New Injectors, now what?
This one came from factory with the passive alarm, not an audible. My security fob is the manual click kind, one click sets it and a double click disarms it, so shouldn't affect the alarm once I turn it off. Read on here someone had a similar problem and replaced tssm module. Hoping miner's just a junk battery.
Turned key on after changing battery, took pressure side fuel line off and fuel just runs out, no pressure. Going to assume the pump is going bad, as I don't have a pressure gauge to test it. New battery didn't make any difference and had mine tested and it shows good, holds 12.9 volts under load.
Can't help you with that. All the ones I have looked at only had one quick connect. The quick connect has a flow control valve that won't let the fuel flow when disconnected. It usually only leaks a little when disconnected. Not sure what you have. I do know if the quick connect oring goes bad it does what you are talking about. Not the only reason for no start. Not sure if you have a fuse in the injector circuit, but would check that. Also the system relay can cause this. I saw in another post about swapping the system relay with another relay and if it runs you found the problem. Don't remember what relay it was. Sorry not much help.
01 Ultra 97"BB,Woods TW-5G cams with Woods directional lifters,Fueling Super Pump, Street port heads, Arlen Ness Big Sucker Stage 1 intake, FI2000R PowerPro Auto Tune processer, Rhineheart True Dual headpipes with Cobra slip-ons, K&P Engineering oil filter, LeNale fan,Alloy Art Stabilizer and a KlockWorks 8.5 windshield. And more money spent than the wife knows about
Thanks for the brake light relay idea. It is a 2001 FLHTCUI with 97" Rev-Tech BB, heads shaved 50,000ths, 1.9 and 1.6 valves with .600 lift beehive springs ( 85cc chambers), Woods TW5G ( 575 lift) cams, Fueling Super pump, Cycle Electric 3 phase electronics, HPI MMFX ( 51mm) throttle body with 4.3 white band injectors and an S&S VFI ecm tuned by C&S Speed shop in Alorton, Illinois.
