HELP!!! 4 sensors showing on check engine check.
2006 dyna wideglide
Engine jumped after hitting a hell of a pot hole going fast. Cut all my wires under the bike and the bike kinda just died and rolled to a stop. Loaded it up and got it to a friends where we put them back to together and had to jump start it to get it running and it wouldn't stay running unless I stayed on the throttle and even then I lost power and gained power all the way home. Got it home and that was the end of it running. I redid the wiring 3x now and I'm showing codes in which I'm sure I was throwing after we redid the wires but now I'm lost and don't know what to do. I'd rather not pay all that money when I could do it myself. These are the codes:
P0113- iat sensor voltage open/high
P0118- open engine temp sensor
P0122- TP sensor open/low EFI
P0123- TP sensor high
The bike is trying to start but it's not getting fuel from the sounds of it. Harley said I need a new wiring harness and want to charge me 1,300 to do it. I figured just rewiring the cut wires would be good enough. Guess not. Any ideas on what to do?
It seems like you have another broken wire that you haven't found yet.
It is also possible that a wire could pulled from a connector and may not be noticeable
I also noticed that all those components are close to one another...this gives you an idea of where to start looking.
KennyPowerz
General Topics/Tech Tips
06-06-2018 10:30 AM
