oil cooler
- Noise in my engine got louder today
- Question on Samson Exhaust
- What kind of bars are these?
- Is a different aspect ratio ok for new tires
- extended warranty.. should I or not?
- Attn Crossbones Owners
- Opinions of 2005 Softail Standard please?
- Starter replacement
- New Breakout Owner
- New FXSB
- New apes ( how hard to install) and do i need new risers ?
- Fat Boy wobble report
- Mounting licence plate to swing arm bag
- Rocker handlebars
- Crossbones rear brake line
- Updating Chrome_FXST Air filter
- How to research work on a bike
- I need to order new stainless cables for my ride
- new full coverage thunderheader heat shields
- Stock or not?
- New Slipon's
- Which Laydown License Plate?
- New Rims for FXST, RSD Diesel in Black Ops
- Mustang tripper seat problems on my 06 deluxe
- 120 or 140 front tire
- D&D black exhaust heat shields (low cat) repaint
- New Member w Fat Boy seat inquiry
- Question about swing arm bag
- Breakout Lowering Kit
- Fatboy Lo bars on a Heritage
- Battery Indicator. New Bike!!!!
- rocker c ape questin
- Front Fender Lowering Kit...
- Potential disaster avoided
- Blackline OEM handlebars specifications?
- Softail brake pedal
- Advice on rear fender repair
- Fat Boy renewing my Harley happiness
- Lowered Front End Question , Ricor Intiminators Vs. Monotubes
- Can't tell if this is an optical illusion...
- Patriot Defender 2 into 1????
- Change clutch cable ?? 2003 FatBoy
- Front and rear spring solo seats
- 2012 Voltage regulator question
- Breakout color choice
- cam change/ oil pump bushing help please!
- Softail battery issue
- White water marks on the black face of my speedomiter
- Slim ?s cast or machined Wheels
- Grinding noise / feel at low speed
- Deer Accident Crash Redesigning The Scoot
- Conflicting info on risers
- My 99 fxstc
- Has Anyone Seen A Late Model Softail Frame Raked
- Spark Plug Wires Vintage Style?
- Lowering a 2011 fatboy
- Heritage over street glide?
- Idiot in a cager cut me off. Engine guard saved my leg from worse damage.
- 2003 Deuce crankshaft issues
- Symptoms of a bad lifter
- Rigid Dually LED Lights
- Chrome & Rubber or Slipstream floorboards and pegs
- Horn button alternatives
- roland sands black ops boss 18"
- Saddlebags and solo rack for 2013 Fat Boy Lo
- Paint codes for FLSTF
- Introduction - new 04 Fat Boy owner here
- Harley Customer Service
- It's my first HD and I don't even know what it is!!
- rush slip on baffle removal
- Softail slim power upgrade advice
- Still have slight wobble
- 02 Fatboy running rough
- 08 HD Rocker been sitting...
- bearing verification help please
- need more input
- Electrical help plz
- Samson Exhaust
- Exhaust Extension Experiment Feedback
- Cholos and the Wife
- OK, so I'm stupid...
- I want to install a chrome pulley cover
- Used Thunderheader wrapped
- Custom Made Seats From Scratch, Who Makes Them?
- 2012 Heritage used oil in mountains
- Mod: Say Elo' To My Lil Bat!
- Removing exhaust wrap
- ECM experts
- Can not start 2003 Fat Boy
- e-Bay Smoke Tri-Bar Fender LED Tail Light
- Deuce 18x5.5 Rear Wheel
- Alloy Arts rear footpegs on a Breakout
- Breakout reflectors
- Passenger footboards tilted forward...
- Leak at ad
- When should battery indicator light function
- crossbones makeover II complete, pics11
- pulley cover
- Got LED spot lamp bulbs
- Tank lining loose..Reline??
- Picked up my anniversary fatboy today
- best place to buy a front tire for cross bones
- Breakout Riser Discussion Thread
- New HD Member + Breakout Owner !!
- Need Help w/ Aux. Light Install
- Wheel Space - Brake Disc Fastener Cover
- New Slim Owner
- Ride wright wheel dealers?
- calling all jockey shifters...touring guy needs some info
- Enjoying that 15% discount!
- Backfiring and Hesistation on Decel, NEED HELP!
- Breakout
- Breakout: Burning Smell After Sitting Two Weeks
- What headlight is this?
- Softail issue
- New Breakout trashed oil tank
- Question for Harley parts chrome consultant guy
- diagnosis code po562 softail deluxe
- 06 Night Train
- NooB Question
- Spec Fat Boy Ford Harley edition 2004
- Springer bags on a Fatboy
- American Custom Slipon's
- Softail 180 tire converting from belt to chain
- Thinking about getting a HD Fatboy
- Closed belt drive....
- Screw Size?
- Is it possible to ugrade hand controls to a later year?
- toolbox bracket
- Slim-perfect styling
- 2013 heritage stage upgrades
- Opinions wanted on a bike
- Windvest on a 2012 or 2013 Fat Boy
- Missing tail pipes WTF?
- Auto tune question
- Compact Detachable Windshield Hardware
- 2011 softail deluxe hesitate to start
- Sending my stock Deluxe seat to Mean City
- Motogadget mini speedometer
- 2013 softail deluxe advice
- Mystery Risers
- Power Commander V maps
- Tins to paint, not sure now...
