Can anyone with a 103 and 2-2 exhaust help a feller out?
Sorry to ask, but would like to play a little. I'm receiving a running rich code and in the interim to going and seeing a tuner a couple hours away I'm hoping to look at other folks' AFR's
Here are my maps currently (canned map). Cams are Andrews 57h, 103 engine, 2-2 Python exhaust. Any advice on changes or a similar set up would be appreciated!
These are the shots from my FP3, I now somewhat understand that these are targets and that I need to look at VE tables which I also have access to but don't know what to do with.
I'm also encountering a bit if stuttering between 3000-4000 rpm's but it seems like it's mostly in 2nd gear not sure if that's possible but is how it feels/sounds. I'm hoping to get to a tuner in the next couple of weeks who is willing to check out the FP3 for tuning but would like to get myself a bit better off in the interim
Thanks you so much! As I read and try to understand more I'm also seeing that I need to better populate my VE tables as well. Ah well live and learn. I will play with these as well. Hoping to be able to make it to tuner who wants to check out the FP3 functionality next week or two.
