SEPST Basics???
Old 12-06-2014, 03:28 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Default SEPST Basics???
Hey guys...so been trying to do my homework for tuners to accompany 2-2 exhaust and intake. I'm looking into the Screamin Eagle Pro since to date, it's the one I know and understand least about. I know it's just a module has has no interactive screen like some of the others and also has no "on-the-fly" type capabilities. But being realistic about my plans/goals for the foreseeable future, it may fit my needs. I know I'm the type that's going to get it set up right, running great, and leave it alone. Local dealer has a great reputation and does flat rate custom dyno maps for $250. Thinking this may be the way to go. So I'm guessing I'm looking for confirmation that for someone that's not looking for near term future engine mods, get a custom map and call it good, this device may be the way to go...yea?? Anything else you guys can add?
For a '14 Softtail Slim with Rinehart 2-2 and Screamin Eagle heavy breather intake.
Old 12-07-2014, 02:19 AM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
You will be ok. If you are dependent on someone setting it up and making changes when needed, you have the right idea. It takes lots of studying and some background in tuning engines to really get the hang of it.
Old 12-07-2014, 04:17 PM
harleytuner's Avatar
harleytuner
harleytuner is offline
I agree, if your local shop (dealer) has a good reputation with the product, you can't go wrong. Do the mods, get your tuner and have them do the tune and you won't look back. Even if you want to do more mods in the future, they should be able to get you dialed in.
Old 12-07-2014, 09:53 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
And I'm guessing the adjustability of the Pro makes it well worth the cost over the Street?
Old 12-08-2014, 12:48 AM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
The non adjustability of the Street makes it worthless for anything other than a mild stage 1 that is epa compliant. No cams, not much better than the downloads.
Old 12-08-2014, 10:50 AM
Lonewolf176's Avatar
Lonewolf176
Lonewolf176 is offline
You can also check with Jason. Very capable.
http://www.cnsspeedshop.com/home.html
Old 12-08-2014, 09:12 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Awesome, thanks. Had not heard of these guys. I knew Frey's has a great dyno reputation in the area also.
Old 12-21-2014, 09:08 PM
galaxyfe's Avatar
galaxyfe
galaxyfe is offline
Is the Pro Tuner a piggyback like a PC that has to stay connected or is this a flash tuner that can be removed after the tuning is done? Guess this one is small in unobtrusive so probably doesn't matter; just curious.
Old 12-21-2014, 10:15 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
The Pro tuner is a flash tuner same as Power Vision and TTS and some others.
mikelikesbikes
09-19-2014 08:49 AM
bobbyjoes
08-24-2014 08:28 AM
Railridin
2014-2023 Touring Models
08-08-2014 06:57 AM
Voelser
11-05-2012 09:37 AM
Roodog
27
10-21-2010 11:48 AM
Quick Reply: SEPST Basics???
