Harley-Davidson Street 500 and 750
Oil leak
Old 02-10-2017, 06:24 AM
daaaymo's Avatar
daaaymo
daaaymo is offline
Stage II
Default Oil leak
Just posted my intro in general, but the real reason I signed up is this:
I sprung a leak! This is on left side, just under primary pulley and above transmission shaft. Already dug through shop manual, but nowhere I saw does it mention this part/sensor, nor why it would be leaking.
The problem:
It's a steady leak, I had wiped all that off last night, and these photos were taken in the morning. At first I had thought it was the primary pulley seal/collar, but now its pretty clear its coming from here. Anybody have the same problem? Anybody know what that sensor is, in hopes that I can find a replacement gasket/whatever?
Thanks!
Old 02-13-2017, 02:21 PM
Snowdonia Rider's Avatar
Snowdonia Rider
Snowdonia Rider is offline
That's the neutral sensor. New gasket should fix it, apparently some were over torqued at the factory causing them to fail.
lh4x4 (02-17-2017)
Old 02-13-2017, 02:22 PM
Snowdonia Rider
I think part number 11900064 is the one you would need for a new gasket.
Havoc365
11-20-2018 09:46 PM
LQQK_OUT
EVO
22
07-10-2016 11:25 AM
mgoblue3
06-18-2009 05:52 PM
nextorion
10-25-2008 12:56 PM
Rhinoexpress
09-09-2007 08:32 PM
Quick Reply: Oil leak
