Harley-Davidson Street 500 and 750
Speedo needle went to zero while riding.
Old 10-09-2016, 03:31 PM
jmilb10053's Avatar
jmilb10053
jmilb10053 is offline
Default Speedo needle went to zero while riding.
Speedo went 0 and I lost the gear indicator but not the RPM in the digital display. I let off the throttle and down shifted. Bike acted fine. About a mile later the engine light popped on. I started to stop and the Speedo came back to life. The gear showed up and the engine light went off. I drove back home about 20 miles with no issues. Any ideas about what happened?
Old 10-13-2016, 07:20 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
Check both end connections of the battery cables. Very like there is a loose connection. Had that happen on two new bikes over the years. One was a loose ground connection on an 08 Buell Ulysses and the other was a loose positive connection on the starter post on a 10 Superglide.
Both times it caused the things that you described.
Old 11-18-2016, 03:06 PM
Ceddie's Avatar
Ceddie
Ceddie is offline
whaththe-what?
gear indicator?
RPM in the digital display?
what are you riding?
Old 11-18-2016, 03:14 PM
Max2015RGlide's Avatar
Max2015RGlide
Max2015RGlide is offline
had this happen recently - fix was replacing all the colored wires going into the speedo - warranty fix at H-D
Old 11-26-2016, 07:01 PM
jmilb10053's Avatar
jmilb10053
It was a loose connection and a sensor that went bad. Thomas at Man O War Harley showed me where the sensor was and tightened everything at no charge. Thanks everyone.
Missexeccph (11-26-2016)
Old 05-30-2017, 08:58 AM
Patrick G. Dulaney's Avatar
Patrick G. Dulaney
Patrick G. Dulaney is offline
6th Gear
Same thing happened to my street rod
Trek
07-15-2011 09:57 AM
Williams HK-WS
06-23-2010 10:41 PM
eazyrider
09-01-2008 09:26 PM
rwalters
10-14-2007 05:25 PM
eno50
08-28-2007 07:08 PM
Quick Reply: Speedo needle went to zero while riding.
