Power Commander Problems...Not to HAPPY!!!
I bought the xieds a few years ago. The bike ran ok with them for the most part. Fuel economy was not great but I never ever had a check engine light.
So a year or so ago I bought a Power Commander. I was a little nervous about putting it on the bike because im not up on all the computer stuff.
The other day I called Power Commander and got a map that the guy said would work well on my 09 S/G. So today I plug it all in. I install the o2 delete plugs. As soon as I fire up the bike the check engine light is on. Now I will say I took it for a ride and it ran really good. Had more power to me and even sounded a little different.
So I ran the diagnosing gizmo. It says PS0118 something like that. I call power Commander back and the guy says its a code for over heating. He says that the code must have been in the bike for a long time. Then he says reset the code. Unplugg the commander. I unplug everything. I start it up the light comes back on in ten seconds. I am beyond PISSED!!!!
I did have a Power Commander 5 go bad, guy I got it from replaced it for me. On my new bike I have one too. Each bike is somewhat different that's why I always dyno tune that's why you are getting the max out of your tunner and its right. You say your go to OCT fest. These people will be there Cycle Solutions they are good at what they do.
www.cyclesolutionsonline.com check the site out
Yes I removed the Xieds before I did anything. I kept coming up with the code 0118 and that is the temp. sender in the front cylinder. I replaced it last night. I reset the code. I started the bike and the code comes back on in a couple seconds. Do I need to ride this for it to be completely removed?
If the light comes on and goes off with the tuner removed its because the code is historic. When it remains on constantly the code is current. This tells me that the problem is your power commander.
