More air????
It might be a coincidence, but if you put the old cover back on does it still run bad?
You should call the dealer and see what the service records say about remapping or installing a tuner. If it was flash tuned they should be able to tell you, and if there is a piggyback tuner you should be able to find it hooked up the to ECM.
Seems doubtful that a different cover would make much difference in air flow, especially if the filter element wasn't changed.
I haven't seen inside the round filter so don't know what shape the filter unit is, compared with yours. If there is an air gap between the cover and your filter, your filter isn't doing any filtering! The cover should seal all around the filter, so the air can only get into your engine by being drawn through the walls of the filter.
