Just got my Powervision
So Fedex just dropped off my power vision. Thanks Fuel Moto. But since it's snowing out I can't go out for a test ride.
So my question is what should I do first? Should I hook it up to my PC? Should I just flash the bike in the garage? Should I just lay in bed and read the documentation?
Help me!!!!
I don't know if you can tell but I'm just a little excited to have it.
Help me!!!!
It's REAL easy. Look over the booklet. Follow the instructions that FM sent along with it and you'll have your bike flashed in no time. And then if you want to mount it on your bike that's your choice. I recently bought one from them and had the download for my pipes and air cleaner already set up when I received it. I'm real happy with mine.
Follow the FM supplied instructions on loading your initial map, and it also tells you how to save the Original Tune your bike has. it will always keep that for you.
Then go online and read the detailed Powervision and WinPV user guide. Learn how to autotune. Also watch all of the Dynojet Powervision Videos, till you have them memorized.
http://www.dynojet.com/powervision/
Well I loaded the tune that Fuel Moto installed for me. I ran the wire and the mount and also installed my Medallion gauges that I had ordered. I started the bike and let it idle. The idle was a little erratic. Not sure what this means but once the roads clear I'll do a few auto tune sessions.
Went for a ride today with the tune that Fuel Moto gave me. Bike ran like crap. I loaded one of the Dynojet tunes that was on the PV already and it ran much better. I'm wondering if Fuel Moto gave me a bad tune. Should I ask them for another one or just Auto Tune from the Dynojet one that I loaded?
The first tune I got from FM was pretty good, but backfired thru the exhaust when I let up on the throttle. I ran the auto tune approx 6 times.
Each time things got better. I then contacted FM, told them that it was still backfiring too much. I sent them the tune I had, they adjusted the deceleration mixture (made it richer), and sent it back.
I recommend you try something similiar
