PCV question
PCV question
I just installed a PCV I bought from a fellow forum member. I've never had a tuner before. I've got a '12 103 RKC. I downloaded a map suggested by MGS ( I have their slip-ons). Ness Big Sucker. No other engine mods. I removed the XIED's and left the O2 sensors disconnected per instructions. The bike starts and idles just fine. I can't ride it yet; weather stinks.
Here's my question: On the PCV the power light is green when the bike is running. The status light is off, although on start-up the status lights flashes red/green/red (or something like that) then it goes off. Is this normal? Everything seems fine, but I just want to be sure. If there was a problem with the PCV, I assume the bike would start and run like crap especially with the O2 sensors disconnected.
Any advice is appreciated. Thanks!
02 sensors!!!
Did you get the 02 sensor plug in resistors that go w/ the PC-V ...the blinking lights may mean that there is an open loop in the 02 sensors .. you can't run it w/ the sensor wires unplugged .... ..What you really need to do is get the auto-tune unit for your model that goes what the PC-V... you will be able to set the AFR to what you what and will run very well .
http://www.ebay.com/itm/Dynojet-Auto...bebf0e&vxp=mtr
AutoTune sounds good. Maybe when funds are available!
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Thanks Jamie! Appreciate you chiming in, even for someone who isn't your customer, yet. That will probably change when I'm ready for the Auto-Tune. I've never seen a person/company more highly recommended than yours.
