Tts calibration share-after a good map
Old 10-29-2014, 01:51 AM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
Originally Posted by Sparra
I didn't think that your ecm/tts would accept a map from another bike as the tts locks to each bike...or am I off track???
The tuner dongles won't accept the map directly. The software on the computer is what I am referring to. You can open a map for your bike in the Sepst software and copy the data from the SEPST and paste it directly into the TTS or SERT or Power Vision. They mostly use the exact same X and Y axis. Main thing you need to pay attention to is if the top axis for columns is based on throttle position or MAP Kpa. The tables that use temp range are C based in the TTS and SEPST and F based in the Power Vision, but not a problem as the temp is actually the same. The C may be 60 and the F would be 140 which is the same temp. It would be too easy if they all used the same software file extension. Power vision uses .pvm, SE dt0, and TTS MT8 and lower. That makes for competition and that is good for us.
Campy Roadie
12-10-2017 02:35 PM
shootist57
The Dyno Room
03-14-2017 09:55 AM
roussfam
03-20-2016 06:45 AM
Crazy
Exhaust System Topics
04-13-2012 10:55 AM
wydopn231
03-09-2008 05:18 PM
Quick Reply: Tts calibration share-after a good map
