Need a better Spark Advance Map
You can also try the v4.77 103 cals , with the cubes reset to 96.7 in the tuning constants
I do that all the time to accomodate cam changes etc etc if there's not a 96 cal to suit.
They're all 176AF.....
For what it's worth in my experience , all V&H straight pipe systems can be hard to totally negate the decel popping , and they're not the best for roll on torque neither
Here is the timing map in jpg format. If you would zip your current file you are editing I could put timing maps in it that will work and send it back to you. If you can edit it you can save it and send it. You are right about it being weak on timing. The only thing I see on the VE tables is it is a little lean in the idle area on the front cylinder. Would probably respond a little better if you richened it up from idle over to 15% and from 500 to 1250. Everything else looks fine. You don't have to go all the way to 24 if you don't want. That is just where I put all the maps I build. Some of the canned maps for SEPST are there also.
First, let me say thank you for helping me. Second, if your having trouble attaching files because they are too big, do this. Go here http://www.cutepdf.com/ and download Cute pdf Writer. When you install this, is gives your PC a virtual printer which prints to a PDF file. When your in SERT, SEPTS, etc... and you want to print a map, select print and instead of using your default printer, select CutePDF from the dropdown list and hit print. Another window will open and all you do is give it a file name and where to save.
Now, I have attached my current setup with the SERT without using your Spark Map. The VE tables were tuned using SERT Data Logging with O2 turned on. I did 8 runs over a few weeks. After each run, I used a software called My Tune and imported a DM2 file to create new VE values. I'm only using narrowband sensors so I'm only effectively tuning the lower end of the map. The AFR map is from Andy Whittle and seems to work fine for now.
The decel popping was being tuned out by dropping the AFR in the 1st column from the 14's to as low as 13.2. It was better but only somewhat. Then I read more about how the flame burns the fuel and if I increase the advance in the first column from 1125 down to 2500 where my problem is, I can burn the fuel up sooner and possible eliminate the fuel getting into the hot pipes and decel popping. Well, I put your 1st spark map in and IT WORKS. As you can see, my advance is 20 at 2500 and below until I get to 1000. Then I drop to 10 for hot start kickback.
Now, the other maps you have attached are strange looking. The AFR map is much different than what I think it should be. Your lean as load and RPM go up. I would think you'd want more fuel, especially if your VE table are 100+ in those areas.
I'm tempted to use all your maps you sent and see what happens. What are your thoughts on mine compared to what you're using on the 09?
To get rid of the Decel pop you need to make the numbers in the Decel table smaller by about 0.2. It is already pretty low. The lower the numbers the richer. Also your front VE table is lean in the area where your decel is happening. Make it look like the rear VE in that area and decel will probably leave completely. All bikes have a small decel pop in the 1900 to 1800 rpm area if decelerating with the clutch engaged. It is transitioning from run conditions to idle conditions and cuts the timing and injectors off for few milliseconds if the throttle is fully closed.
The AFR table in the first two rows over to where the 13.8 starts should be around 13.8 back to 0 throttle position. Also you aren't running in closed loop in the cruise area which is 30 to 60% throttle and 2000 to 3500. I would set that area to about 14.3 or .4 max. I wouldn't run any numbers other than the cruise area above 13.8 as it will cause the engine to not cool right in low speed cruise. Also advancing the timing will help run cooler.
The start timing is all the way to the right in the 100% column in the 750 to 1000 area. Usually runs anywhere from -4 to +6. If it hesitates/kicksback it is usually too fast or weak timing. The start spark like I said is in the 100 Kpa as that table works from the Map sensor reading. At Wide Open throttle you are at 0 vacuum and that is also what the map sensor sees when the engine is not running and the ignition is on. It may move back to the left as the vacuum will build some on the starter but not much. You can change that area to 0 if you like and see what happens. The 10 in first row won't likely help anything.
As far as my thoughts, everything except the spark tables and AFR looks ok. The VE tables are ok except where the front table is too lean. I usually set my VE tables below 2000 and don't change them with the autotune. You can do it on stock engine, but I always seem to run into difficulty if I follow the datalog below 2000 with cams as it will want you to lean it too much. AS low as your timing is in idle area below 2000 it will think it is rich and try to lean it out. The VE tables are what are adjusted to change the mixture. The AFR tables are targets for closed loop. You said something about being at 100+ on the ve table and need to richen the afr table to compensate for that. They will go to 127 which is as rich as they can go. If you want to check this out change your VE's on front and rear in the idle area 0 to 15% throttle and 750 to 1250 rpms to 95 and watch what happens when you start it. Don't change your afr tables. If you need more proof change them to 60 in that area and it probably won't even run there. Put them back to where they were then change your afr to 14.6 which is lean in same area and observe what happens. Then change it to 12.5 which is very rich and see if you can detect any change. On a dyno with active AFR control it will make a difference, but not on our map.
Ok. I have made the changes to the VE and the decel maps. I have also made the changes to the AFR as well, but the map that you included and the comments you made on the values are slightly different. I have included excel file with a renamed extension of docx. Just change it to exe. Can you make the changes you are recommending? Thanks
Remember 2008 and up cals from the Supertuner ( SEPST ) are no good to you directly
TTS MT6 cals may be of use , as they are a direct descendent of your v4.77 cals
You can get your dongle "upgraded" to TTS current spec if you choose by posting the dongle to TTS.
In my experience "original" v4.77 cals work well in up to 2008 bikes , indeed my own 2008 CVO Springer is still on v4.77 using MT6 calibrations.
I find the Springer more "flat" on the TTS cals , but "smoother".
The original SERT cals are noticeably "gruntier" but "rougher and more ready"
Sorry. No Rat or Troll. The file extension is xls. My bad. I put the values from your AFR map jpg in my SERT map. I was just confused as too what was in the jpg as apposed to what you had mentioned in post 13. The attached file is a spreadsheet of my AFR map. Can you make the changes to it? Thanks
Thanks RW. I'm going the adjust the VE's as mentioned by making the front match the rear. I also inserted the Timing table sent in post 12. I understand how to adjust the VE's, but how will I know if the Timing needs adjusting besides data tuning and watching for knock? And I'm not talking the decel area at 100%. I understand that as well.
