Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
Did you ever get any help on this? I'm also starting to look into doing the 107 kit but I already have the pro tuner so I don't want to buy another tuner just to map it.
I personally was going to use the Wood Knight Prowler TW-777 Cams. They give you the option of either 10.25:1 or 10.50:1 compression.
The way the kit works is if you go with the 777 you go with the 10.5:1 and if you go with the 555 you go with the 10.25:1. I did the 555's a few years ago (before the 777 came out) then added the 107 with level b heads at 10.25:1 last winter. This is what I was told when I ordered my 107
