Fuel Mileage dropped too much!!
09 Street Glide
96ci
Fuel Moto Billet A/C
Jackpot 3.5 Dyno tuned muffs
Powervision
SE204 cams
Prior to the cams I was getting 36-44 MPG. After the cams I tried a tune from Fuel Moto, KE5RBD was helping (and was very close to what the Dyno tuner came up with with just emails). Finally I got tired of playing around and had the bike tuned by Raganit in Houma. Everyone in the area raved about him and I have to admit he got the more torque and hp than I expected. However my mileage has dropped to a low of 22-28 MPG. From what I read from others on the forums MPG usually doesn't take that much of a hit from 204 cams. The speedo was corrected in all of the tuning as well, but I dont think that should make too much difference. All in all I lost more 60 miles per tank as now I only get a max of 140 and was able to squeeze about 220 before.
I have also noticed that the bike kinda stutters or surges (not sure how to describe it. While at any steady rpm the bike seems to lunge and slow down some. not enough for the wife to feel, but I can tell) I will try to take a video of it later on. This is my first cammed Harley so I am not sure if that is typical or not.
I do think however that I can get better mileage and keep the torque that I have now. All I have at this point are the pics of the plugs after about 500 miles since the tune.
I HAVE not confered with the tuner again yet because he is an hour away and I have been super busy at work. I am not bashing him or Fuel Moto or KE5RBD for that matter, just looking for some insight here.
I have pics of the plugs too, but they look pretty good to me.
Rear plug
Front plug
96ci
Powervision
SE204 cams
Rear plug
Front plug
Stang,
the surging might be that your VE tables are a little out of balance.
I try to keep them slowly increasing as you move left to right and down too.
Left to right for example if a VE at 2250 shows 82 83 84 94 85 86, the 94 will cause a little surge or push. the opposite example if a number is lower than the numbers around it there will be a little uuh there too.
Engine vibration will be noticeable too. When I "smooth" my VE table I look at the #'s above, below, left, right of a cell. Then try to set the VE cell in between all of them.
Save your work with another file name in case you over correct and have to revert back to your last correction.
Gas mileage: 2250-2750 is most likely your cruising area see if any VE's are extremely high in that area.
Phase II The front VE's are leaner than the rear VE's, if you get them too far from each other you will get a shake of vibration under acceleration
I hope you are able to see/find something that will help.
SFS
SFS
those plugs look very lean and the condition you are describing are lean. The gap is also atleast .060" looks like. Could be bad camera angle but the center electrode and ground electrode should be parallel at the gap area. If the heat range is too hot it will cause the same surging issue. Those aren't the factory plugs either. May want to get original set of plugs to make sure heat range is correct. Like some said you may want to get back in contact with the dyno and let him know of your concerns. If you can do a datalog run from the gauge screen of the PV and not in autotune and send it to me I will look it over and see if can give you some insight into the issues. Set the gauge selection at the top of the assign gauges screen to advanced and it will pick up more data for the datalog. It would be helpful if you send copy of the current tune to compare to. It is not too uncommon with new tune to loose some mileage from twisting the right grip too much either. I know it messes my mileage up, but not to the amount you are loosing. If need send me email if you have questions on the datalog.
As far as the twisty loss I thought that might be the case, but the mileage dropped way too much. Ashame too because the power is there. I hate to keep bugging you with this stuff since you helped me so much already.
Thanks for the insight I'll let everyone know what he says after I speak with him. Hopefully this week. (If he's not closed for Thanksgiving holiday).
This should ALWAYS be done before any tuning takes place. If they are not set correctly, the rest of the tune can be way off.
