fuel line quick connect o-ring?
01-31-2015, 08:09 PM
Just as the title says. I have an 05 Ultra classic. The quick connect fuel line out of the fuel tank has an o-ring inside it. The fitting is leaking fuel if I attach the line, it stops unhooked. I can see the o-ring up inside it and the edge is cut off. I need to replace it. question is can I get just the o-ring or have to replace the entire quick connect that screws in the fuel tank?
Shane
02-01-2015, 01:32 AM
If you`re careful you can use a pair of angled tweezers or internal snap ring pliers. The tricky part is removing the "O" ring without tearing it completely up, so you have something to match for a replacement. Putting in the new one is not a problem, though.
02-01-2015, 09:58 AM
The orings that work for the drain plug will work. If the tank is unplugged for awhile. It's a good idea to lube it a bit when plugging it back in.
02-01-2015, 11:06 AM
I was told I would have to buy the whole assymbly , I took the O-rings out which were 2 different sizes. Went to my CAT dealer parts guy and he hooked me up with some new O-rings. I got the part #'s ou tin the garage if u need them pm me .
09-02-2015, 02:14 PM
o-ring size
Kaycee i found that one of the sizes is 10mm x 14mm x 2mm. What do you have for the other size?
TwoBlue02
04-23-2016 06:31 PM
steelerdude1
05-17-2015 05:48 PM
mattHD
04-28-2011 08:40 AM
Psychosis
01-16-2010 10:26 PM
rotorhead
06-05-2009 01:03 PM
