Fuel Table Help
I've noticed a lot of people sharing maps around lately and I thought I'd try and get in on the action! I don't actually need the whole map, I was hoping to just get AFR and CLB tables from a similar build (details in signature) so I can compare them to what I've got. My bike runs well except for a minor stumble at low RPM & low MAP. And I seem to be going through spark plugs like nobodies business. I also had a free power run on a dyno last year and showed 86HP/92TQ, which I thought was a bit low for my setup, and now I'm hoping it may just be a tuning issue. I haven't touched timing at all.
Any help would be greatly appreciated,
Thanks,
Matt.
Thanks,
Matt.
Yeah Mac helped me with my map and a heap of others on the forum, it was night and day difference from the map dynojet provided me
His skill/advice is proof IMO that a "map" has basic fundamentals which apply whether you create a map in the loungeroom on a computer or at shop on a dyno machine
You will get a bike that works correctly through all areas of the ride, ie. cruise, idle, wot, start-up, decel etc,
Update
So just as an update, my bike is all sorted, and you were right Mirrmu and Bob. The VEs needed a bit of tweaking and some other things that I'm not even going to pretend I understand!! Its not that I didn't believe you, it's just that I didn't have the confidence in myself to know that I was changing the right things. Anyway I got a LOT of help from Mac, he walked me through every step of the way and the end result is a smoother, cooler and more powerful bike. And he did that from the other side of the planet!!!
I couldn't be happier. Thanks Mac your a champion!!
gilbert_roadking
19
05-16-2016 08:16 AM
