extended mirrors?
You can wire them to just be turn signals, since the street doesn't have running lights, but I cannibilized the old pilot light wire to make them running/turn signals. They don't get brighter when you have your signal, they instead switch to just turn signal until it's cancled out.
Ps. Rjg883c, I am a girl.
Missexeccph (04-02-2017)
I'm fairly difficult to offend, I was just clarifying. 'Casey' is after all, a mix-gendered name. As I'm also in the military, I'm use to being mistaken for male.
I also think the Street has successfully taken over the Girl-bike catagory from the Sportster. Missexeccph with her extremely pink and flowery model has not helped this.
Received 5,387 Likes
Mirror extensions made for the Street out side to out side with out 29 inches with 33 Inches using stock mirrors Made by Krator cost $16 foe set . They are some what cheap the bracket extension good the hardware cheap but it works. No instruction but anyone can figure it out. Just make sure if you have moved levers you can see the hole in the bars when you thread the bolt in or it will not tighten down. To tighten it needs pass into that hole.
I had my INDY put them while I had coffee. about a 20 minute job.
The kit
[url=https://flic.kr/p/VFU6ra]
after
[url=https://flic.kr/p/UDPV7T]
Before
[url=https://flic.kr/p/UAU7GN]
My INDY he works cheap
by https://www.flickr.com/photos/144658281@N02/, on Flickr
The kit
after
Before
