Ignition/Tuner/ECM/Fuel InjectionNeed advice on ignition issues? Questions about a tuner? Have questions about a EFI calibration or Fuel Injection? Tips on Engine Diagnostics, how to get codes, and what they mean. Find your answers here.
06 street bob, 25 degree stock fuel injectors, 95ci 3.875" big bore, 10.5/1 compression wiseco forged domed pistons, S&S 585 easy start cam .585 lift, D&D fat cat 2 to 1 with prefferrated wrapped quiet baffle, ported and polished heads decked to 85cc's for 10.5/1 compression. Thundermax with autotune. Anyone have a MAP for there bike that is close to my build?
Do you know the number on the list 1 to 800 or so I see
Hope this helps. Item 902
The map selected is good for the heads, exhaust and compression. There in no map that matches your cam. The cam for the selected map has an intake valve closing that is 2 deg off from your cam. Should get your timing in the ball park. AFRs will take care of them selves.
